I downloaded 26.04 and attempted to burn it to an ISO dvd disc. Message came up that it was too large to fit on the DVD.
Problem with 26.04
That is because it is by a small amount.
You would need a dual-layer disk or use a USB stick.
Many/most of the Ubuntu flavors are over the size of a standard DVD these days. Even Xubuntu. Lubuntu is still under.
Kubuntu ISO = ~4.7GiB = 5.046586573 GB
"so then it is actually to big for a DVD, use a USB ..."
The obvious answer.
I downloaded it at my house in the mountains, I have faster internet there.
I brought a recordable DVD with me to burn the installation disc.
Unfortunately, I didn't have any thumb drives. I going to keep a supply of them.
Yep, I remember loading my first Linux distro Slackware from 15 or so Floppy discs. back in the Mid 90's. I now keep a supply of usb sticks handy.Originally posted by Curmudgeon View PostIn perspective:
This is someone who recalls loading Windows and OS/2 from floppies.
Have one that is 64 gbs and use it for ventoy which makes it easy no burning needed just copy the .iso to the stick and away you go.
Good luck.Dave Kubuntu 20.04 Registered Linux User #462608
yea i still have like 40 boot dvd's with various windows and countless linux distros on it ,from YEARS back...
nowadays it seems distros is just getting bigger and bigger▁ ▂ ▄ ▅ ▆ ▇ █ ᄂIПЦX FӨЯ ᄂIFΣ █ ▇ ▆ ▅ ▄ ▂ ▁
- Likes 1
