Multiple error when booting kubuntu 22.04
    I just installed Kubuntu and whenever I boot up, I always got error message even though the boot process is success (I can access my Kubuntu without problem).
    But when I check the error logs using
    journalctl -b -xep err
    I got this error:
    Nov 30 09:23:23 Swift-X kernel: integrity: Problem loading X.509 certificate -65
    Nov 30 09:23:23 Swift-X kernel: mt7921e 0000:03:00.0: ASIC revision: 79610010
    Nov 30 09:23:24 Swift-X kernel: mt7921e 0000:03:00.0: Firmware init done
    Nov 30 09:23:24 Swift-X bluetoothd[801]: Failed to set mode: Blocked through rfkill (0x12)
    Nov 30 09:23:31 Swift-X kernel: ntfs3: Unknown parameter 'windows_names'
    Nov 30 09:23:33 Swift-X wpa_supplicant[865]: bgscan simple: Failed to enable signal strength monitori>​​
    My laptop is Acer Swift X and I dual booted Kubuntu & Windows 11.
    Is it OK if I ignored it? or there's any way to fix the error? Thanks​
