Personally, I've never subscribed to the AGW theory, primarily because of the work of Dr. Edward Lorenz, who discovered Chaos Theory while trying to get his computer to model the Atmosphere. He established that modeling cannot achieve an accurate prediction of weather for a given date beyond 3 to 5 days in the future. Because of bifurcation of the extrapolations, in which minuscule variances at the level of data errors can cause huge variations in the model output, it is highly unlikely that any computer model, or several such models combined, can predict weather 50 years into the future, as has been claimed by the IPCC. IF they could predict the weather that accurately that far in advance their models could be modified to predict the stock market tomorrow.
Yesterday I downloaded the files hacked from the IPCC website in England (it's at WkiiLeaks) and began reading them. I read the tree ring data and all the comments in them. The yamal tree-ring data is the basis for the "new" and infamous "Hockey Stick" graph supposedly proving that the globe is heating up and can only get hotter if we don't regulate increases in the atmospheric CO2. The previous Hockey Stick graph, by Dr. Mann, was throughly destroyed when it was showed that he cherry picked the data and then grossly manipulated it. The problem was not in showing the data cooking. It was getting ahold of the data, which was not being released, contrary to the peer review process and two centuries of scientific research tradition. You cannot replicate an experiment if they don't archive the data.
Counting the "read.me" the folder contains 84 files, most dated 5/24/96, then many are randomly dated between then and 2/19/99. Then, on 12/31/2008 are three data yamal data files which have been pre-processed for use as source files to tsplot, or some other graphing utility, and a Word DOC file containing a draft of a paper which was going to be or has been published, concerning the yamal tree rings.
[EDIT: I've discovered that the 12/31/2008 date must be the result of a touch command, because the DOC file shows, in the properties, that it was first created in 2002 as part of a GreenLand study.]
Here is it's Abstract:
However, some are questioning if tree-rings really relate to global temperatures or just local temperature, and if there is a relationship is it linear as the IPCC studies state.
Here is an excerpt from 1256760240.txt
The "readme.txt"'s, the "info.txt"s, and looking at the tsplot.apo function which was used to generate the yamal graphs is a revelation. Reading the emails is a total SHOCK! They led me to an article by Steve McIntyer, which discussed the Yamal data and in which he demonstrates how the data was manipulated to produce the hockey stick but when not manipulated produces the cool down which has actually occurred during the last eight years, thus destorying the yamal data hockey stick.
Here is one of the emails that discuss McIntyre's report and question their own data and conclusions. They top-post at the ICPP, so the start is at the bottom and the end is at the top.
They are asking questions among themselves which clearly indicate their "model" does not explain important questions, and they know it! And this is just a few weeks before they go to Copenhagen to help further the agenda of the IPCC by reporting even "more evidence" of GW.
Michael Mann was worried about the BBC not staying in the choir, but in this thread he is busy trying to keep the troops in line.
Msg # 1255532032.txt
> From: Michael Mann <mann@meteo.psu.edu>
> To: Kevin Trenberth <trenbert@ucar.edu>
> Subject: Re: BBC U-turn on climate
> Date: Wed, 14 Oct 2009 10:53:52 -0400
> Cc: Tom Wigley <wigley@ucar.edu>, Stephen H Schneider <shs@stanford.edu>, Myles Allen <allen@atm.ox.ac.uk>, peter stott <peter.stott@metoffice.gov.uk>, "Philip D. Jones" <p.jones@uea.ac.uk>, Benjamin Santer <santer1@llnl.gov>, Thomas R Karl <Thomas.R.Karl@noaa.gov>, Gavin Schmidt <gschmidt@giss.nasa.gov>, James Hansen <jhansen@giss.nasa.gov>, Michael Oppenheimer <omichael@Princeton.EDU>
> thanks Kevin, yes, it's a matter of what question one is asking. to argue that the
> observed global mean temperature anomalies of the past decade falsifies the model
> projections of global mean temperature change, as contrarians have been fond of claiming,
> is clearly wrong. but that doesn't mean we can explain exactly what's going on. there is
> always the danger of falling a bit into the "we don't know everything, so we know nothing"
> fallacy. hence, I wanted to try to clarify where we all agree, and where there may be
> disagreement,
> mike
> On Oct 14, 2009, at 10:36 AM, Kevin Trenberth wrote:
> Mike
> Here are some of the issues as I see them:
> Saying it is natural variability is not an explanation. What are the physical processes?
> Where did the heat go? We know there is a build up of ocean heat prior to El Nino, and a
> discharge (and sfc T warming) during late stages of El Nino, but is the observing system
> sufficient to track it? Quite aside from the changes in the ocean, we know there are major
> changes in the storm tracks and teleconnections with ENSO, and there is a LOT more rain on
> land during La Nina (more drought in El Nino), so how does the albedo change overall
> (changes in cloud)? At the very least the extra rain on land means a lot more heat goes
> into evaporation rather than raising temperatures, and so that keeps land temps down: and
> should generate cloud. But the resulting evaporative cooling means the heat goes into
> atmosphere and should be radiated to space: so we should be able to track it with CERES
> data. The CERES data are unfortunately wonting and so too are the cloud data. The ocean
> data are also lacking although some of that may be related to the ocean current changes and
> burying heat at depth where it is not picked up. If it is sequestered at depth then it
> comes back to haunt us later and so we should know about it.
> Kevin
> Michael Mann wrote:
> Kevin, that's an interesting point. As the plot from Gavin I sent shows, we can easily
> account for the observed surface cooling in terms of the natural variability seen in
> the CMIP3 ensemble (i.e. the observed cold dip falls well within it). So in that sense,
> we can "explain" it. But this raises the interesting question, is there something going
> on here w/ the energy & radiation budget which is inconsistent with the modes of
> internal variability that leads to similar temporary cooling periods within the models.
> I'm not sure that this has been addressed--has it?
> m
> On Oct 14, 2009, at 10:17 AM, Kevin Trenberth wrote:
> Hi Tom
> How come you do not agree with a statement that says we are no where close to knowing where
> energy is going or whether clouds are changing to make the planet brighter. We are not
> close to balancing the energy budget. The fact that we can not account for what is
> happening in the climate system makes any consideration of geoengineering quite hopeless as
> we will never be able to tell if it is successful or not! It is a travesty!
> Kevin
> Tom Wigley wrote:
> Dear all,
> At the risk of overload, here are some notes of mine on the recent
> lack of warming. I look at this in two ways. The first is to look at
> the difference between the observed and expected anthropogenic trend relative to the pdf
> for unforced variability. The second is to remove ENSO, volcanoes and TSI variations
> from the observed data.
> Both methods show that what we are seeing is not unusual. The second
> method leaves a significant warming over the past decade.
> These sums complement Kevin's energy work.
> Kevin says ... "The fact is that we can't account for the lack of warming at the moment
> and it is a travesty that we can't". I do not
> agree with this.
> Tom.
> Hi all
> Well I have my own article on where the heck is global warming? We are asking that here
> in Boulder where we have broken records the past two days for the coldest days on
> record. We had 4 inches of snow. The high the last 2 days was below 30F and the normal
> is 69F, and it smashed the previous records for these days by 10F. The low was about
> 18F and also a record low, well below the previous record low. This is January weather
> (see the Rockies baseball playoff game was canceled on saturday and then played last
> night in below freezing weather).
> Trenberth, K. E., 2009: An imperative for climate change planning: tracking Earth's
> global energy. /Current Opinion in Environmental Sustainability/, *1*, 19-27,
> doi:10.1016/j.cosust.2009.06.001. [PDF]
> <[1]http://www.cgd.ucar.edu/cas/Trenberth/trenberth.papers/EnergyDiagnostics09final.pdf>
> (A PDF of the published version can be obtained from the author.)
> The fact is that we can't account for the lack of warming at the moment and it is a
> travesty that we can't. The CERES data published in the August BAMS 09 supplement on
> 2008 shows there should be even more warming: but the data are surely wrong. Our
> observing system is inadequate.
> That said there is a LOT of nonsense about the PDO. People like CPC are tracking PDO on
> a monthly basis but it is highly correlated with ENSO. Most of what they are seeing is
> the change in ENSO not real PDO. It surely isn't decadal. The PDO is already reversing
> with the switch to El Nino. The PDO index became positive in September for first time
> since Sept 2007. see
> [2]http://www.cpc.ncep.noaa.gov/products/GODAS/ocean_briefing_gif/global_ocean_monitorin
> g_current.ppt
> Kevin
> Michael Mann wrote:
> extremely disappointing to see something like this appear on BBC. its particularly odd,
> since climate is usually Richard Black's beat at BBC (and he does a great job). from
> what I can tell, this guy was formerly a weather person at the Met Office.
> We may do something about this on RealClimate, but meanwhile it might be appropriate for
> the Met Office to have a say about this, I might ask Richard Black what's up here?
> mike
> On Oct 12, 2009, at 2:32 AM, Stephen H Schneider wrote:
> Hi all. Any of you want to explain decadal natural variability and signal to noise and
> sampling errors to this new "IPCC Lead Author" from the BBC? As we enter an El Nino
> year and as soon, as the sunspots get over their temporary--presumed--vacation worth a
> few tenths of a Watt per meter squared reduced forcing, there will likely be another
> dramatic upward spike like 1992-2000. I heard someone--Mike Schlesinger maybe??--was
> willing to bet alot of money on it happening in next 5 years?? Meanwhile the past 10
> years of global mean temperature trend stasis still saw what, 9 of the warmest in
> reconstructed 1000 year record and Greenland and the sea ice of the North in big
> retreat?? Some of you observational folks probably do need to straighten this out as my
> student suggests below. Such "fun", Cheers, Steve
> Stephen H. Schneider
> Melvin and Joan Lane Professor for Interdisciplinary Environmental Studies,
> Professor, Department of Biology and
> Senior Fellow, Woods Institute for the Environment
> Mailing address:
> Yang & Yamazaki Environment & Energy Building - MC 4205
> 473 Via Ortega
> Ph: 650 725 9978
> F: 650 725 4387
> Websites: climatechange.net
> patientfromhell.org
> ----- Forwarded Message -----
> From: "Narasimha D. Rao" <[3]ndrao@stanford.edu <[4]mailto:ndrao@stanford.edu>>
> To: "Stephen H Schneider" <[5]shs@stanford.edu <[6]mailto:shs@stanford.edu>>
> Sent: Sunday, October 11, 2009 10:25:53 AM GMT -08:00 US/Canada Pacific
> Subject: BBC U-turn on climate
> Steve,
> You may be aware of this already. Paul Hudson, BBCs reporter on climate change, on
> Friday wrote that theres been no warming since 1998, and that pacific oscillations will
> force cooling for the next 20-30 years. It is not outrageously biased in presentation as
> are other skeptics views.
> [7]http://news.bbc.co.uk/2/hi/science/nature/8299079.stm
> [8]http://blogs.telegraph.co.uk/news/damianthompson/100013173/the-bbcs-amazing-u-turn-on
> -climate-change/
> BBC has significant influence on public opinion outside the US.
> Do you think this merits an op-ed response in the BBC from a scientist?
> Narasimha
> PhD Candidate,
> Emmett Interdisciplinary Program in Environment and Resources (E-IPER)
> Stanford University
> Tel: 415-812-7560
> Michael E. Mann
> Professor
> Director, Earth System Science Center (ESSC)
> Department of Meteorology Phone: (814) 863-4075
> 503 Walker Building FAX: (814) 865-3663
> The Pennsylvania State University email: [9]mann@psu.edu <[10]mailto:mann@psu.edu>
> University Park, PA 16802-5013
> website: [11]http://www.meteo.psu.edu/~mann/Mann/index.html
> <[12]http://www.meteo.psu.edu/%7Emann/Mann/index.html>
> "Dire Predictions" book site:
> [13]http://www.essc.psu.edu/essc_web/news/DirePredictions/index.html
> Kevin E. Trenberth e-mail: [14]trenbert@ucar.edu
> Climate Analysis Section, [15]www.cgd.ucar.edu/cas/trenbert.html
> NCAR
> P. O. Box 3000, (303) 497 1318
> Boulder, CO 80307 (303) 497 1333 (fax)
> Street address: 1850 Table Mesa Drive, Boulder, CO 80305
> Kevin E. Trenberth e-mail: [16]trenbert@ucar.edu
> Climate Analysis Section, [17]www.cgd.ucar.edu/cas/trenbert.html
> NCAR
> Michael E. Mann
> Professor
> The Pennsylvania State University email: [18]mann@psu.edu
> website: [19]http://www.meteo.psu.edu/~mann/Mann/index.html
> [20]http://www.essc.psu.edu/essc_web/news/DirePredictions/index.html
> Kevin E. Trenberth e-mail: [21]trenbert@ucar.edu
> Climate Analysis Section, [22]www.cgd.ucar.edu/cas/trenbert.html
> NCAR
> Michael E. Mann
> Professor
> The Pennsylvania State University email: [23]mann@psu.edu
> website: [24]http://www.meteo.psu.edu/~mann/Mann/index.html
> [25]http://www.essc.psu.edu/essc_web/news/DirePredictions/index.html
> References
> Visible links
> 1. http://www.cgd.ucar.edu/cas/Trenbert...ics09final.pdf
> 2. http://www.cpc.ncep.noaa.gov/product...ng_current.ppt
> 3. mailto:ndrao@stanford.edu
> 4. mailto:ndrao@stanford.edu
> 5. mailto:shs@stanford.edu
> 6. mailto:shs@stanford.edu
> 7. http://news.bbc.co.uk/2/hi/science/nature/8299079.stm
> 8. http://blogs.telegraph.co.uk/news/da...limate-change/
> 9. mailto:mann@psu.edu
> 10. mailto:mann@psu.edu
> 11. http://www.meteo.psu.edu/~mann/Mann/index.html
> 12. http://www.meteo.psu.edu/%7Emann/Mann/index.html
> 13. http://www.essc.psu.edu/essc_web/new...ons/index.html
> 14. mailto:trenbert@ucar.edu
> 15. http://www.cgd.ucar.edu/cas/trenbert.html
> 16. mailto:trenbert@ucar.edu
> 17. http://www.cgd.ucar.edu/cas/trenbert.html
> 18. mailto:mann@psu.edu
> 19. http://www.meteo.psu.edu/%7Emann/Mann/index.html
> 20. http://www.essc.psu.edu/essc_web/new...ons/index.html
> 21. mailto:trenbert@ucar.edu
> 22. http://www.cgd.ucar.edu/cas/trenbert.html
> 23. mailto:mann@psu.edu
> 24. http://www.meteo.psu.edu/~mann/Mann/index.html
> 25. http://www.essc.psu.edu/essc_web/new...ons/index.html
> Hidden links:
> 26. http://www.met.psu.edu/dept/faculty/mann.htm
I have LOTS of emails to read. I started with those written just a couple weeks ago, on 11/14/09. They go back to 1996.
So far, I have read less than a dozen. There are about 1,070 files, each containing a single email or a thread of several emails.
From what I have seen, and the recent page posted by Steve McIntyre at Climate Audit, I can understand why this debacle is being called CRUdGate. CRU is the Climate Research Unit at the University where CRU director Phil Jones is a professor.
Abstract. Remains of subfossil Siberian larch trees in the Holocene deposits of the Yamal Peninsula (Western Siberia) have been collected in order to develop a continuous, multi-millennium tree-ring-width chronology. To date, this work has resulted in the construction of an absolute 4000-year (from 2000 BC to 1996 AD) series. From these data, we are able to estimate summer temperature variability in this region on scales. Radiocarbon dating of selected older material shows that the absolute age of the oldest subfossil wood reaches back 9400 years and the dates of the sampled material are generally distributed more or less evenly through time. This demonstrates that it will be possible to develop a tree-ring chronology more than 9 thousand years long. An initial assessment of long-term fluctuations in northern Yamal summer warmth has been realised through the reconstruction of tree-line dynamics using a combination of dendrochronological (absolute) dated material and less precisely (radiocarbon) dated older subfossils.
To: <k.briffa@uea.ac.uk>
Cc: <p.jones@uea.ac.uk>
X-ARU-HELO: CAMEXCH.ANGLIA.LOCAL
X-ARU-sender-host: cambe01.ad.anglia.ac.uk (CAMEXCH.ANGLIA.LOCAL) [193.63.55.171]:25427
X-ARU-Mailhub: yes
X-ARU-Exchange: yes
X-ARU-MailFilter: message scanned
X-Spam-Status: no
Reply-to: Don.Keiller@anglia.ac.uk
X-Canit-CHI2: 0.00
X-Bayes-Prob: 0.0001 (Score 0, tokens from: @@RPTN, f028)
X-Spam-Score: 0.00 () [Hold at 5.00] SPF(none,0)
X-CanItPRO-Stream: UEA:f028 (inherits from UEA:default,base:default)
X-Canit-Stats-ID: 34330416 - 89bde843c4e5 (trained as not-spam)
X-Antispam-Training-Forget:
[2]https://canit.uea.ac.uk/b.php?i=34330416&m=89bde843c4e5&c=f
X-Antispam-Training-Nonspam:
[3]https://canit.uea.ac.uk/b.php?i=34330416&m=89bde843c4e5&c=n
X-Antispam-Training-Spam: [4]https://canit.uea.ac.uk/b.php?i=34330416&m=89bde843c4e5&c=s
X-Scanned-By: CanIt (www . roaringpenguin . com) on 127.0.0.1
Dear Professor Briffa, I am pleased to hear that you appear to have recovered
from your recent illness sufficiently to post a response to the controversy
surrounding the use of the Yamal chronology;
([5]http://www.cru.uea.ac.uk/cru/people/briffa/yamal2009/cautious/cautious.htm)
and the chronology itself;
([6]http://www.cru.uea.ac.uk/cru/people/briffa/yamal2009/)
Unfortunately I find your explanations lacking in scientific rigour and I am
more inclined to believe the analysis of McIntyre
([7]http://www.climateaudit.org/?p=7588)
Can I have a straightforward answer to the following questions
1) Are the reconstructions sensitive to the removal of either the Yamal data
and Strip pine bristlecones, either when present singly or in combination?
2) Why these series, when incorporated with white noise as a background, can
still produce a Hockey-Stick shaped graph if they have, as you suggest, a low
individual weighting?
And once you have done this, please do me the courtesy of answering my
initial email.
Dr. D.R. Keiller
-----Original Message-----
Sent: 02 October 2009 10:34
To: 'k.briffa@uea.ac.uk'
Cc: 'p.jones@uea.ac.uk'
Subject: Yamal and paleoclimatology
Dear Professor Briffa, my apologies for contacting you directly, particularly
since I hear that you are unwell.
However the recent release of tree ring data by CRU has prompted much
discussion and indeed disquiet about the methodology and conclusions of a
number of key papers by you and co-workers.
As an environmental plant physiologist, I have followed the long debate
starting with Mann et al (1998) and through to Kaufman et al (2009).
As time has progressed I have found myself more concerned with the whole
scientific basis of dendroclimatology. In particular;
1) The appropriateness of the statistical analyses employed
2) The reliance on the same small datasets in these multiple studies
3) The concept of "teleconnection" by which certain trees respond to the
"Global Temperature Field", rather than local climate
4) The assumption that tree ring width and density are related to temperature
in a linear manner.
Whilst I would not describe myself as an expert statistician, I do use
inferential statistics routinely for both research and teaching and find
difficulty in understanding the statistical rationale in these papers.
As a plant physiologist I can say without hesitation that points 3 and 4 do
not agree with the accepted science.
There is a saying that "extraordinary claims require extraordinary proof".
Given the scientific, political and economic importance of these papers,
further detailed explanation is urgently required.
Yours sincerely,
Dr. Don Keiller.
X-ARU-Mailhub: yes
X-ARU-Exchange: yes
X-Spam-Status: no
X-Canit-CHI2: 0.00
initial email.
Dr. D.R. Keiller
in a linear manner.
Yours sincerely,
Dr. Don Keiller.
> disagreement,
> mike
> Mike
> Kevin
> m
> Hi Tom
> Kevin
> Tom Wigley wrote:
> Dear all,
> agree with this.
> Tom.
> Hi all
> g_current.ppt
> Kevin
> mike
> Mailing address:
> 473 Via Ortega
> Ph: 650 725 9978
> F: 650 725 4387
> patientfromhell.org
> Steve,
> -climate-change/
> Narasimha
> PhD Candidate,
> Stanford University
> Tel: 415-812-7560
> Michael E. Mann
> Professor
> NCAR
> NCAR
> Michael E. Mann
> Professor
> NCAR
> Michael E. Mann
> Professor
> References
> Visible links
> Hidden links:
) the shrinkage of its ice cap. RealClimate poo-ppo's that explanation.
