[Closed] Trying to upgrade old emachines DT
    It's been sitting on my shelf and I decided to slap an SSD in it (it had no HD) and install Kubuntu 22.04.
    It's a 64-bit system so I was sure it would install OK.
    After Kubuntu installed and I removed the USB stick, it restarted and I was greeted with gobbledy-gook on the black screen.
    I think that has something to do with NVIDIA not playing nice.
    Diagonal rows of something too small to read.
    However, I don't remember how I got past this when I first installed Mint 17.7 on my current box. (Now running Kubuntu 22.04.)
    I'm thinking maybe I started a live session and installed drivers but I just don't remember.
    This problem sound familiar to anyone?
    What are the specifications of the computer (CPU, GPU, etc.)?
    What does at which point exactly happen when you boot the machine (GRUB, tty, nothing - a screenshot could be helpful…)?
      I sounds like the problems that were helped by setting "nomodeset". I don't know how to do that with 22.04 on your hardware.
        Typically, to set kernel boot options, you must edit the grub configuration file. However, you can do this temporarily for a single boot by entering the grub menu during the boot process. If you do not get to see the grub boot menu after the bios automatically, you may have to press SHIFT key after the bios logo to get into the grub menu:
        Once in the grub menu, select the default kubuntu kernel (...usually the top one if there is more than one), and rather than pressing enter, press E to edit.
        Press the DOWN ARROW until you get to the line that starts with
        linux /boot
        and then press END key to position your cursor at the end of the that line, usually ending with the options “quiet splash”.
        Now you can type in the additional kernel boot option "nomodeset". So your options would then be "quiet splash nomodeset".
        Then press control+X to boot the modified grub entry.
        Important: Setting the boot options this way only applies to a single boot. If you reboot your machine, those settings will be lost unless you make them permanent​ by editing the /etc/default/grub file setting: GRUB_CMDLINE_LINUX_DEFAULT="quiet splash nomodeset"
        After editing the grub default file you will need to update grub so it'll take effect on the next boot:
        sudo update-grub
        cheers,
        bill
        sigpic
        A person who never made a mistake never tried anything new. --Albert Einstein
          Thanks Bill that was very helpful!
            Glad to be of assistance...
            cheers,
            bill
            sigpic
