Appearance of conflict between kernel 5.13 and my Graphics Processor
    Hello,
    A few days ago, I upgraded my Kubuntu distro to 21.10 Impish. After rebooting, I saw Grub, then HP's logo, then Kubuntu's one, and then... nothing. I had to use the power button to turn my computer off.
    I then tried to boot using Grub's "advanced options for Ubuntu" line to see what would happen if I used kernel 5.11 instead of 5.13. It was a success: the mouse's pointer appeared, then the logging screen and so on. I then copied the system information:
    Operating System: Kubuntu 21.10
    KDE Plasma Version: 5.22.5
    KDE Frameworks Version: 5.86.0
    Qt Version: 5.15.2
    Kernel Version: 5.11.0-38-generic (64-bit)
    Graphics Platform: X11
    Processors: 2 × AMD A6-9210 RADEON R4, 5 COMPUTE CORES 2C+3G
    Memory: 7.2 Gio of RAM
    Graphics Processor: AMD STONEY
    Next, I tried the "kernel 5.13 (recovery mode)" option. It also worked:
    Qt Version: 5.15.2
    Kernel Version: 5.13.0-20-generic (64-bit)
    Graphics Processor: llvmpipe
    But I noticed that the Graphics Processor was not the same.
    As a last test, I rebooted my computer the normal way. After Kubuntu's logo, again a blank screen. I then managed to connect blindly to my user account and to launch with keyboard shortcuts my SuperTuxKart game, the music of which I finally heard, always without seeing anything. So it's a display problem.
    I don't know if there's a link, but I got some warnings when I upgraded. These warnings also appeared when I did the linux-firmware update yesterday:
    antoine@antoine-HP-Pavilion-Notebook:~$ sudo apt-get upgrade
    Lecture des listes de paquets... Fait
    Construction de l'arbre des dépendances... Fait
    Lecture des informations d'état... Fait
    Calcul de la mise à jour... Fait
    Les paquets suivants seront mis à jour :
    linux-firmware
    1 mis à jour, 0 nouvellement installés, 0 à enlever et 0 non mis à jour.
    Il est nécessaire de prendre 198 Mo dans les archives.
    Après cette opération, 4 096 o d'espace disque supplémentaires seront utilisés.
    Souhaitez-vous continuer ? [O/n] o
    Réception de :1 http://ca.archive.ubuntu.com/ubuntu impish-updates/main amd64 linux-firmware all 1.201.1 [198 MB]
    198 Mo réceptionnés en 2min 12s (1 507 ko/s)
    (Lecture de la base de données... 394522 fichiers et répertoires déjà installés.)
    Préparation du dépaquetage de .../linux-firmware_1.201.1_all.deb ...
    Dépaquetage de linux-firmware (1.201.1) sur (1.201) ...
    Paramétrage de linux-firmware (1.201.1) ...
    update-initramfs: Generating /boot/initrd.img-5.13.0-20-generic
    W: Possible missing firmware /lib/firmware/amdgpu/vangogh_gpu_info.bin for module amdgpu
    W: Possible missing firmware /lib/firmware/amdgpu/aldebaran_ta.bin for module amdgpu
    W: Possible missing firmware /lib/firmware/amdgpu/aldebaran_sos.bin for module amdgpu
    W: Possible missing firmware /lib/firmware/amdgpu/aldebaran_rlc.bin for module amdgpu
    W: Possible missing firmware /lib/firmware/amdgpu/aldebaran_mec2.bin for module amdgpu
    W: Possible missing firmware /lib/firmware/amdgpu/aldebaran_mec.bin for module amdgpu
    W: Possible missing firmware /lib/firmware/amdgpu/aldebaran_sdma.bin for module amdgpu
    W: Possible missing firmware /lib/firmware/amdgpu/sienna_cichlid_mes.bin for module amdgpu
    W: Possible missing firmware /lib/firmware/amdgpu/navi10_mes.bin for module amdgpu
    W: Possible missing firmware /lib/firmware/amdgpu/aldebaran_vcn.bin for module amdgpu
    W: Possible missing firmware /lib/firmware/amdgpu/aldebaran_smc.bin for module amdgpu
    update-initramfs: Generating /boot/initrd.img-5.11.0-38-generic
    update-initramfs: Generating /boot/initrd.img-5.11.0-37-generic
    update-initramfs: Generating /boot/initrd.img-5.11.0-36-generic
    In the reported bugs, I found this one which may have a link with mine:
    Bug #1944397 “HDMI does not display anything with Impish RPi des...” : Bugs : linux-raspi package : Ubuntu
    Is there something I should do next?
    Thanks
    Recovery mode working would be expected. It's exactly for the situation you describe.
    The "missing firmware" messages are usually harmless. It's more likely that you have not installed all the kernel modules. If you do have all the modules installed, you can search for and find the missing firmwares sometimes, but you may just have to stay with the older kernel until an update comes out that fixes it. Just make the 5.11 kernel the default in grub and test the newer kernel after every update until it works.
    To check your modules to see if any are missing, you can compare the 5.11 to the 5.13 kernel. Try reviewing the output of:
    dpkg -l | grep 5.11.0-38
    to:
    dpkg -l |grep 5.13.0-20
      Here's where the firmware is stored in case you need it or just want to try:
      https://git.kernel.org/pub/scm/linux...it/tree/amdgpu
      Bonne chance.
        Try using the correct apt command:
        sudo apt full-upgrade
        You might be missing some updates.
        Also check the grub menu and see if you have more than one version of 5.13
        When you use Recovery Mode, you do end up using a generic style driver
        lvvmpipe is normal for this mode
        Also, I agree with Oshunluvr here on the firmware warnings. The only time you would need to worry is if you saw your graphics card there: Stony isn't one of them so you are good here.
          Thanks a lot
          Here's the result of the suggested comparison:
          antoine@antoine-HP-Pavilion-Notebook:~$ dpkg -l | grep 5.11.0-38
          ii linux-headers-5.11.0-38 5.11.0-38.42 all Header files related to Linux kernel version 5.11.0
          ii linux-headers-5.11.0-38-generic 5.11.0-38.42 amd64 Linux kernel headers for version 5.11.0 on 64 bit x86 SMP
          ii linux-image-5.11.0-38-generic 5.11.0-38.42 amd64 Signed kernel image generic
          ii linux-modules-5.11.0-38-generic 5.11.0-38.42 amd64 Linux kernel extra modules for version 5.11.0 on 64 bit x86 SMP
          ii linux-modules-extra-5.11.0-38-generic 5.11.0-38.42 amd64 Linux kernel extra modules for version 5.11.0 on 64 bit x86 SMP
          antoine@antoine-HP-Pavilion-Notebook:~$ dpkg -l |grep 5.13.0-20
          ii linux-headers-5.13.0-20 5.13.0-20.20 all Header files related to Linux kernel version 5.13.0
          ii linux-headers-5.13.0-20-generic 5.13.0-20.20 amd64 Linux kernel headers for version 5.13.0 on 64 bit x86 SMP
          ii linux-image-5.13.0-20-generic 5.13.0-20.20 amd64 Signed kernel image generic
          ii linux-libc-dev:amd64 5.13.0-20.20 amd64 Linux Kernel Headers for development
          ii linux-modules-5.13.0-20-generic 5.13.0-20.20 amd64 Linux kernel extra modules for version 5.13.0 on 64 bit x86 SMP
          ii linux-modules-extra-5.13.0-20-generic 5.13.0-20.20 amd64 Linux kernel extra modules for version 5.13.0 on 64 bit x86 SMP
          ii linux-tools-common 5.13.0-20.20 all Linux kernel version specific tools for version 5.13.0
          Kernel 5.13 has more modules than 5.11, so it doesn't seem to have missing modules.
          Also, sudo apt full-upgrade indicated that I have all updates. (but thanks, I will use this command from now on)
          And double-checking the grub menu confirmed there's only 5.13.0-20-generic and 5.13.0-20-generic (recovery mode)
          So I made 5.11 default and I will wait until a good update comes out.
          Thanks again
            Antoine, I have a similar problem with an Acer notebook Nitro-5 : blank screen after boot.
            I find a solution in the Ubuntu forum.
            I've modified the grub like this:
            in configuration file /etc/default/grub , add "nomodeset" at the end of the line GRUB_CMDLINE_LINUX_DEFAULT
            like this: GRUB_CMDLINE_LINUX_DEFAULT="quiet splash nomodeset"
            and update grub: sudo update-grub
            and reboot
              Thank you didier31 for this solution. It's a pity that I forgot to activate Email notification. I saw your message only today, after upgrading to Kubuntu 22.04, which solved my problem.
