Hi!
After upgrading yesterday evening, a lot of KDE Plasma related packages got upgraded.
Now, the whole Plasma desktop is in a half-broken state. More specifically, desktop is black (I've set up a background picture), right click does not bring up the context menu, the main panel I've setup got reset, the pager (for switching desktop) is a single icon only and crashes if I click on it, and I can not add any plasmoids - trying to add one, the dialog never comes up.
What does work, is the panel menu, any widgets that are there except the pager, I can remove widgets but not add any, changing desktop without the pager, and ALT+F2 to start krunner.
EDIT: Also, there is now a long delay after logging in before Plasma desktop actually finishes loading. Not overly long, something like 30 seconds, but it used to be nearly-instantenous / only a few seconds with an SSD
This is after a reboot, and as a sidenote, updates were done when I was not using a plasma desktop session.
Any idea as to what is the cause, and possible fixes?
I will try with another user account if the desktop is usable.
Thanks!
Thanks!
... I should investigate my logs when I have the time).
