USB and Portable drives not appearing in Dolphin
    Hi Again everyone,
    I have been scratching my head regarding browsing USB flash and portable Hard drives.
    Some flash drives will make themselves known, no problems, but others that had files saved on Mac and Windows won't show in Dolphin or any other File manager.
    I have opened up Disk Utility and the drives do appear on there with the option to format - which is what I don't want to as, as I don't want to lose any files.
    Can you advise on how any Portable storage drive can appear on Dolphin or any other File manager, and be able to read any format that is on the drives please.
    Thank you in advance,
    Michael
    Originally posted by EuroNiceguy View Post
    Disk Utility
    What is that?
    Which Kubuntu version?
    Open the drive in Partition Manager and see what file system it is formatted with. You likely need to add something that supports that specific filesystem.
    For example, Exfat, more common nowadays as normal fat32 only supports file sizes up to 4Gb, may still require exfat-utils on 24.04, and maybe 25.04. I think native support in the kernel is there now, but not sure if these tools are still needed for the OS to be able use them.
    But even if it can't access things, Partition Manager will tell you what format is used, and we can go from there.
      The Kubuntu version is 24.04 LTS
      Going into Partition manager, it is coming up as unallocated.
      What do you recommend to do, so the computer can read all formats?
        Unallocated means not formatted or assigned to a file system. That is quite different from not supported or can't read.
        If these drives have files and can be read in Windows or Mac, you may need to get that information from those.
        But let's try one more thing:
        in a terminal, enter:
         df -Th
        This will show us drive info
        Here is mine
        $ df -Th
        Filesystem     Type      Size  Used Avail Use% Mounted on
        tmpfs          tmpfs     3.1G  5.5M  3.1G   1% /run
        efivarfs       efivarfs  150K   78K   68K  54% /sys/firmware/efi/efivars
        /dev/nvme0n1p2 btrfs     932G  443G  481G  48% /
        tmpfs          tmpfs      16G   83M   16G   1% /dev/shm
        tmpfs          tmpfs     5.0M   28K  5.0M   1% /run/lock
        tmpfs          tmpfs      16G  8.8M   16G   1% /tmp
        /dev/nvme0n1p2 btrfs     932G  443G  481G  48% /home
        /dev/nvme0n1p1 vfat      300M   12M  289M   4% /boot/efi
        tmpfs          tmpfs     3.1G  248K  3.1G   1% /run/user/1000
        /dev/sdc1      exfat     240G  1.6G  238G   1% /media/claydoh/tsoofs   <----my USB stick
        Exfat or Fat32 is generally usable on all operating systems, and is perfect for removable media. No permissions or anything to deal with.
        NTFS is Ok as well, I assume it works on Mac.
          Thank you for that,
          This is mine;
          michael@MichaelDesktop:~$ df -Th
          tmpfs tmpfs 2.8G 5.0M 2.8G 1% /run
          /dev/nvme0n1p2 ext4 458G 95G 340G 22% /
          tmpfs tmpfs 14G 8.0K 14G 1% /dev/shm
          tmpfs tmpfs 5.0M 12K 5.0M 1% /run/lock
          efivarfs efivarfs 128K 48K 76K 39% /sys/firmware/efi/efivars
          tmpfs tmpfs 14G 4.0K 14G 1% /tmp
          /dev/sda ext4 1.8T 83G 1.7T 5% /mnt/3cf3cc13-bb6a-4db3-b689-a1a30eef70fd
          /dev/nvme0n1p1 vfat 300M 6.2M 294M 3% /boot/efi
          tmpfs tmpfs 2.8G 2.6M 2.8G 1% /run/user/1000
            Is that correct? Is this the removable drive of ~~ 2Tb?
            it should be /dev/sda{number}. And it is not mounted in a normally used place, either (that itself is not an issue).
            But in any case, that is a Linux file system there anyway (ext4)
              No. That is the second SSD installed in the computer.
              The External drive plugged in did not appear on that list
                Sorry, I offered a command that won't show unmounted partitions
                lsblk -f is better
                  Honestly, to me it just sounds like you need to install hfsplus to read the Mac drive(s) and ntfs-3g for the Windows drive(s). Those are not Linux file systems and support for them is not installed by default.
                  If you are frequently using the same thumb drive with multiple OSs you'd be better off using a file system all of them can read/write like exfat
                    Is that still relevant? macOS stopped using HFS+ when it was replaced with the Apple File System (APFS), released with macOS High Sierra in 2017.​
                      Probably not. I haven't touched a Mac in 2 decades. A brief web search reveals APFS has little support on Linux. Regardless, my suggestion remains the same: Use a file system that is universally supported.
                        Totally!
                        I have access to my mac (running macOS Big Sur (Version 11.7.10), which utilizes APFS) from my Desktop PC (Kubuntu 24.04) via Samba. I can read and write to it.
                          Do you have the remote commands to install these?
                          Thank you everyone for your answers.
                            The commands to install these packages (and their dependencies) in Konsole or a terminal are the same as you would use to install any package:
                            sudo apt update
                            sudo apt install hfsplus ntfs-3g
                              Thank you for this. It did allow access to one of the devices.
