I have Kubuntu 24.04 install on a new HDD for about a month.
When I boot up, it shows the GRUB menu for 30 s. I can't remember if it did that since day 1 but it has been a while like that.
You know, the usual GRUB menu that looks like this
https://itsfoss.com/access-grub-virtual-machine/
I had this line in the file /etc/default/grub
GRUB_TIMEOUT=0
I tried
GRUB_TIMEOUT=3
and then I run
sudo update-grub
It succeeds and I boot up but
it still shows the menu with a 30 s counter.
GRUB_TIMEOUT_STYLE=menu
so I guess the above makes the menu show up but I tried
GRUB_TIMEOUT_STYLE=hidden
This is the entire file.
I have only added
mitigations=off
In a VM, I experimented a bit with Kubuntu 24.04
I tried
GRUB_TIMEOUT=15
and that works.
I tried
and that works.
Why does it work in the VM but not my real PC?
I always run
sudo update-grub
after making a change to the grub file.
GRUB_TIMEOUT=0
I tried
GRUB_TIMEOUT=3
and then I run
sudo update-grub
I have only added
mitigations=off
# If you change this file, run 'update-grub' afterwards to update # /boot/grub/grub.cfg. # For full documentation of the options in this file, see: # info -f grub -n 'Simple configuration' GRUB_DEFAULT=0 GRUB_TIMEOUT_STYLE=hidden GRUB_TIMEOUT=3 GRUB_DISTRIBUTOR='Kubuntu' GRUB_CMDLINE_LINUX_DEFAULT="quiet splash resume=UUID=50961ac8-9164-434d-8196-1556bb3d1cc0 mitigations=off" GRUB_CMDLINE_LINUX="" # If your computer has multiple operating systems installed, then you # probably want to run os-prober. However, if your computer is a host # for guest OSes installed via LVM or raw disk devices, running # os-prober can cause damage to those guest OSes as it mounts # filesystems to look for things. #GRUB_DISABLE_OS_PROBER=false # Uncomment to enable BadRAM filtering, modify to suit your needs # This works with Linux (no patch required) and with any kernel that obtains # the memory map information from GRUB (GNU Mach, kernel of FreeBSD ...) #GRUB_BADRAM="0x01234567,0xfefefefe,0x89abcdef,0xefefefef" # Uncomment to disable graphical terminal #GRUB_TERMINAL=console # The resolution used on graphical terminal # note that you can use only modes which your graphic card supports via VBE # you can see them in real GRUB with the command `vbeinfo' #GRUB_GFXMODE=640x480 # Uncomment if you don't want GRUB to pass "root=UUID=xxx" parameter to Linux #GRUB_DISABLE_LINUX_UUID=true # Uncomment to disable generation of recovery mode menu entries #GRUB_DISABLE_RECOVERY="true" # Uncomment to get a beep at grub start #GRUB_INIT_TUNE="480 440 1"
I tried
GRUB_TIMEOUT=15
and that works.
I tried
and that works.
I always run
sudo update-grub
