22.04 desktop installed without a problem but it is spontaneously rebooting at the startup screen, how do I fix this?
Spontaneous Rebooting Issue
Welcome.
What exactly do you mean with "startup screen"? The log in screen where you enter your username and password?
And some more information about what you have exactly done could also be helpful to solve your problem (and did Kubuntu 22.04 LTS work before, is this the very first installation - to name something general as further examples).Last edited by Schwarzer Kater; Apr 23, 2024, 11:48 AM.Debian LXQt • Kubuntu • openSUSE KDE • Linux Mint • Windows • macOS
install traditional Firefox script (22.04 +) • install traditional Thunderbird script (24.04 +)
Consider reinstalling? Since you haven't been able to log in or use it at all.
is it rebooting before or after you attempt to log in at the login screen?
No messages or texts, or anything you might think is off (other then the reboot)?
Basic hardware info can be useful.
At this stage, I'd suggest trying the 24.04 release, which is out tomorrow officially. If your hardware is quite recent, this might have a better time on the current stuff.Self-built: Asus PRIME B550M-K/Ryzen 5600GT/32Gb/Intel ARC B580 12Gb/KDE neon
I'd say try a reinstall, using a fresh usb/fresh iso image.Self-built: Asus PRIME B550M-K/Ryzen 5600GT/32Gb/Intel ARC B580 12Gb/KDE neon
What card were you using, and what did you replace it with?Windows no longer obstruct my view.
