During the last time I updated the operating system, the actual update didn`t work. As there was no valuable data contained in the installation, I wasn`t forced to update and ended up with a new installation. This hasn`t changed, so I think this time I will again perform a new installation, right? I have prepared a boot stick from the 24.04 iso image. I would like to follow the installation procedure described here. My question is, if in step 5 I have to choose "replace a partition" and select the one with the existing Kubuntu 22.04 (I want to replace 22.04 by 24.04).
Is there anything else I need to know in order not to mess up anything with the windows installation on a different partition? What would you need to know about my system to be able to answer that?
Thanks, Michel
Thanks, Michel
