Hi y'all!
This is a fresh install on an old laptop (a Dell e1705) I just upgraded with 4GB of new ram and a used T7400 (64 bit) processor. Except for plasma, everything seems nicely snappy. Plasma is not. Directly after install kwin crashed - kwin crashes without apparent cause, and plasma apps, like network monitor just stop sometimes. Just changing the desktop image takes ten minutes or more, with plasma running near 100% from core to core as the images slowly load and selection slowly registers with the software. Like I said, the system disables opengl and I can run okay on xrender, but that has no affect on plasma. Every time I re-enable opengl, either opengl 2 or opengl 3, kwin immediately crashes (no back trace available) and it's disabled again. Firefox works great, as does Muon, and vlc playing x264 vids, but Discover appears broken. Win xp (32 bit) seems to run perfectly, though I honestly didn't stay very long.
Oh, I replaced the screen a few years ago with a uxga? higher resolution screen than the original (our backlight went out and it was relatively cheap). We've been running 16.04 (actually, now that I think of it, I think it was 14.04) on this machine - it's my wife's.
I've been using Kubuntu for quite a few years now, and I should be better at this than I am. For some reason, I just don't seem to retain the technical stuff anymore. Any help will be appreciated.
I should also say, the system is fully up to date.
Prepare for LOGS!!!
https://www.kubuntuforums.net/attach...1&d=1612705841
There's a lot to go through here - sorry about that - but I don't really know what might be important. I copied these after re-enabling opengl with both opengl 3 and opengl2 successively.
Thank you.
Prepare for LOGS!!!
Thank you.
