HWE stack for upgrade to 22.04.2
    In the last I was made the same question about upgrade HWE stack 22.04 to 22.04.2.​
    In the past, with 20.04, I need run this command:
    sudo apt install --install-recommends linux-generic-hwe-20.04
    Is the same in 22.04 changing 20.04 to 22.04?
    Thanks and regards.
    Yes, you would:
    sudo apt update
    sudo apt install --install-recommends linux-generic-hwe-22.04
    sudo apt autoremove && sudo apt autoclean (optional)
    reboot
      Thank you very much!
