Booting takes for-ever
    Since upgrading to 24.04 my system booting now takes 3-5 minutes
    Way too long, and all I have is a black screen
    Q- How do I enable (or disable) that dos like screen stuff, since tapping [esc] key isn't working ??
    Thanks
    https://www.kubuntuforums.net/forum/...095#post681095
      Also, to help with boot time troubleshooting:
      https://www.kubuntuforums.net/forum/...ystemd-analyze
        Thanks Claydoh.
        I edited the grub file and removed the "quiet splash" and that gave me the list of sevices and linux stuff.
        THEN
        The screen goes blank for about a minute, no keyboard [ESC] Key. I think numlock works and then the boot screen, the one I spent days trying to get work, before the login screen
        Q- Where is the startup log file located, please ?
        Q- Or is it some command line ?
        Thanks
          New Problem
          NO Updates or Upgrades that I did (unless the system suddenly re-activated auto updates and apply them)
          I had a temp power outage a few hours ago.... My PC rebooted. I got to a blank screen. Thought the PC had locked up until I realized the Microwave Clock was reset to 0000
          So [CTRL] + [ALT] + DEL and the screen scrolled shutdown system stuff the rebooted, then screen (not-Quiet mode) scrolled more stuff, Froze for 90 seconds on UUID HDD not found and then black screen again.
          Kubuntu 24.04 officially suxs
          EDIT: Just Found This. This is perfectly explained...
          [HTML]https://medium.com/@julienetienne/kubuntu-kde-wayland-ubuntu-eab189b6be5f[/HTML]
            After reading through a few other KFN issues (Anna Smith - Upgrade from 22.04), I think my screen issues is because its on the nvidia driver. I think I clicked on it, and it changed. I noticed it a few days before my whole system crashed (power outage) and meant to change it back to nouveau the Open source driver.
