Yesterday I updated my laptop from Ubuntu 24.04.5 to 26.04.1 with sudo do-release-upgrade command. After the upgrade succeeded and I rebooted the machine I tried to update the software packages with the command sudo apt update && sudo apt upgrade. After this command completed I got the error messages (see below). My machine has 2 nvme ssd disk. One nvme1 ssd disk with Ubuntu 24.04.5 succesfully installed before the mentioned upgrade. On nvme2 ssd disk I have Ubuntu studio 26.04.1 en MX linux 2.5 installed. Before the uprade Ubuntu 24.05, Ubuntu studio 26.04.1 and MX linux worked fine. To boot one of these OSs I use grub2 installed on Ubuntu Studio 26.04.1 on my nvme2 ssd disk. After the upgrade I have mentionted, I found out that there is also a grub2 installation on nvme1 ssd disk of Ubuntu 26.04.1 installation (on /dev/nvme0n1p1 for /boot/efi). Ubuntu 26.04.1 uses /dev/nvme0n1p5 for / and /dev/nvme0n1p6 for /home.
I have also include /boot/grub/grub.cfg.new (for its text see below), because it is mentioned in the error messages (see also below). If I run the command sudo grub-mkconfig -o /boot/grub/grub.cfg on my boot Ubuntu 26.04.1 I get the same errors.
How can I fix this problem, because now I can not update any new software packages?
<< *** BEGIN Error messages *** >>
Summary: Upgrading: 12, Installing: 0, Removing: 1, Not Upgrading: 1 10 not fully installed or removed. 12 standard LTS security updates Download size: 3.606 kB / 4.254 kB Freed space: 15,0 MB
Continue? [Y/n] y Get:1 http://archive.ubuntu.com/ubuntu resolute-updates/main amd64 libsqlite3-dev amd64 3.46.1-9ubuntu0.3 [932 kB] Get:2 http://archive.ubuntu.com/ubuntu resolute-updates/main amd64 libsqlite3-0 amd64 3.46.1-9ubuntu0.3 [720 kB] Get:3 http://archive.ubuntu.com/ubuntu resolute-updates/main i386 libsqlite3-0 i386 3.46.1-9ubuntu0.3 [794 kB] Get:4 http://archive.ubuntu.com/ubuntu resolute-updates/main amd64 python3-cryptography amd64 46.0.5-1ubuntu2.2 [1.160 kB] Fetched 3.606 kB in 1s (3.310 kB/s)
dpkg: warning: files list file for package 'winboat' missing; assuming package has no files currently installed (Reading database… 1110464 files and directories currently installed.) Removing linux-image-6.8.0-1061-nvidia-lowlatency (6.8.0-1061.64.1)… /etc/kernel/postrm.d/initramfs-tools: update-initramfs: Deleting /boot/initrd.img-6.8.0-1061-nvidia-lowlatency /etc/kernel/postrm.d/kdump-tools: kdump-tools: Removing kdump tracking files for kernel version: 6.8.0-1061-nvidia-lowlatency /etc/kernel/postrm.d/zz-update-grub: Sourcing file /etc/default/grub' Sourcing file /etc/default/grub.d/99-lowlatency.cfg' Sourcing file `/etc/default/grub.d/kdump-tools.cfg' Generating grub configuration file ... Found linux image: /boot/vmlinuz-7.0.0-1016-nvidia Found initrd image: /boot/initrd.img-7.0.0-1016-nvidia Found linux image: /boot/vmlinuz-7.0.0-31-generic Found initrd image: /boot/initrd.img-7.0.0-31-generic Found linux image: /boot/vmlinuz-6.8.0-1062-nvidia-lowlatency Found initrd image: /boot/initrd.img-6.8.0-1062-nvidia-lowlatency Found linux image: /boot/vmlinuz-6.8.0-139-generic Found initrd image: /boot/initrd.img-6.8.0-139-generic Found linux image: /boot/vmlinuz-6.8.0-138-lowlatency Found initrd image: /boot/initrd.img-6.8.0-138-lowlatency Found linux image: /boot/vmlinuz-7.0.0-1016-nvidia Found initrd image: /boot/initrd.img-7.0.0-1016-nvidia Found linux image: /boot/vmlinuz-7.0.0-31-generic Found initrd image: /boot/initrd.img-7.0.0-31-generic Found linux image: /boot/vmlinuz-6.8.0-1062-nvidia-lowlatency Found initrd image: /boot/initrd.img-6.8.0-1062-nvidia-lowlatency Found linux image: /boot/vmlinuz-6.8.0-139-generic Found initrd image: /boot/initrd.img-6.8.0-139-generic Found linux image: /boot/vmlinuz-6.8.0-138-lowlatency Found initrd image: /boot/initrd.img-6.8.0-138-lowlatency Warning: os-prober will be executed to detect other bootable partitions. Its output will be used to detect bootable binaries on them and create new boot entries. Found Ubuntu 26.04.1 LTS (26.04) on /dev/nvme0n1p3 Found MX 25.2 Infinity (25.2) on /dev/nvme0n1p6 Found Windows Boot Manager on /dev/nvme1n1p1@/EFI/Microsoft/Boot/bootmgfw.efi Adding boot menu entry for UEFI Firmware Settings ... Found linux image: /boot/vmlinuz-7.0.0-1016-nvidia Found initrd image: /boot/initrd.img-7.0.0-1016-nvidia Found linux image: /boot/vmlinuz-7.0.0-31-generic Found initrd image: /boot/initrd.img-7.0.0-31-generic Found linux image: /boot/vmlinuz-6.8.0-1062-nvidia-lowlatency Found initrd image: /boot/initrd.img-6.8.0-1062-nvidia-lowlatency Found linux image: /boot/vmlinuz-6.8.0-139-generic Found initrd image: /boot/initrd.img-6.8.0-139-generic Found linux image: /boot/vmlinuz-6.8.0-138-lowlatency Found initrd image: /boot/initrd.img-6.8.0-138-lowlatency error: out of memory. error: syntax error. error: Incorrect command. error: syntax error. Syntax error at line 1910 Syntax errors are detected in generated GRUB config file. Ensure that there are no errors in /etc/default/grub and /etc/grub.d/* files or please file a bug report with /boot/grub/grub.cfg.new file attached. run-parts: /etc/kernel/postrm.d/zz-update-grub exited with return code 1 dpkg: error processing package linux-image-6.8.0-1061-nvidia-lowlatency (--remove): old linux-image-6.8.0-1061-nvidia-lowlatency package postrm maintainer script subprocess failed with exit status 1 dpkg: too many errors, stopping Errors were encountered while processing: linux-image-6.8.0-1061-nvidia-lowlatency Processing was halted because there were too many errors.
<< *** END Error meassages *** >>
<< *** BEGIN text of /boot/grub/grub.cfg.new *** >>>
DO NOT EDIT THIS FILE
It is automatically generated by grub-mkconfig using templates
from /etc/grub.d and settings from /etc/default/grub
BEGIN /etc/grub.d/00_header
if [ -s $prefix/grubenv ]; then set have_grubenv=true load_env fi
if [ "${env_block}" ] ; then set env_block="(${root})${env_block}" export env_block load_env -f "${env_block}" fi
if [ "${initrdfail}" = 2 ]; then set initrdfail= elif [ "${initrdfail}" = 1 ]; then set next_entry="${prev_entry}" set prev_entry= save_env prev_entry if [ "${next_entry}" ]; then set initrdfail=2 fi fi if [ "${next_entry}" ] ; then set default="${next_entry}" set next_entry= if [ "${env_block}" ] ; then save_env -f "${env_block}" next_entry else save_env next_entry fi set boot_once=true else set default="0" fi
if [ x"${feature_menuentry_id}" = xy ]; then menuentry_id_option="--id" else menuentry_id_option="" fi
export menuentry_id_option
if [ "${prev_saved_entry}" ]; then set saved_entry="${prev_saved_entry}" save_env saved_entry set prev_saved_entry= save_env prev_saved_entry set boot_once=true fi
function savedefault { if [ -z "${boot_once}" ]; then saved_entry="${chosen}" if [ "${env_block}" ] ; then save_env -f "${env_block}" saved_entry else save_env saved_entry fi
fi } function initrdfail { if [ -n "${have_grubenv}" ]; then if [ -n "${partuuid}" ]; then if [ -z "${initrdfail}" ]; then set initrdfail=1 if [ -n "${boot_once}" ]; then set prev_entry="${default}" save_env prev_entry fi fi save_env initrdfail fi; fi } function recordfail { set recordfail=1 if [ -n "${have_grubenv}" ]; then if [ -z "${boot_once}" ]; then save_env recordfail; fi; fi } function load_video { if [ x$grub_platform = xefi ]; then insmod efi_gop elif [ x$feature_all_video_module = xy ]; then insmod all_video else insmod efi_gop insmod ieee1275_fb insmod vbe insmod vga insmod video_bochs insmod video_cirrus fi }
if [ x$feature_default_font_path = xy ] ; then font=unicode else insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root 1ee56e03-e339-4319-b518-8402e7279820 font="/usr/share/grub/unicode.pf2" fi
if loadfont $font ; then set gfxmode=auto load_video insmod gfxterm set locale_dir=$prefix/locale set lang=en_US insmod gettext fi terminal_output gfxterm if [ "${recordfail}" = 1 ] ; then set timeout=30 else if [ x$feature_timeout_style = xy ] ; then set timeout_style=hidden set timeout=0 Fallback hidden-timeout code in case the timeout_style feature is
unavailable.
elif sleep --interruptible 0 ; then set timeout=0 fi fi END /etc/grub.d/00_header
BEGIN /etc/grub.d/05_debian_theme
set menu_color_normal=white/black set menu_color_highlight=black/light-gray END /etc/grub.d/05_debian_theme
BEGIN /etc/grub.d/10_linux_proxy
if [ "${recordfail}" != 1 ]; then if [ -e ${prefix}/gfxblacklist.txt ]; then if [ ${grub_platform} != pc ]; then set linux_gfx_mode=keep elif hwmatch ${prefix}/gfxblacklist.txt 3; then if [ ${match} = 0 ]; then set linux_gfx_mode=keep else set linux_gfx_mode=text fi else set linux_gfx_mode=text fi else set linux_gfx_mode=keep fi else set linux_gfx_mode=text fi export linux_gfx_mode END /etc/grub.d/10_linux_proxy
BEGIN /etc/grub.d/12_linux_proxy
menuentry "Ubuntu, with Linux 7.0.0-1016-nvidia" --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-7.0.0-1016-nvidia-advanced-1ee56e03-e339-4319-b518-8402e7279820' { recordfail load_video set gfxpayload=$linux_gfx_mode insmod gzio if [ x$grub_platform = xxen ]; then insmod xzio; insmod lzopio; fi insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root 1ee56e03-e339-4319-b518-8402e7279820 echo 'Loading Linux 7.0.0-1016-nvidia ...' linux /boot/vmlinuz-7.0.0-1016-nvidia root=UUID=1ee56e03-e339-4319-b518-8402e7279820 ro quiet splash preempt=full rcu_nocbs=all crashkernel=2G-4G:320M,4G-32G:512M,32G-64G:1024M,64G-128G:2048M,128G-:4096M echo 'Loading initial ramdisk ...' initrd /boot/initrd.img-7.0.0-1016-nvidia } menuentry "Ubuntu, with Linux 7.0.0-1016-nvidia (recovery mode)" --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-7.0.0-1016-nvidia-recovery-1ee56e03-e339-4319-b518-8402e7279820' { recordfail load_video insmod gzio if [ x$grub_platform = xxen ]; then insmod xzio; insmod lzopio; fi insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root 1ee56e03-e339-4319-b518-8402e7279820 echo 'Loading Linux 7.0.0-1016-nvidia ...' linux /boot/vmlinuz-7.0.0-1016-nvidia root=UUID=1ee56e03-e339-4319-b518-8402e7279820 ro recovery nomodeset dis_ucode_ldr echo 'Loading initial ramdisk ...' initrd /boot/initrd.img-7.0.0-1016-nvidia } menuentry "Ubuntu, with Linux 7.0.0-31-generic" --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-7.0.0-31-generic-advanced-1ee56e03-e339-4319-b518-8402e7279820' { recordfail load_video set gfxpayload=$linux_gfx_mode insmod gzio if [ x$grub_platform = xxen ]; then insmod xzio; insmod lzopio; fi insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root 1ee56e03-e339-4319-b518-8402e7279820 echo 'Loading Linux 7.0.0-31-generic ...' linux /boot/vmlinuz-7.0.0-31-generic root=UUID=1ee56e03-e339-4319-b518-8402e7279820 ro quiet splash preempt=full rcu_nocbs=all crashkernel=2G-4G:320M,4G-32G:512M,32G-64G:1024M,64G-128G:2048M,128G-:4096M echo 'Loading initial ramdisk ...' initrd /boot/initrd.img-7.0.0-31-generic } menuentry "Ubuntu, with Linux 7.0.0-31-generic (recovery mode)" --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-7.0.0-31-generic-recovery-1ee56e03-e339-4319-b518-8402e7279820' { recordfail load_video insmod gzio if [ x$grub_platform = xxen ]; then insmod xzio; insmod lzopio; fi insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root 1ee56e03-e339-4319-b518-8402e7279820 echo 'Loading Linux 7.0.0-31-generic ...' linux /boot/vmlinuz-7.0.0-31-generic root=UUID=1ee56e03-e339-4319-b518-8402e7279820 ro recovery nomodeset dis_ucode_ldr echo 'Loading initial ramdisk ...' initrd /boot/initrd.img-7.0.0-31-generic } menuentry "Ubuntu, with Linux 6.8.0-1062-nvidia-lowlatency" --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-6.8.0-1062-nvidia-lowlatency-advanced-1ee56e03-e339-4319-b518-8402e7279820' { recordfail load_video set gfxpayload=$linux_gfx_mode insmod gzio if [ x$grub_platform = xxen ]; then insmod xzio; insmod lzopio; fi insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root 1ee56e03-e339-4319-b518-8402e7279820 echo 'Loading Linux 6.8.0-1062-nvidia-lowlatency ...' linux /boot/vmlinuz-6.8.0-1062-nvidia-lowlatency root=UUID=1ee56e03-e339-4319-b518-8402e7279820 ro quiet splash preempt=full rcu_nocbs=all crashkernel=2G-4G:320M,4G-32G:512M,32G-64G:1024M,64G-128G:2048M,128G-:4096M echo 'Loading initial ramdisk ...' initrd /boot/initrd.img-6.8.0-1062-nvidia-lowlatency } menuentry "Ubuntu, with Linux 6.8.0-1062-nvidia-lowlatency (recovery mode)" --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-6.8.0-1062-nvidia-lowlatency-recovery-1ee56e03-e339-4319-b518-8402e7279820' { recordfail load_video insmod gzio if [ x$grub_platform = xxen ]; then insmod xzio; insmod lzopio; fi insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root 1ee56e03-e339-4319-b518-8402e7279820 echo 'Loading Linux 6.8.0-1062-nvidia-lowlatency ...' linux /boot/vmlinuz-6.8.0-1062-nvidia-lowlatency root=UUID=1ee56e03-e339-4319-b518-8402e7279820 ro recovery nomodeset dis_ucode_ldr echo 'Loading initial ramdisk ...' initrd /boot/initrd.img-6.8.0-1062-nvidia-lowlatency } menuentry "Ubuntu, with Linux 6.8.0-139-generic" --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-6.8.0-139-generic-advanced-1ee56e03-e339-4319-b518-8402e7279820' { recordfail load_video set gfxpayload=$linux_gfx_mode insmod gzio if [ x$grub_platform = xxen ]; then insmod xzio; insmod lzopio; fi insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root 1ee56e03-e339-4319-b518-8402e7279820 echo 'Loading Linux 6.8.0-139-generic ...' linux /boot/vmlinuz-6.8.0-139-generic root=UUID=1ee56e03-e339-4319-b518-8402e7279820 ro quiet splash preempt=full rcu_nocbs=all crashkernel=2G-4G:320M,4G-32G:512M,32G-64G:1024M,64G-128G:2048M,128G-:4096M echo 'Loading initial ramdisk ...' initrd /boot/initrd.img-6.8.0-139-generic } menuentry "Ubuntu, with Linux 6.8.0-139-generic (recovery mode)" --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-6.8.0-139-generic-recovery-1ee56e03-e339-4319-b518-8402e7279820' { recordfail load_video insmod gzio if [ x$grub_platform = xxen ]; then insmod xzio; insmod lzopio; fi insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root 1ee56e03-e339-4319-b518-8402e7279820 echo 'Loading Linux 6.8.0-139-generic ...' linux /boot/vmlinuz-6.8.0-139-generic root=UUID=1ee56e03-e339-4319-b518-8402e7279820 ro recovery nomodeset dis_ucode_ldr echo 'Loading initial ramdisk ...' initrd /boot/initrd.img-6.8.0-139-generic } menuentry "Ubuntu, with Linux 6.8.0-138-lowlatency" --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-6.8.0-138-lowlatency-advanced-1ee56e03-e339-4319-b518-8402e7279820' { recordfail load_video set gfxpayload=$linux_gfx_mode insmod gzio if [ x$grub_platform = xxen ]; then insmod xzio; insmod lzopio; fi insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root 1ee56e03-e339-4319-b518-8402e7279820 echo 'Loading Linux 6.8.0-138-lowlatency ...' linux /boot/vmlinuz-6.8.0-138-lowlatency root=UUID=1ee56e03-e339-4319-b518-8402e7279820 ro quiet splash preempt=full rcu_nocbs=all crashkernel=2G-4G:320M,4G-32G:512M,32G-64G:1024M,64G-128G:2048M,128G-:4096M echo 'Loading initial ramdisk ...' initrd /boot/initrd.img-6.8.0-138-lowlatency } menuentry "Ubuntu, with Linux 6.8.0-138-lowlatency (recovery mode)" --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-6.8.0-138-lowlatency-recovery-1ee56e03-e339-4319-b518-8402e7279820' { recordfail load_video insmod gzio if [ x$grub_platform = xxen ]; then insmod xzio; insmod lzopio; fi insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root 1ee56e03-e339-4319-b518-8402e7279820 echo 'Loading Linux 6.8.0-138-lowlatency ...' linux /boot/vmlinuz-6.8.0-138-lowlatency root=UUID=1ee56e03-e339-4319-b518-8402e7279820 ro recovery nomodeset dis_ucode_ldr echo 'Loading initial ramdisk ...' initrd /boot/initrd.img-6.8.0-138-lowlatency } END /etc/grub.d/12_linux_proxy
BEGIN /etc/grub.d/13_linux_zfs
END /etc/grub.d/13_linux_zfs
BEGIN /etc/grub.d/20_linux_xen
END /etc/grub.d/20_linux_xen
BEGIN /etc/grub.d/25_bli
if [ "$grub_platform" = "efi" ]; then insmod bli fi END /etc/grub.d/25_bli
BEGIN /etc/grub.d/30_os-prober_proxy
submenu "Advanced options for Ubuntu 26.04.1 LTS (26.04) (on /dev/nvme1n1p3)"{ menuentry "Ubuntu, with Linux 7.0.0-31-generic (on /dev/nvme1n1p3)" --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-7.0.0-31-generic--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/vmlinuz-7.0.0-31-generic root=UUID=bd830e84-8c65-4850-bb7a-01fa779c0d99 ro quiet splash preempt=full threadirqs rcu_nocbs=all initrd /boot/initrd.img-7.0.0-31-generic } } submenu "Advanced options for MX 25.2 Infinity (25.2) (on /dev/nvme1n1p6)"{ menuentry "MX 25.2 Infinity, with Linux 6.12.107+deb13-amd64 (on /dev/nvme1n1p6)" --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-6.12.107+deb13-amd64--bba7e528-a914-44dc-9309-a4cabc64d66b' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bba7e528-a914-44dc-9309-a4cabc64d66b linux /boot/vmlinuz-6.12.107+deb13-amd64 root=UUID=bba7e528-a914-44dc-9309-a4cabc64d66b ro quiet splash initrd /boot/initrd.img-6.12.107+deb13-amd64 } } menuentry "Ubuntu 26.04.1 LTS (26.04) (on /dev/nvme0n1p3)" --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-simple-bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/vmlinuz-7.0.0-31-generic root=UUID=bd830e84-8c65-4850-bb7a-01fa779c0d99 ro quiet splash preempt=full threadirqs rcu_nocbs=all initrd /boot/initrd.img-7.0.0-31-generic } submenu "Advanced options for Ubuntu 26.04.1 LTS (26.04) (on /dev/nvme0n1p3)"{ menuentry "Memory test (mt86+x64)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 } menuentry "Memory test (mt86+x64, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 console=ttyS0,115200 } menuentry "Memory test (mt86+ia32)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 } menuentry "Memory test (mt86+ia32, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 console=ttyS0,115200 } menuentry "Memory test (mt86+x64)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 } menuentry "Memory test (mt86+x64, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 console=ttyS0,115200 } menuentry "Memory test (mt86+ia32)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 } menuentry "Memory test (mt86+ia32, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 console=ttyS0,115200 } menuentry "Memory test (mt86+x64)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 } menuentry "Memory test (mt86+x64, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 console=ttyS0,115200 } menuentry "Memory test (mt86+ia32)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 } menuentry "Memory test (mt86+ia32, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 console=ttyS0,115200 } menuentry "Memory test (mt86+x64)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 } menuentry "Memory test (mt86+x64, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 console=ttyS0,115200 } menuentry "Memory test (mt86+ia32)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 } menuentry "Memory test (mt86+ia32, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 console=ttyS0,115200 } menuentry "Memory test (mt86+x64)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 } menuentry "Memory test (mt86+x64, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 console=ttyS0,115200 } menuentry "Memory test (mt86+ia32)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 } menuentry "Memory test (mt86+ia32, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 console=ttyS0,115200 } menuentry "Memory test (mt86+x64)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 } menuentry "Memory test (mt86+x64, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 console=ttyS0,115200 } menuentry "Memory test (mt86+ia32)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 } menuentry "Memory test (mt86+ia32, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 console=ttyS0,115200 } menuentry "Memory test (mt86+x64)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 } menuentry "Memory test (mt86+x64, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 console=ttyS0,115200 } menuentry "Memory test (mt86+ia32)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 } menuentry "Memory test (mt86+ia32, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 console=ttyS0,115200 } menuentry "Memory test (mt86+x64)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 } menuentry "Memory test (mt86+x64, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 console=ttyS0,115200 } menuentry "Memory test (mt86+ia32)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 } menuentry "Memory test (mt86+ia32, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 console=ttyS0,115200 } menuentry "Memory test (mt86+x64)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 } menuentry "Memory test (mt86+x64, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 console=ttyS0,115200 } menuentry "Memory test (mt86+ia32)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 } menuentry "Memory test (mt86+ia32, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 console=ttyS0,115200 } menuentry "Memory test (mt86+x64)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 } menuentry "Memory test (mt86+x64, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 console=ttyS0,115200 } menuentry "Memory test (mt86+ia32)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 } menuentry "Memory test (mt86+ia32, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 console=ttyS0,115200 } menuentry "Memory test (mt86+x64)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 } menuentry "Memory test (mt86+x64, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 console=ttyS0,115200 } menuentry "Memory test (mt86+ia32)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 } menuentry "Memory test (mt86+ia32, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 console=ttyS0,115200 } menuentry "Memory test (mt86+x64)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 } menuentry "Memory test (mt86+x64, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 console=ttyS0,115200 } menuentry "Memory test (mt86+ia32)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 } menuentry "Memory test (mt86+ia32, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 console=ttyS0,115200 } menuentry "Memory test (mt86+x64)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 } menuentry "Memory test (mt86+x64, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 console=ttyS0,115200 } menuentry "Memory test (mt86+ia32)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 } menuentry "Memory test (mt86+ia32, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 console=ttyS0,115200 } menuentry "Memory test (mt86+x64)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 } menuentry "Memory test (mt86+x64, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 console=ttyS0,115200 } menuentry "Memory test (mt86+ia32)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 } menuentry "Memory test (mt86+ia32, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 console=ttyS0,115200 } menuentry "Memory test (mt86+x64)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 } menuentry "Memory test (mt86+x64, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 console=ttyS0,115200 } menuentry "Memory test (mt86+ia32)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 } menuentry "Memory test (mt86+ia32, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 console=ttyS0,115200 } menuentry "Memory test (mt86+x64)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 } menuentry "Memory test (mt86+x64, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 console=ttyS0,115200 } menuentry "Memory test (mt86+ia32)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 } menuentry "Memory test (mt86+ia32, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 console=ttyS0,115200 } menuentry "Memory test (mt86+x64)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 } menuentry "Memory test (mt86+x64, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 console=ttyS0,115200 } menuentry "Memory test (mt86+ia32)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 } menuentry "Memory test (mt86+ia32, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 console=ttyS0,115200 } menuentry "Memory test (mt86+x64)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 } menuentry "Memory test (mt86+x64, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 console=ttyS0,115200 } menuentry "Memory test (mt86+ia32)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 } menuentry "Memory test (mt86+ia32, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 console=ttyS0,115200 } menuentry "Memory test (mt86+x64)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 } menuentry "Memory test (mt86+x64, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 console=ttyS0,115200 } menuentry "Memory test (mt86+ia32)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 } menuentry "Memory test (mt86+ia32, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 console=ttyS0,115200 } menuentry "Memory test (mt86+x64)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 } menuentry "Memory test (mt86+x64, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 console=ttyS0,115200 } menuentry "Memory test (mt86+ia32)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 } menuentry "Memory test (mt86+ia32, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 console=ttyS0,115200 } menuentry "Memory test (mt86+x64)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 } menuentry "Memory test (mt86+x64, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 console=ttyS0,115200 } menuentry "Memory test (mt86+ia32)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 } menuentry "Memory test (mt86+ia32, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 console=ttyS0,115200 } menuentry "Memory test (mt86+x64)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 } menuentry "Memory test (mt86+x64, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 console=ttyS0,115200 } menuentry "Memory test (mt86+ia32)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 } menuentry "Memory test (mt86+ia32, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 console=ttyS0,115200 } menuentry "Memory test (mt86+x64)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 } menuentry "Memory test (mt86+x64, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 console=ttyS0,115200 } menuentry "Memory test (mt86+ia32)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 } menuentry "Memory test (mt86+ia32, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 console=ttyS0,115200 } menuentry "Memory test (mt86+x64)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 } menuentry "Memory test (mt86+x64, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 console=ttyS0,115200 } menuentry "Memory test (mt86+ia32)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 } menuentry "Memory test (mt86+ia32, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 console=ttyS0,115200 } menuentry "Memory test (mt86+x64)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 } menuentry "Memory test (mt86+x64, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 console=ttyS0,115200 } menuentry "Memory test (mt86+ia32)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 } menuentry "Memory test (mt86+ia32, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 console=ttyS0,115200 } menuentry "Memory test (mt86+x64)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 } menuentry "Memory test (mt86+x64, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 console=ttyS0,115200 } menuentry "Memory test (mt86+ia32)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 } menuentry "Memory test (mt86+ia32, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 console=ttyS0,115200 } menuentry "Memory test (mt86+x64)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 } menuentry "Memory test (mt86+x64, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 console=ttyS0,115200 } menuentry "Memory test (mt86+ia32)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 } menuentry "Memory test (mt86+ia32, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 console=ttyS0,115200 } menuentry "Memory test (mt86+x64)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 } menuentry "Memory test (mt86+x64, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 console=ttyS0,115200 } menuentry "Memory test (mt86+ia32)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 } menuentry "Memory test (mt86+ia32, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 console=ttyS0,115200 } menuentry "Memory test (mt86+x64)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 } menuentry "Memory test (mt86+x64, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 console=ttyS0,115200 } menuentry "Memory test (mt86+ia32)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 } menuentry "Memory test (mt86+ia32, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 console=ttyS0,115200 } menuentry "Memory test (mt86+x64)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 } menuentry "Memory test (mt86+x64, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 console=ttyS0,115200 } menuentry "Memory test (mt86+ia32)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 } menuentry "Memory test (mt86+ia32, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 console=ttyS0,115200 } menuentry "Memory test (mt86+x64)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 } menuentry "Memory test (mt86+x64, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 console=ttyS0,115200 } menuentry "Memory test (mt86+ia32)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 } menuentry "Memory test (mt86+ia32, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 console=ttyS0,115200 } menuentry "Memory test (mt86+x64)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 } menuentry "Memory test (mt86+x64, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 console=ttyS0,115200 } menuentry "Memory test (mt86+ia32)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 } menuentry "Memory test (mt86+ia32, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 console=ttyS0,115200 } menuentry "Memory test (mt86+x64)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 } menuentry "Memory test (mt86+x64, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 console=ttyS0,115200 } menuentry "Memory test (mt86+ia32)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 } menuentry "Memory test (mt86+ia32, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 console=ttyS0,115200 } menuentry "Memory test (mt86+x64)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 } menuentry "Memory test (mt86+x64, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 console=ttyS0,115200 } menuentry "Memory test (mt86+ia32)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 } menuentry "Memory test (mt86+ia32, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 console=ttyS0,115200 } menuentry "Memory test (mt86+x64)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 } menuentry "Memory test (mt86+x64, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 console=ttyS0,115200 } menuentry "Memory test (mt86+ia32)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 } menuentry "Memory test (mt86+ia32, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 console=ttyS0,115200 } menuentry "Memory test (mt86+x64)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 } menuentry "Memory test (mt86+x64, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 console=ttyS0,115200 } menuentry "Memory test (mt86+ia32)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 } menuentry "Memory test (mt86+ia32, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 console=ttyS0,115200 } menuentry "Memory test (mt86+x64)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 } menuentry "Memory test (mt86+x64, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 console=ttyS0,115200 } menuentry "Memory test (mt86+ia32)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 } menuentry "Memory test (mt86+ia32, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 console=ttyS0,115200 } menuentry "Memory test (mt86+x64)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 } menuentry "Memory test (mt86+x64, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 console=ttyS0,115200 } menuentry "Memory test (mt86+ia32)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 } menuentry "Memory test (mt86+ia32, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 console=ttyS0,115200 } menuentry "Memory test (mt86+x64)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 } menuentry "Memory test (mt86+x64, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 console=ttyS0,115200 } menuentry "Memory test (mt86+ia32)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 } menuentry "Memory test (mt86+ia32, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 console=ttyS0,115200 } menuentry "Memory test (mt86+x64)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 } menuentry "Memory test (mt86+x64, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 console=ttyS0,115200 } menuentry "Memory test (mt86+ia32)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 } menuentry "Memory test (mt86+ia32, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 console=ttyS0,115200 } menuentry "Memory test (mt86+x64)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 } menuentry "Memory test (mt86+x64, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 console=ttyS0,115200 } menuentry "Memory test (mt86+ia32)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 } menuentry "Memory test (mt86+ia32, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 console=ttyS0,115200 } menuentry "Memory test (mt86+x64)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 } menuentry "Memory test (mt86+x64, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 console=ttyS0,115200 } menuentry "Memory test (mt86+ia32)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 } menuentry "Memory test (mt86+ia32, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 console=ttyS0,115200 } menuentry "Memory test (mt86+x64)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 } menuentry "Memory test (mt86+x64, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 console=ttyS0,115200 } menuentry "Memory test (mt86+ia32)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 } menuentry "Memory test (mt86+ia32, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 console=ttyS0,115200 } menuentry "Memory test (mt86+x64)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 } menuentry "Memory test (mt86+x64, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 console=ttyS0,115200 } menuentry "Memory test (mt86+ia32)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 } menuentry "Memory test (mt86+ia32, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 console=ttyS0,115200 } menuentry "1. Ubuntu Studio (on /dev/nvme0n1p3)" --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-7.0.0-31-generic--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/vmlinuz-7.0.0-31-generic root=UUID=bd830e84-8c65-4850-bb7a-01fa779c0d99 ro quiet splash preempt=full threadirqs rcu_nocbs=all initrd /boot/initrd.img-7.0.0-31-generic } menuentry "Ubuntu, with Linux 7.0.0-31-generic (on /dev/nvme0n1p3)" --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-7.0.0-31-generic--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/vmlinuz-7.0.0-31-generic root=UUID=bd830e84-8c65-4850-bb7a-01fa779c0d99 ro quiet splash preempt=full threadirqs rcu_nocbs=all initrd /boot/initrd.img-7.0.0-31-generic } menuentry "Ubuntu, with Linux 7.0.0-31-generic (recovery mode) (on /dev/nvme0n1p3)" --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-7.0.0-31-generic-root=UUID=bd830e84-8c65-4850-bb7a-01fa779c0d99 ro recovery nomodeset dis_ucode_ldr-bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/vmlinuz-7.0.0-31-generic root=UUID=bd830e84-8c65-4850-bb7a-01fa779c0d99 ro recovery nomodeset dis_ucode_ldr initrd /boot/initrd.img-7.0.0-31-generic } menuentry "Ubuntu, with Linux 7.0.0-30-generic (on /dev/nvme0n1p3)" --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-7.0.0-30-generic--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/vmlinuz-7.0.0-30-generic root=UUID=bd830e84-8c65-4850-bb7a-01fa779c0d99 ro quiet splash preempt=full threadirqs rcu_nocbs=all initrd /boot/initrd.img-7.0.0-30-generic } menuentry "Ubuntu, with Linux 7.0.0-30-generic (recovery mode) (on /dev/nvme0n1p3)" --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-7.0.0-30-generic-root=UUID=bd830e84-8c65-4850-bb7a-01fa779c0d99 ro recovery nomodeset dis_ucode_ldr-bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/vmlinuz-7.0.0-30-generic root=UUID=bd830e84-8c65-4850-bb7a-01fa779c0d99 ro recovery nomodeset dis_ucode_ldr initrd /boot/initrd.img-7.0.0-30-generic } } menuentry "MX 25.2 Infinity (25.2) (on /dev/nvme0n1p6)" --class mx --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-simple-bba7e528-a914-44dc-9309-a4cabc64d66b' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bba7e528-a914-44dc-9309-a4cabc64d66b linux /boot/vmlinuz-6.12.107+deb13-amd64 root=UUID=bba7e528-a914-44dc-9309-a4cabc64d66b ro quiet splash initrd /boot/initrd.img-6.12.107+deb13-amd64 } submenu "Advanced options for MX 25.2 Infinity (25.2) (on /dev/nvme0n1p6)"{ menuentry "MX 25.2 Infinity (on /dev/nvme0n1p6)" --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-6.12.107+deb13-amd64--bba7e528-a914-44dc-9309-a4cabc64d66b' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bba7e528-a914-44dc-9309-a4cabc64d66b linux /boot/vmlinuz-6.12.107+deb13-amd64 root=UUID=bba7e528-a914-44dc-9309-a4cabc64d66b ro quiet splash initrd /boot/initrd.img-6.12.107+deb13-amd64 } menuentry "MX 25.2 Infinity, with Linux 6.12.107+deb13-amd64 (on /dev/nvme0n1p6)" --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-6.12.107+deb13-amd64--bba7e528-a914-44dc-9309-a4cabc64d66b' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bba7e528-a914-44dc-9309-a4cabc64d66b linux /boot/vmlinuz-6.12.107+deb13-amd64 root=UUID=bba7e528-a914-44dc-9309-a4cabc64d66b ro quiet splash initrd /boot/initrd.img-6.12.107+deb13-amd64 } menuentry "MX 25.2 Infinity, with Linux 6.12.107+deb13-amd64 (sysvinit) (on /dev/nvme0n1p6)" --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-6.12.107+deb13-amd64--bba7e528-a914-44dc-9309-a4cabc64d66b' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bba7e528-a914-44dc-9309-a4cabc64d66b linux /boot/vmlinuz-6.12.107+deb13-amd64 root=UUID=bba7e528-a914-44dc-9309-a4cabc64d66b ro quiet splash init=/lib/sysvinit/init initrd /boot/initrd.img-6.12.107+deb13-amd64 } menuentry "MX 25.2 Infinity, with Linux 6.12.105+deb13-amd64 (on /dev/nvme0n1p6)" --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-6.12.105+deb13-amd64--bba7e528-a914-44dc-9309-a4cabc64d66b' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bba7e528-a914-44dc-9309-a4cabc64d66b linux /boot/vmlinuz-6.12.105+deb13-amd64 root=UUID=bba7e528-a914-44dc-9309-a4cabc64d66b ro quiet splash initrd /boot/initrd.img-6.12.105+deb13-amd64 } menuentry "MX 25.2 Infinity, with Linux 6.12.105+deb13-amd64 (sysvinit) (on /dev/nvme0n1p6)" --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-6.12.105+deb13-amd64--bba7e528-a914-44dc-9309-a4cabc64d66b' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bba7e528-a914-44dc-9309-a4cabc64d66b linux /boot/vmlinuz-6.12.105+deb13-amd64 root=UUID=bba7e528-a914-44dc-9309-a4cabc64d66b ro quiet splash init=/lib/sysvinit/init initrd /boot/initrd.img-6.12.105+deb13-amd64 } menuentry "MX 25.2 Infinity, with Linux 6.12.100+deb13-amd64 (on /dev/nvme0n1p6)" --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-6.12.100+deb13-amd64--bba7e528-a914-44dc-9309-a4cabc64d66b' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bba7e528-a914-44dc-9309-a4cabc64d66b linux /boot/vmlinuz-6.12.100+deb13-amd64 root=UUID=bba7e528-a914-44dc-9309-a4cabc64d66b ro quiet splash initrd /boot/initrd.img-6.12.100+deb13-amd64 } menuentry "MX 25.2 Infinity, with Linux 6.12.100+deb13-amd64 (sysvinit) (on /dev/nvme0n1p6)" --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-6.12.100+deb13-amd64--bba7e528-a914-44dc-9309-a4cabc64d66b' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bba7e528-a914-44dc-9309-a4cabc64d66b linux /boot/vmlinuz-6.12.100+deb13-amd64 root=UUID=bba7e528-a914-44dc-9309-a4cabc64d66b ro quiet splash init=/lib/sysvinit/init initrd /boot/initrd.img-6.12.100+deb13-amd64 } } This menu entry is supported only on EFI platforms.
set timeout_style=menu if [ "${timeout}" = 0 ]; then set timeout=10 fi menuentry "Windows Boot Manager (on /dev/nvme0n1p1)" --class windows --class os $menuentry_id_option 'osprober-efi-181C-600B' { insmod part_gpt insmod fat search --no-floppy --fs-uuid --set=root 181C-600B chainloader /EFI/Microsoft/Boot/bootmgfw.efi } END /etc/grub.d/30_os-prober_proxy
BEGIN /etc/grub.d/31_uefi-firmware
if [ "$grub_platform" = "efi" ]; then fwsetup --is-supported if [ "$?" = 0 ]; then menuentry 'UEFI Firmware Settings' $menuentry_id_option 'uefi-firmware' { fwsetup } fi fi END /etc/grub.d/31_uefi-firmware
BEGIN /etc/grub.d/42_linux_proxy
submenu "Advanced options for Ubuntu"{ menuentry "Ubuntu, with Linux 7.0.0-1016-nvidia" --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-7.0.0-1016-nvidia-advanced-1ee56e03-e339-4319-b518-8402e7279820' { recordfail load_video set gfxpayload=$linux_gfx_mode insmod gzio if [ x$grub_platform = xxen ]; then insmod xzio; insmod lzopio; fi insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root 1ee56e03-e339-4319-b518-8402e7279820 echo 'Loading Linux 7.0.0-1016-nvidia ...' linux /boot/vmlinuz-7.0.0-1016-nvidia root=UUID=1ee56e03-e339-4319-b518-8402e7279820 ro quiet splash preempt=full rcu_nocbs=all crashkernel=2G-4G:320M,4G-32G:512M,32G-64G:1024M,64G-128G:2048M,128G-:4096M echo 'Loading initial ramdisk ...' initrd /boot/initrd.img-7.0.0-1016-nvidia } menuentry "Ubuntu, with Linux 7.0.0-1016-nvidia (recovery mode)" --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-7.0.0-1016-nvidia-recovery-1ee56e03-e339-4319-b518-8402e7279820' { recordfail load_video insmod gzio if [ x$grub_platform = xxen ]; then insmod xzio; insmod lzopio; fi insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root 1ee56e03-e339-4319-b518-8402e7279820 echo 'Loading Linux 7.0.0-1016-nvidia ...' linux /boot/vmlinuz-7.0.0-1016-nvidia root=UUID=1ee56e03-e339-4319-b518-8402e7279820 ro recovery nomodeset dis_ucode_ldr echo 'Loading initial ramdisk ...' initrd /boot/initrd.img-7.0.0-1016-nvidia } menuentry "Ubuntu, with Linux 7.0.0-31-generic" --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-7.0.0-31-generic-advanced-1ee56e03-e339-4319-b518-8402e7279820' { recordfail load_video set gfxpayload=$linux_gfx_mode insmod gzio if [ x$grub_platform = xxen ]; then insmod xzio; insmod lzopio; fi insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root 1ee56e03-e339-4319-b518-8402e7279820 echo 'Loading Linux 7.0.0-31-generic ...' linux /boot/vmlinuz-7.0.0-31-generic root=UUID=1ee56e03-e339-4319-b518-8402e7279820 ro quiet splash preempt=full rcu_nocbs=all crashkernel=2G-4G:320M,4G-32G:512M,32G-64G:1024M,64G-128G:2048M,128G-:4096M echo 'Loading initial ramdisk ...' initrd /boot/initrd.img-7.0.0-31-generic } menuentry "Ubuntu, with Linux 7.0.0-31-generic (recovery mode)" --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-7.0.0-31-generic-recovery-1ee56e03-e339-4319-b518-8402e7279820' { recordfail load_video insmod gzio if [ x$grub_platform = xxen ]; then insmod xzio; insmod lzopio; fi insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root 1ee56e03-e339-4319-b518-8402e7279820 echo 'Loading Linux 7.0.0-31-generic ...' linux /boot/vmlinuz-7.0.0-31-generic root=UUID=1ee56e03-e339-4319-b518-8402e7279820 ro recovery nomodeset dis_ucode_ldr echo 'Loading initial ramdisk ...' initrd /boot/initrd.img-7.0.0-31-generic } menuentry "Ubuntu, with Linux 6.8.0-1062-nvidia-lowlatency" --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-6.8.0-1062-nvidia-lowlatency-advanced-1ee56e03-e339-4319-b518-8402e7279820' { recordfail load_video set gfxpayload=$linux_gfx_mode insmod gzio if [ x$grub_platform = xxen ]; then insmod xzio; insmod lzopio; fi insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root 1ee56e03-e339-4319-b518-8402e7279820 echo 'Loading Linux 6.8.0-1062-nvidia-lowlatency ...' linux /boot/vmlinuz-6.8.0-1062-nvidia-lowlatency root=UUID=1ee56e03-e339-4319-b518-8402e7279820 ro quiet splash preempt=full rcu_nocbs=all crashkernel=2G-4G:320M,4G-32G:512M,32G-64G:1024M,64G-128G:2048M,128G-:4096M echo 'Loading initial ramdisk ...' initrd /boot/initrd.img-6.8.0-1062-nvidia-lowlatency } menuentry "Ubuntu, with Linux 6.8.0-1062-nvidia-lowlatency (recovery mode)" --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-6.8.0-1062-nvidia-lowlatency-recovery-1ee56e03-e339-4319-b518-8402e7279820' { recordfail load_video insmod gzio if [ x$grub_platform = xxen ]; then insmod xzio; insmod lzopio; fi insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root 1ee56e03-e339-4319-b518-8402e7279820 echo 'Loading Linux 6.8.0-1062-nvidia-lowlatency ...' linux /boot/vmlinuz-6.8.0-1062-nvidia-lowlatency root=UUID=1ee56e03-e339-4319-b518-8402e7279820 ro recovery nomodeset dis_ucode_ldr echo 'Loading initial ramdisk ...' initrd /boot/initrd.img-6.8.0-1062-nvidia-lowlatency } menuentry "Ubuntu, with Linux 6.8.0-139-generic" --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-6.8.0-139-generic-advanced-1ee56e03-e339-4319-b518-8402e7279820' { recordfail load_video set gfxpayload=$linux_gfx_mode insmod gzio if [ x$grub_platform = xxen ]; then insmod xzio; insmod lzopio; fi insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root 1ee56e03-e339-4319-b518-8402e7279820 echo 'Loading Linux 6.8.0-139-generic ...' linux /boot/vmlinuz-6.8.0-139-generic root=UUID=1ee56e03-e339-4319-b518-8402e7279820 ro quiet splash preempt=full rcu_nocbs=all crashkernel=2G-4G:320M,4G-32G:512M,32G-64G:1024M,64G-128G:2048M,128G-:4096M echo 'Loading initial ramdisk ...' initrd /boot/initrd.img-6.8.0-139-generic } menuentry "Ubuntu, with Linux 6.8.0-139-generic (recovery mode)" --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-6.8.0-139-generic-recovery-1ee56e03-e339-4319-b518-8402e7279820' { recordfail load_video insmod gzio if [ x$grub_platform = xxen ]; then insmod xzio; insmod lzopio; fi insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root 1ee56e03-e339-4319-b518-8402e7279820 echo 'Loading Linux 6.8.0-139-generic ...' linux /boot/vmlinuz-6.8.0-139-generic root=UUID=1ee56e03-e339-4319-b518-8402e7279820 ro recovery nomodeset dis_ucode_ldr echo 'Loading initial ramdisk ...' initrd /boot/initrd.img-6.8.0-139-generic } menuentry "Ubuntu, with Linux 6.8.0-138-lowlatency" --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-6.8.0-138-lowlatency-advanced-1ee56e03-e339-4319-b518-8402e7279820' { recordfail load_video set gfxpayload=$linux_gfx_mode insmod gzio if [ x$grub_platform = xxen ]; then insmod xzio; insmod lzopio; fi insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root 1ee56e03-e339-4319-b518-8402e7279820 echo 'Loading Linux 6.8.0-138-lowlatency ...' linux /boot/vmlinuz-6.8.0-138-lowlatency root=UUID=1ee56e03-e339-4319-b518-8402e7279820 ro quiet splash preempt=full rcu_nocbs=all crashkernel=2G-4G:320M,4G-32G:512M,32G-64G:1024M,64G-128G:2048M,128G-:4096M echo 'Loading initial ramdisk ...' initrd /boot/initrd.img-6.8.0-138-lowlatency } menuentry "Ubuntu, with Linux 6.8.0-138-lowlatency (recovery mode)" --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-6.8.0-138-lowlatency-recovery-1ee56e03-e339-4319-b518-8402e7279820' { recordfail load_video insmod gzio if [ x$grub_platform = xxen ]; then insmod xzio; insmod lzopio; fi insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root 1ee56e03-e339-4319-b518-8402e7279820 echo 'Loading Linux 6.8.0-138-lowlatency ...' linux /boot/vmlinuz-6.8.0-138-lowlatency root=UUID=1ee56e03-e339-4319-b518-8402e7279820 ro recovery nomodeset dis_ucode_ldr echo 'Loading initial ramdisk ...' initrd /boot/initrd.img-6.8.0-138-lowlatency } } menuentry "Ubuntu" --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-simple-1ee56e03-e339-4319-b518-8402e7279820' { recordfail load_video set gfxpayload=$linux_gfx_mode insmod gzio if [ x$grub_platform = xxen ]; then insmod xzio; insmod lzopio; fi insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root 1ee56e03-e339-4319-b518-8402e7279820 linux /boot/vmlinuz-7.0.0-1016-nvidia root=UUID=1ee56e03-e339-4319-b518-8402e7279820 ro quiet splash preempt=full rcu_nocbs=all crashkernel=2G-4G:320M,4G-32G:512M,32G-64G:1024M,64G-128G:2048M,128G-:4096M initrd /boot/initrd.img-7.0.0-1016-nvidia } END /etc/grub.d/42_linux_proxy
<< *** END text of /boot/grub/grub.cfg.new *** >>>
I have also include /boot/grub/grub.cfg.new (for its text see below), because it is mentioned in the error messages (see also below). If I run the command sudo grub-mkconfig -o /boot/grub/grub.cfg on my boot Ubuntu 26.04.1 I get the same errors.
How can I fix this problem, because now I can not update any new software packages?
<< *** BEGIN Error messages *** >>
Summary: Upgrading: 12, Installing: 0, Removing: 1, Not Upgrading: 1 10 not fully installed or removed. 12 standard LTS security updates Download size: 3.606 kB / 4.254 kB Freed space: 15,0 MB
Continue? [Y/n] y Get:1 http://archive.ubuntu.com/ubuntu resolute-updates/main amd64 libsqlite3-dev amd64 3.46.1-9ubuntu0.3 [932 kB] Get:2 http://archive.ubuntu.com/ubuntu resolute-updates/main amd64 libsqlite3-0 amd64 3.46.1-9ubuntu0.3 [720 kB] Get:3 http://archive.ubuntu.com/ubuntu resolute-updates/main i386 libsqlite3-0 i386 3.46.1-9ubuntu0.3 [794 kB] Get:4 http://archive.ubuntu.com/ubuntu resolute-updates/main amd64 python3-cryptography amd64 46.0.5-1ubuntu2.2 [1.160 kB] Fetched 3.606 kB in 1s (3.310 kB/s)
dpkg: warning: files list file for package 'winboat' missing; assuming package has no files currently installed (Reading database… 1110464 files and directories currently installed.) Removing linux-image-6.8.0-1061-nvidia-lowlatency (6.8.0-1061.64.1)… /etc/kernel/postrm.d/initramfs-tools: update-initramfs: Deleting /boot/initrd.img-6.8.0-1061-nvidia-lowlatency /etc/kernel/postrm.d/kdump-tools: kdump-tools: Removing kdump tracking files for kernel version: 6.8.0-1061-nvidia-lowlatency /etc/kernel/postrm.d/zz-update-grub: Sourcing file /etc/default/grub' Sourcing file /etc/default/grub.d/99-lowlatency.cfg' Sourcing file `/etc/default/grub.d/kdump-tools.cfg' Generating grub configuration file ... Found linux image: /boot/vmlinuz-7.0.0-1016-nvidia Found initrd image: /boot/initrd.img-7.0.0-1016-nvidia Found linux image: /boot/vmlinuz-7.0.0-31-generic Found initrd image: /boot/initrd.img-7.0.0-31-generic Found linux image: /boot/vmlinuz-6.8.0-1062-nvidia-lowlatency Found initrd image: /boot/initrd.img-6.8.0-1062-nvidia-lowlatency Found linux image: /boot/vmlinuz-6.8.0-139-generic Found initrd image: /boot/initrd.img-6.8.0-139-generic Found linux image: /boot/vmlinuz-6.8.0-138-lowlatency Found initrd image: /boot/initrd.img-6.8.0-138-lowlatency Found linux image: /boot/vmlinuz-7.0.0-1016-nvidia Found initrd image: /boot/initrd.img-7.0.0-1016-nvidia Found linux image: /boot/vmlinuz-7.0.0-31-generic Found initrd image: /boot/initrd.img-7.0.0-31-generic Found linux image: /boot/vmlinuz-6.8.0-1062-nvidia-lowlatency Found initrd image: /boot/initrd.img-6.8.0-1062-nvidia-lowlatency Found linux image: /boot/vmlinuz-6.8.0-139-generic Found initrd image: /boot/initrd.img-6.8.0-139-generic Found linux image: /boot/vmlinuz-6.8.0-138-lowlatency Found initrd image: /boot/initrd.img-6.8.0-138-lowlatency Warning: os-prober will be executed to detect other bootable partitions. Its output will be used to detect bootable binaries on them and create new boot entries. Found Ubuntu 26.04.1 LTS (26.04) on /dev/nvme0n1p3 Found MX 25.2 Infinity (25.2) on /dev/nvme0n1p6 Found Windows Boot Manager on /dev/nvme1n1p1@/EFI/Microsoft/Boot/bootmgfw.efi Adding boot menu entry for UEFI Firmware Settings ... Found linux image: /boot/vmlinuz-7.0.0-1016-nvidia Found initrd image: /boot/initrd.img-7.0.0-1016-nvidia Found linux image: /boot/vmlinuz-7.0.0-31-generic Found initrd image: /boot/initrd.img-7.0.0-31-generic Found linux image: /boot/vmlinuz-6.8.0-1062-nvidia-lowlatency Found initrd image: /boot/initrd.img-6.8.0-1062-nvidia-lowlatency Found linux image: /boot/vmlinuz-6.8.0-139-generic Found initrd image: /boot/initrd.img-6.8.0-139-generic Found linux image: /boot/vmlinuz-6.8.0-138-lowlatency Found initrd image: /boot/initrd.img-6.8.0-138-lowlatency error: out of memory. error: syntax error. error: Incorrect command. error: syntax error. Syntax error at line 1910 Syntax errors are detected in generated GRUB config file. Ensure that there are no errors in /etc/default/grub and /etc/grub.d/* files or please file a bug report with /boot/grub/grub.cfg.new file attached. run-parts: /etc/kernel/postrm.d/zz-update-grub exited with return code 1 dpkg: error processing package linux-image-6.8.0-1061-nvidia-lowlatency (--remove): old linux-image-6.8.0-1061-nvidia-lowlatency package postrm maintainer script subprocess failed with exit status 1 dpkg: too many errors, stopping Errors were encountered while processing: linux-image-6.8.0-1061-nvidia-lowlatency Processing was halted because there were too many errors.
<< *** END Error meassages *** >>
<< *** BEGIN text of /boot/grub/grub.cfg.new *** >>>
DO NOT EDIT THIS FILE
It is automatically generated by grub-mkconfig using templates
from /etc/grub.d and settings from /etc/default/grub
BEGIN /etc/grub.d/00_header
if [ -s $prefix/grubenv ]; then set have_grubenv=true load_env fi
if [ "${env_block}" ] ; then set env_block="(${root})${env_block}" export env_block load_env -f "${env_block}" fi
if [ "${initrdfail}" = 2 ]; then set initrdfail= elif [ "${initrdfail}" = 1 ]; then set next_entry="${prev_entry}" set prev_entry= save_env prev_entry if [ "${next_entry}" ]; then set initrdfail=2 fi fi if [ "${next_entry}" ] ; then set default="${next_entry}" set next_entry= if [ "${env_block}" ] ; then save_env -f "${env_block}" next_entry else save_env next_entry fi set boot_once=true else set default="0" fi
if [ x"${feature_menuentry_id}" = xy ]; then menuentry_id_option="--id" else menuentry_id_option="" fi
export menuentry_id_option
if [ "${prev_saved_entry}" ]; then set saved_entry="${prev_saved_entry}" save_env saved_entry set prev_saved_entry= save_env prev_saved_entry set boot_once=true fi
function savedefault { if [ -z "${boot_once}" ]; then saved_entry="${chosen}" if [ "${env_block}" ] ; then save_env -f "${env_block}" saved_entry else save_env saved_entry fi
fi } function initrdfail { if [ -n "${have_grubenv}" ]; then if [ -n "${partuuid}" ]; then if [ -z "${initrdfail}" ]; then set initrdfail=1 if [ -n "${boot_once}" ]; then set prev_entry="${default}" save_env prev_entry fi fi save_env initrdfail fi; fi } function recordfail { set recordfail=1 if [ -n "${have_grubenv}" ]; then if [ -z "${boot_once}" ]; then save_env recordfail; fi; fi } function load_video { if [ x$grub_platform = xefi ]; then insmod efi_gop elif [ x$feature_all_video_module = xy ]; then insmod all_video else insmod efi_gop insmod ieee1275_fb insmod vbe insmod vga insmod video_bochs insmod video_cirrus fi }
if [ x$feature_default_font_path = xy ] ; then font=unicode else insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root 1ee56e03-e339-4319-b518-8402e7279820 font="/usr/share/grub/unicode.pf2" fi
if loadfont $font ; then set gfxmode=auto load_video insmod gfxterm set locale_dir=$prefix/locale set lang=en_US insmod gettext fi terminal_output gfxterm if [ "${recordfail}" = 1 ] ; then set timeout=30 else if [ x$feature_timeout_style = xy ] ; then set timeout_style=hidden set timeout=0 Fallback hidden-timeout code in case the timeout_style feature is
unavailable.
elif sleep --interruptible 0 ; then set timeout=0 fi fi END /etc/grub.d/00_header
BEGIN /etc/grub.d/05_debian_theme
set menu_color_normal=white/black set menu_color_highlight=black/light-gray END /etc/grub.d/05_debian_theme
BEGIN /etc/grub.d/10_linux_proxy
if [ "${recordfail}" != 1 ]; then if [ -e ${prefix}/gfxblacklist.txt ]; then if [ ${grub_platform} != pc ]; then set linux_gfx_mode=keep elif hwmatch ${prefix}/gfxblacklist.txt 3; then if [ ${match} = 0 ]; then set linux_gfx_mode=keep else set linux_gfx_mode=text fi else set linux_gfx_mode=text fi else set linux_gfx_mode=keep fi else set linux_gfx_mode=text fi export linux_gfx_mode END /etc/grub.d/10_linux_proxy
BEGIN /etc/grub.d/12_linux_proxy
menuentry "Ubuntu, with Linux 7.0.0-1016-nvidia" --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-7.0.0-1016-nvidia-advanced-1ee56e03-e339-4319-b518-8402e7279820' { recordfail load_video set gfxpayload=$linux_gfx_mode insmod gzio if [ x$grub_platform = xxen ]; then insmod xzio; insmod lzopio; fi insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root 1ee56e03-e339-4319-b518-8402e7279820 echo 'Loading Linux 7.0.0-1016-nvidia ...' linux /boot/vmlinuz-7.0.0-1016-nvidia root=UUID=1ee56e03-e339-4319-b518-8402e7279820 ro quiet splash preempt=full rcu_nocbs=all crashkernel=2G-4G:320M,4G-32G:512M,32G-64G:1024M,64G-128G:2048M,128G-:4096M echo 'Loading initial ramdisk ...' initrd /boot/initrd.img-7.0.0-1016-nvidia } menuentry "Ubuntu, with Linux 7.0.0-1016-nvidia (recovery mode)" --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-7.0.0-1016-nvidia-recovery-1ee56e03-e339-4319-b518-8402e7279820' { recordfail load_video insmod gzio if [ x$grub_platform = xxen ]; then insmod xzio; insmod lzopio; fi insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root 1ee56e03-e339-4319-b518-8402e7279820 echo 'Loading Linux 7.0.0-1016-nvidia ...' linux /boot/vmlinuz-7.0.0-1016-nvidia root=UUID=1ee56e03-e339-4319-b518-8402e7279820 ro recovery nomodeset dis_ucode_ldr echo 'Loading initial ramdisk ...' initrd /boot/initrd.img-7.0.0-1016-nvidia } menuentry "Ubuntu, with Linux 7.0.0-31-generic" --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-7.0.0-31-generic-advanced-1ee56e03-e339-4319-b518-8402e7279820' { recordfail load_video set gfxpayload=$linux_gfx_mode insmod gzio if [ x$grub_platform = xxen ]; then insmod xzio; insmod lzopio; fi insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root 1ee56e03-e339-4319-b518-8402e7279820 echo 'Loading Linux 7.0.0-31-generic ...' linux /boot/vmlinuz-7.0.0-31-generic root=UUID=1ee56e03-e339-4319-b518-8402e7279820 ro quiet splash preempt=full rcu_nocbs=all crashkernel=2G-4G:320M,4G-32G:512M,32G-64G:1024M,64G-128G:2048M,128G-:4096M echo 'Loading initial ramdisk ...' initrd /boot/initrd.img-7.0.0-31-generic } menuentry "Ubuntu, with Linux 7.0.0-31-generic (recovery mode)" --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-7.0.0-31-generic-recovery-1ee56e03-e339-4319-b518-8402e7279820' { recordfail load_video insmod gzio if [ x$grub_platform = xxen ]; then insmod xzio; insmod lzopio; fi insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root 1ee56e03-e339-4319-b518-8402e7279820 echo 'Loading Linux 7.0.0-31-generic ...' linux /boot/vmlinuz-7.0.0-31-generic root=UUID=1ee56e03-e339-4319-b518-8402e7279820 ro recovery nomodeset dis_ucode_ldr echo 'Loading initial ramdisk ...' initrd /boot/initrd.img-7.0.0-31-generic } menuentry "Ubuntu, with Linux 6.8.0-1062-nvidia-lowlatency" --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-6.8.0-1062-nvidia-lowlatency-advanced-1ee56e03-e339-4319-b518-8402e7279820' { recordfail load_video set gfxpayload=$linux_gfx_mode insmod gzio if [ x$grub_platform = xxen ]; then insmod xzio; insmod lzopio; fi insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root 1ee56e03-e339-4319-b518-8402e7279820 echo 'Loading Linux 6.8.0-1062-nvidia-lowlatency ...' linux /boot/vmlinuz-6.8.0-1062-nvidia-lowlatency root=UUID=1ee56e03-e339-4319-b518-8402e7279820 ro quiet splash preempt=full rcu_nocbs=all crashkernel=2G-4G:320M,4G-32G:512M,32G-64G:1024M,64G-128G:2048M,128G-:4096M echo 'Loading initial ramdisk ...' initrd /boot/initrd.img-6.8.0-1062-nvidia-lowlatency } menuentry "Ubuntu, with Linux 6.8.0-1062-nvidia-lowlatency (recovery mode)" --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-6.8.0-1062-nvidia-lowlatency-recovery-1ee56e03-e339-4319-b518-8402e7279820' { recordfail load_video insmod gzio if [ x$grub_platform = xxen ]; then insmod xzio; insmod lzopio; fi insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root 1ee56e03-e339-4319-b518-8402e7279820 echo 'Loading Linux 6.8.0-1062-nvidia-lowlatency ...' linux /boot/vmlinuz-6.8.0-1062-nvidia-lowlatency root=UUID=1ee56e03-e339-4319-b518-8402e7279820 ro recovery nomodeset dis_ucode_ldr echo 'Loading initial ramdisk ...' initrd /boot/initrd.img-6.8.0-1062-nvidia-lowlatency } menuentry "Ubuntu, with Linux 6.8.0-139-generic" --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-6.8.0-139-generic-advanced-1ee56e03-e339-4319-b518-8402e7279820' { recordfail load_video set gfxpayload=$linux_gfx_mode insmod gzio if [ x$grub_platform = xxen ]; then insmod xzio; insmod lzopio; fi insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root 1ee56e03-e339-4319-b518-8402e7279820 echo 'Loading Linux 6.8.0-139-generic ...' linux /boot/vmlinuz-6.8.0-139-generic root=UUID=1ee56e03-e339-4319-b518-8402e7279820 ro quiet splash preempt=full rcu_nocbs=all crashkernel=2G-4G:320M,4G-32G:512M,32G-64G:1024M,64G-128G:2048M,128G-:4096M echo 'Loading initial ramdisk ...' initrd /boot/initrd.img-6.8.0-139-generic } menuentry "Ubuntu, with Linux 6.8.0-139-generic (recovery mode)" --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-6.8.0-139-generic-recovery-1ee56e03-e339-4319-b518-8402e7279820' { recordfail load_video insmod gzio if [ x$grub_platform = xxen ]; then insmod xzio; insmod lzopio; fi insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root 1ee56e03-e339-4319-b518-8402e7279820 echo 'Loading Linux 6.8.0-139-generic ...' linux /boot/vmlinuz-6.8.0-139-generic root=UUID=1ee56e03-e339-4319-b518-8402e7279820 ro recovery nomodeset dis_ucode_ldr echo 'Loading initial ramdisk ...' initrd /boot/initrd.img-6.8.0-139-generic } menuentry "Ubuntu, with Linux 6.8.0-138-lowlatency" --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-6.8.0-138-lowlatency-advanced-1ee56e03-e339-4319-b518-8402e7279820' { recordfail load_video set gfxpayload=$linux_gfx_mode insmod gzio if [ x$grub_platform = xxen ]; then insmod xzio; insmod lzopio; fi insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root 1ee56e03-e339-4319-b518-8402e7279820 echo 'Loading Linux 6.8.0-138-lowlatency ...' linux /boot/vmlinuz-6.8.0-138-lowlatency root=UUID=1ee56e03-e339-4319-b518-8402e7279820 ro quiet splash preempt=full rcu_nocbs=all crashkernel=2G-4G:320M,4G-32G:512M,32G-64G:1024M,64G-128G:2048M,128G-:4096M echo 'Loading initial ramdisk ...' initrd /boot/initrd.img-6.8.0-138-lowlatency } menuentry "Ubuntu, with Linux 6.8.0-138-lowlatency (recovery mode)" --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-6.8.0-138-lowlatency-recovery-1ee56e03-e339-4319-b518-8402e7279820' { recordfail load_video insmod gzio if [ x$grub_platform = xxen ]; then insmod xzio; insmod lzopio; fi insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root 1ee56e03-e339-4319-b518-8402e7279820 echo 'Loading Linux 6.8.0-138-lowlatency ...' linux /boot/vmlinuz-6.8.0-138-lowlatency root=UUID=1ee56e03-e339-4319-b518-8402e7279820 ro recovery nomodeset dis_ucode_ldr echo 'Loading initial ramdisk ...' initrd /boot/initrd.img-6.8.0-138-lowlatency } END /etc/grub.d/12_linux_proxy
BEGIN /etc/grub.d/13_linux_zfs
END /etc/grub.d/13_linux_zfs
BEGIN /etc/grub.d/20_linux_xen
END /etc/grub.d/20_linux_xen
BEGIN /etc/grub.d/25_bli
if [ "$grub_platform" = "efi" ]; then insmod bli fi END /etc/grub.d/25_bli
BEGIN /etc/grub.d/30_os-prober_proxy
submenu "Advanced options for Ubuntu 26.04.1 LTS (26.04) (on /dev/nvme1n1p3)"{ menuentry "Ubuntu, with Linux 7.0.0-31-generic (on /dev/nvme1n1p3)" --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-7.0.0-31-generic--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/vmlinuz-7.0.0-31-generic root=UUID=bd830e84-8c65-4850-bb7a-01fa779c0d99 ro quiet splash preempt=full threadirqs rcu_nocbs=all initrd /boot/initrd.img-7.0.0-31-generic } } submenu "Advanced options for MX 25.2 Infinity (25.2) (on /dev/nvme1n1p6)"{ menuentry "MX 25.2 Infinity, with Linux 6.12.107+deb13-amd64 (on /dev/nvme1n1p6)" --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-6.12.107+deb13-amd64--bba7e528-a914-44dc-9309-a4cabc64d66b' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bba7e528-a914-44dc-9309-a4cabc64d66b linux /boot/vmlinuz-6.12.107+deb13-amd64 root=UUID=bba7e528-a914-44dc-9309-a4cabc64d66b ro quiet splash initrd /boot/initrd.img-6.12.107+deb13-amd64 } } menuentry "Ubuntu 26.04.1 LTS (26.04) (on /dev/nvme0n1p3)" --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-simple-bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/vmlinuz-7.0.0-31-generic root=UUID=bd830e84-8c65-4850-bb7a-01fa779c0d99 ro quiet splash preempt=full threadirqs rcu_nocbs=all initrd /boot/initrd.img-7.0.0-31-generic } submenu "Advanced options for Ubuntu 26.04.1 LTS (26.04) (on /dev/nvme0n1p3)"{ menuentry "Memory test (mt86+x64)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 } menuentry "Memory test (mt86+x64, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 console=ttyS0,115200 } menuentry "Memory test (mt86+ia32)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 } menuentry "Memory test (mt86+ia32, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 console=ttyS0,115200 } menuentry "Memory test (mt86+x64)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 } menuentry "Memory test (mt86+x64, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 console=ttyS0,115200 } menuentry "Memory test (mt86+ia32)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 } menuentry "Memory test (mt86+ia32, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 console=ttyS0,115200 } menuentry "Memory test (mt86+x64)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 } menuentry "Memory test (mt86+x64, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 console=ttyS0,115200 } menuentry "Memory test (mt86+ia32)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 } menuentry "Memory test (mt86+ia32, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 console=ttyS0,115200 } menuentry "Memory test (mt86+x64)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 } menuentry "Memory test (mt86+x64, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 console=ttyS0,115200 } menuentry "Memory test (mt86+ia32)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 } menuentry "Memory test (mt86+ia32, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 console=ttyS0,115200 } menuentry "Memory test (mt86+x64)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 } menuentry "Memory test (mt86+x64, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 console=ttyS0,115200 } menuentry "Memory test (mt86+ia32)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 } menuentry "Memory test (mt86+ia32, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 console=ttyS0,115200 } menuentry "Memory test (mt86+x64)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 } menuentry "Memory test (mt86+x64, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 console=ttyS0,115200 } menuentry "Memory test (mt86+ia32)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 } menuentry "Memory test (mt86+ia32, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 console=ttyS0,115200 } menuentry "Memory test (mt86+x64)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 } menuentry "Memory test (mt86+x64, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 console=ttyS0,115200 } menuentry "Memory test (mt86+ia32)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 } menuentry "Memory test (mt86+ia32, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 console=ttyS0,115200 } menuentry "Memory test (mt86+x64)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 } menuentry "Memory test (mt86+x64, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 console=ttyS0,115200 } menuentry "Memory test (mt86+ia32)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 } menuentry "Memory test (mt86+ia32, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 console=ttyS0,115200 } menuentry "Memory test (mt86+x64)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 } menuentry "Memory test (mt86+x64, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 console=ttyS0,115200 } menuentry "Memory test (mt86+ia32)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 } menuentry "Memory test (mt86+ia32, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 console=ttyS0,115200 } menuentry "Memory test (mt86+x64)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 } menuentry "Memory test (mt86+x64, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 console=ttyS0,115200 } menuentry "Memory test (mt86+ia32)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 } menuentry "Memory test (mt86+ia32, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 console=ttyS0,115200 } menuentry "Memory test (mt86+x64)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 } menuentry "Memory test (mt86+x64, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 console=ttyS0,115200 } menuentry "Memory test (mt86+ia32)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 } menuentry "Memory test (mt86+ia32, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 console=ttyS0,115200 } menuentry "Memory test (mt86+x64)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 } menuentry "Memory test (mt86+x64, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 console=ttyS0,115200 } menuentry "Memory test (mt86+ia32)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 } menuentry "Memory test (mt86+ia32, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 console=ttyS0,115200 } menuentry "Memory test (mt86+x64)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 } menuentry "Memory test (mt86+x64, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 console=ttyS0,115200 } menuentry "Memory test (mt86+ia32)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 } menuentry "Memory test (mt86+ia32, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 console=ttyS0,115200 } menuentry "Memory test (mt86+x64)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 } menuentry "Memory test (mt86+x64, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 console=ttyS0,115200 } menuentry "Memory test (mt86+ia32)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 } menuentry "Memory test (mt86+ia32, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 console=ttyS0,115200 } menuentry "Memory test (mt86+x64)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 } menuentry "Memory test (mt86+x64, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 console=ttyS0,115200 } menuentry "Memory test (mt86+ia32)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 } menuentry "Memory test (mt86+ia32, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 console=ttyS0,115200 } menuentry "Memory test (mt86+x64)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 } menuentry "Memory test (mt86+x64, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 console=ttyS0,115200 } menuentry "Memory test (mt86+ia32)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 } menuentry "Memory test (mt86+ia32, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 console=ttyS0,115200 } menuentry "Memory test (mt86+x64)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 } menuentry "Memory test (mt86+x64, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 console=ttyS0,115200 } menuentry "Memory test (mt86+ia32)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 } menuentry "Memory test (mt86+ia32, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 console=ttyS0,115200 } menuentry "Memory test (mt86+x64)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 } menuentry "Memory test (mt86+x64, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 console=ttyS0,115200 } menuentry "Memory test (mt86+ia32)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 } menuentry "Memory test (mt86+ia32, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 console=ttyS0,115200 } menuentry "Memory test (mt86+x64)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 } menuentry "Memory test (mt86+x64, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 console=ttyS0,115200 } menuentry "Memory test (mt86+ia32)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 } menuentry "Memory test (mt86+ia32, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 console=ttyS0,115200 } menuentry "Memory test (mt86+x64)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 } menuentry "Memory test (mt86+x64, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 console=ttyS0,115200 } menuentry "Memory test (mt86+ia32)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 } menuentry "Memory test (mt86+ia32, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 console=ttyS0,115200 } menuentry "Memory test (mt86+x64)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 } menuentry "Memory test (mt86+x64, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 console=ttyS0,115200 } menuentry "Memory test (mt86+ia32)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 } menuentry "Memory test (mt86+ia32, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 console=ttyS0,115200 } menuentry "Memory test (mt86+x64)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 } menuentry "Memory test (mt86+x64, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 console=ttyS0,115200 } menuentry "Memory test (mt86+ia32)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 } menuentry "Memory test (mt86+ia32, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 console=ttyS0,115200 } menuentry "Memory test (mt86+x64)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 } menuentry "Memory test (mt86+x64, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 console=ttyS0,115200 } menuentry "Memory test (mt86+ia32)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 } menuentry "Memory test (mt86+ia32, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 console=ttyS0,115200 } menuentry "Memory test (mt86+x64)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 } menuentry "Memory test (mt86+x64, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 console=ttyS0,115200 } menuentry "Memory test (mt86+ia32)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 } menuentry "Memory test (mt86+ia32, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 console=ttyS0,115200 } menuentry "Memory test (mt86+x64)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 } menuentry "Memory test (mt86+x64, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 console=ttyS0,115200 } menuentry "Memory test (mt86+ia32)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 } menuentry "Memory test (mt86+ia32, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 console=ttyS0,115200 } menuentry "Memory test (mt86+x64)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 } menuentry "Memory test (mt86+x64, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 console=ttyS0,115200 } menuentry "Memory test (mt86+ia32)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 } menuentry "Memory test (mt86+ia32, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 console=ttyS0,115200 } menuentry "Memory test (mt86+x64)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 } menuentry "Memory test (mt86+x64, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 console=ttyS0,115200 } menuentry "Memory test (mt86+ia32)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 } menuentry "Memory test (mt86+ia32, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 console=ttyS0,115200 } menuentry "Memory test (mt86+x64)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 } menuentry "Memory test (mt86+x64, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 console=ttyS0,115200 } menuentry "Memory test (mt86+ia32)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 } menuentry "Memory test (mt86+ia32, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 console=ttyS0,115200 } menuentry "Memory test (mt86+x64)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 } menuentry "Memory test (mt86+x64, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 console=ttyS0,115200 } menuentry "Memory test (mt86+ia32)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 } menuentry "Memory test (mt86+ia32, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 console=ttyS0,115200 } menuentry "Memory test (mt86+x64)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 } menuentry "Memory test (mt86+x64, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 console=ttyS0,115200 } menuentry "Memory test (mt86+ia32)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 } menuentry "Memory test (mt86+ia32, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 console=ttyS0,115200 } menuentry "Memory test (mt86+x64)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 } menuentry "Memory test (mt86+x64, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 console=ttyS0,115200 } menuentry "Memory test (mt86+ia32)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 } menuentry "Memory test (mt86+ia32, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 console=ttyS0,115200 } menuentry "Memory test (mt86+x64)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 } menuentry "Memory test (mt86+x64, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 console=ttyS0,115200 } menuentry "Memory test (mt86+ia32)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 } menuentry "Memory test (mt86+ia32, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 console=ttyS0,115200 } menuentry "Memory test (mt86+x64)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 } menuentry "Memory test (mt86+x64, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 console=ttyS0,115200 } menuentry "Memory test (mt86+ia32)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 } menuentry "Memory test (mt86+ia32, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 console=ttyS0,115200 } menuentry "Memory test (mt86+x64)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 } menuentry "Memory test (mt86+x64, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 console=ttyS0,115200 } menuentry "Memory test (mt86+ia32)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 } menuentry "Memory test (mt86+ia32, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 console=ttyS0,115200 } menuentry "Memory test (mt86+x64)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 } menuentry "Memory test (mt86+x64, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 console=ttyS0,115200 } menuentry "Memory test (mt86+ia32)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 } menuentry "Memory test (mt86+ia32, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 console=ttyS0,115200 } menuentry "Memory test (mt86+x64)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 } menuentry "Memory test (mt86+x64, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 console=ttyS0,115200 } menuentry "Memory test (mt86+ia32)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 } menuentry "Memory test (mt86+ia32, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 console=ttyS0,115200 } menuentry "Memory test (mt86+x64)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 } menuentry "Memory test (mt86+x64, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 console=ttyS0,115200 } menuentry "Memory test (mt86+ia32)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 } menuentry "Memory test (mt86+ia32, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 console=ttyS0,115200 } menuentry "Memory test (mt86+x64)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 } menuentry "Memory test (mt86+x64, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 console=ttyS0,115200 } menuentry "Memory test (mt86+ia32)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 } menuentry "Memory test (mt86+ia32, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 console=ttyS0,115200 } menuentry "Memory test (mt86+x64)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 } menuentry "Memory test (mt86+x64, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 console=ttyS0,115200 } menuentry "Memory test (mt86+ia32)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 } menuentry "Memory test (mt86+ia32, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 console=ttyS0,115200 } menuentry "Memory test (mt86+x64)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 } menuentry "Memory test (mt86+x64, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 console=ttyS0,115200 } menuentry "Memory test (mt86+ia32)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 } menuentry "Memory test (mt86+ia32, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 console=ttyS0,115200 } menuentry "Memory test (mt86+x64)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 } menuentry "Memory test (mt86+x64, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 console=ttyS0,115200 } menuentry "Memory test (mt86+ia32)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 } menuentry "Memory test (mt86+ia32, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 console=ttyS0,115200 } menuentry "Memory test (mt86+x64)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 } menuentry "Memory test (mt86+x64, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 console=ttyS0,115200 } menuentry "Memory test (mt86+ia32)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 } menuentry "Memory test (mt86+ia32, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 console=ttyS0,115200 } menuentry "Memory test (mt86+x64)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 } menuentry "Memory test (mt86+x64, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 console=ttyS0,115200 } menuentry "Memory test (mt86+ia32)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 } menuentry "Memory test (mt86+ia32, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 console=ttyS0,115200 } menuentry "Memory test (mt86+x64)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 } menuentry "Memory test (mt86+x64, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+x64--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+x64 console=ttyS0,115200 } menuentry "Memory test (mt86+ia32)" --class memtest $menuentry_id_option "memtest86+ (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 } menuentry "Memory test (mt86+ia32, serial console)" --class memtest $menuentry_id_option "memtest86+-serial (on /dev/nvme1n1p3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/mt86+ia32--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/mt86+ia32 console=ttyS0,115200 } menuentry "1. Ubuntu Studio (on /dev/nvme0n1p3)" --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-7.0.0-31-generic--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/vmlinuz-7.0.0-31-generic root=UUID=bd830e84-8c65-4850-bb7a-01fa779c0d99 ro quiet splash preempt=full threadirqs rcu_nocbs=all initrd /boot/initrd.img-7.0.0-31-generic } menuentry "Ubuntu, with Linux 7.0.0-31-generic (on /dev/nvme0n1p3)" --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-7.0.0-31-generic--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/vmlinuz-7.0.0-31-generic root=UUID=bd830e84-8c65-4850-bb7a-01fa779c0d99 ro quiet splash preempt=full threadirqs rcu_nocbs=all initrd /boot/initrd.img-7.0.0-31-generic } menuentry "Ubuntu, with Linux 7.0.0-31-generic (recovery mode) (on /dev/nvme0n1p3)" --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-7.0.0-31-generic-root=UUID=bd830e84-8c65-4850-bb7a-01fa779c0d99 ro recovery nomodeset dis_ucode_ldr-bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/vmlinuz-7.0.0-31-generic root=UUID=bd830e84-8c65-4850-bb7a-01fa779c0d99 ro recovery nomodeset dis_ucode_ldr initrd /boot/initrd.img-7.0.0-31-generic } menuentry "Ubuntu, with Linux 7.0.0-30-generic (on /dev/nvme0n1p3)" --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-7.0.0-30-generic--bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/vmlinuz-7.0.0-30-generic root=UUID=bd830e84-8c65-4850-bb7a-01fa779c0d99 ro quiet splash preempt=full threadirqs rcu_nocbs=all initrd /boot/initrd.img-7.0.0-30-generic } menuentry "Ubuntu, with Linux 7.0.0-30-generic (recovery mode) (on /dev/nvme0n1p3)" --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-7.0.0-30-generic-root=UUID=bd830e84-8c65-4850-bb7a-01fa779c0d99 ro recovery nomodeset dis_ucode_ldr-bd830e84-8c65-4850-bb7a-01fa779c0d99' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bd830e84-8c65-4850-bb7a-01fa779c0d99 linux /boot/vmlinuz-7.0.0-30-generic root=UUID=bd830e84-8c65-4850-bb7a-01fa779c0d99 ro recovery nomodeset dis_ucode_ldr initrd /boot/initrd.img-7.0.0-30-generic } } menuentry "MX 25.2 Infinity (25.2) (on /dev/nvme0n1p6)" --class mx --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-simple-bba7e528-a914-44dc-9309-a4cabc64d66b' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bba7e528-a914-44dc-9309-a4cabc64d66b linux /boot/vmlinuz-6.12.107+deb13-amd64 root=UUID=bba7e528-a914-44dc-9309-a4cabc64d66b ro quiet splash initrd /boot/initrd.img-6.12.107+deb13-amd64 } submenu "Advanced options for MX 25.2 Infinity (25.2) (on /dev/nvme0n1p6)"{ menuentry "MX 25.2 Infinity (on /dev/nvme0n1p6)" --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-6.12.107+deb13-amd64--bba7e528-a914-44dc-9309-a4cabc64d66b' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bba7e528-a914-44dc-9309-a4cabc64d66b linux /boot/vmlinuz-6.12.107+deb13-amd64 root=UUID=bba7e528-a914-44dc-9309-a4cabc64d66b ro quiet splash initrd /boot/initrd.img-6.12.107+deb13-amd64 } menuentry "MX 25.2 Infinity, with Linux 6.12.107+deb13-amd64 (on /dev/nvme0n1p6)" --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-6.12.107+deb13-amd64--bba7e528-a914-44dc-9309-a4cabc64d66b' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bba7e528-a914-44dc-9309-a4cabc64d66b linux /boot/vmlinuz-6.12.107+deb13-amd64 root=UUID=bba7e528-a914-44dc-9309-a4cabc64d66b ro quiet splash initrd /boot/initrd.img-6.12.107+deb13-amd64 } menuentry "MX 25.2 Infinity, with Linux 6.12.107+deb13-amd64 (sysvinit) (on /dev/nvme0n1p6)" --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-6.12.107+deb13-amd64--bba7e528-a914-44dc-9309-a4cabc64d66b' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bba7e528-a914-44dc-9309-a4cabc64d66b linux /boot/vmlinuz-6.12.107+deb13-amd64 root=UUID=bba7e528-a914-44dc-9309-a4cabc64d66b ro quiet splash init=/lib/sysvinit/init initrd /boot/initrd.img-6.12.107+deb13-amd64 } menuentry "MX 25.2 Infinity, with Linux 6.12.105+deb13-amd64 (on /dev/nvme0n1p6)" --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-6.12.105+deb13-amd64--bba7e528-a914-44dc-9309-a4cabc64d66b' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bba7e528-a914-44dc-9309-a4cabc64d66b linux /boot/vmlinuz-6.12.105+deb13-amd64 root=UUID=bba7e528-a914-44dc-9309-a4cabc64d66b ro quiet splash initrd /boot/initrd.img-6.12.105+deb13-amd64 } menuentry "MX 25.2 Infinity, with Linux 6.12.105+deb13-amd64 (sysvinit) (on /dev/nvme0n1p6)" --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-6.12.105+deb13-amd64--bba7e528-a914-44dc-9309-a4cabc64d66b' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bba7e528-a914-44dc-9309-a4cabc64d66b linux /boot/vmlinuz-6.12.105+deb13-amd64 root=UUID=bba7e528-a914-44dc-9309-a4cabc64d66b ro quiet splash init=/lib/sysvinit/init initrd /boot/initrd.img-6.12.105+deb13-amd64 } menuentry "MX 25.2 Infinity, with Linux 6.12.100+deb13-amd64 (on /dev/nvme0n1p6)" --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-6.12.100+deb13-amd64--bba7e528-a914-44dc-9309-a4cabc64d66b' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bba7e528-a914-44dc-9309-a4cabc64d66b linux /boot/vmlinuz-6.12.100+deb13-amd64 root=UUID=bba7e528-a914-44dc-9309-a4cabc64d66b ro quiet splash initrd /boot/initrd.img-6.12.100+deb13-amd64 } menuentry "MX 25.2 Infinity, with Linux 6.12.100+deb13-amd64 (sysvinit) (on /dev/nvme0n1p6)" --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-6.12.100+deb13-amd64--bba7e528-a914-44dc-9309-a4cabc64d66b' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root bba7e528-a914-44dc-9309-a4cabc64d66b linux /boot/vmlinuz-6.12.100+deb13-amd64 root=UUID=bba7e528-a914-44dc-9309-a4cabc64d66b ro quiet splash init=/lib/sysvinit/init initrd /boot/initrd.img-6.12.100+deb13-amd64 } } This menu entry is supported only on EFI platforms.
set timeout_style=menu if [ "${timeout}" = 0 ]; then set timeout=10 fi menuentry "Windows Boot Manager (on /dev/nvme0n1p1)" --class windows --class os $menuentry_id_option 'osprober-efi-181C-600B' { insmod part_gpt insmod fat search --no-floppy --fs-uuid --set=root 181C-600B chainloader /EFI/Microsoft/Boot/bootmgfw.efi } END /etc/grub.d/30_os-prober_proxy
BEGIN /etc/grub.d/31_uefi-firmware
if [ "$grub_platform" = "efi" ]; then fwsetup --is-supported if [ "$?" = 0 ]; then menuentry 'UEFI Firmware Settings' $menuentry_id_option 'uefi-firmware' { fwsetup } fi fi END /etc/grub.d/31_uefi-firmware
BEGIN /etc/grub.d/42_linux_proxy
submenu "Advanced options for Ubuntu"{ menuentry "Ubuntu, with Linux 7.0.0-1016-nvidia" --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-7.0.0-1016-nvidia-advanced-1ee56e03-e339-4319-b518-8402e7279820' { recordfail load_video set gfxpayload=$linux_gfx_mode insmod gzio if [ x$grub_platform = xxen ]; then insmod xzio; insmod lzopio; fi insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root 1ee56e03-e339-4319-b518-8402e7279820 echo 'Loading Linux 7.0.0-1016-nvidia ...' linux /boot/vmlinuz-7.0.0-1016-nvidia root=UUID=1ee56e03-e339-4319-b518-8402e7279820 ro quiet splash preempt=full rcu_nocbs=all crashkernel=2G-4G:320M,4G-32G:512M,32G-64G:1024M,64G-128G:2048M,128G-:4096M echo 'Loading initial ramdisk ...' initrd /boot/initrd.img-7.0.0-1016-nvidia } menuentry "Ubuntu, with Linux 7.0.0-1016-nvidia (recovery mode)" --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-7.0.0-1016-nvidia-recovery-1ee56e03-e339-4319-b518-8402e7279820' { recordfail load_video insmod gzio if [ x$grub_platform = xxen ]; then insmod xzio; insmod lzopio; fi insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root 1ee56e03-e339-4319-b518-8402e7279820 echo 'Loading Linux 7.0.0-1016-nvidia ...' linux /boot/vmlinuz-7.0.0-1016-nvidia root=UUID=1ee56e03-e339-4319-b518-8402e7279820 ro recovery nomodeset dis_ucode_ldr echo 'Loading initial ramdisk ...' initrd /boot/initrd.img-7.0.0-1016-nvidia } menuentry "Ubuntu, with Linux 7.0.0-31-generic" --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-7.0.0-31-generic-advanced-1ee56e03-e339-4319-b518-8402e7279820' { recordfail load_video set gfxpayload=$linux_gfx_mode insmod gzio if [ x$grub_platform = xxen ]; then insmod xzio; insmod lzopio; fi insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root 1ee56e03-e339-4319-b518-8402e7279820 echo 'Loading Linux 7.0.0-31-generic ...' linux /boot/vmlinuz-7.0.0-31-generic root=UUID=1ee56e03-e339-4319-b518-8402e7279820 ro quiet splash preempt=full rcu_nocbs=all crashkernel=2G-4G:320M,4G-32G:512M,32G-64G:1024M,64G-128G:2048M,128G-:4096M echo 'Loading initial ramdisk ...' initrd /boot/initrd.img-7.0.0-31-generic } menuentry "Ubuntu, with Linux 7.0.0-31-generic (recovery mode)" --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-7.0.0-31-generic-recovery-1ee56e03-e339-4319-b518-8402e7279820' { recordfail load_video insmod gzio if [ x$grub_platform = xxen ]; then insmod xzio; insmod lzopio; fi insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root 1ee56e03-e339-4319-b518-8402e7279820 echo 'Loading Linux 7.0.0-31-generic ...' linux /boot/vmlinuz-7.0.0-31-generic root=UUID=1ee56e03-e339-4319-b518-8402e7279820 ro recovery nomodeset dis_ucode_ldr echo 'Loading initial ramdisk ...' initrd /boot/initrd.img-7.0.0-31-generic } menuentry "Ubuntu, with Linux 6.8.0-1062-nvidia-lowlatency" --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-6.8.0-1062-nvidia-lowlatency-advanced-1ee56e03-e339-4319-b518-8402e7279820' { recordfail load_video set gfxpayload=$linux_gfx_mode insmod gzio if [ x$grub_platform = xxen ]; then insmod xzio; insmod lzopio; fi insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root 1ee56e03-e339-4319-b518-8402e7279820 echo 'Loading Linux 6.8.0-1062-nvidia-lowlatency ...' linux /boot/vmlinuz-6.8.0-1062-nvidia-lowlatency root=UUID=1ee56e03-e339-4319-b518-8402e7279820 ro quiet splash preempt=full rcu_nocbs=all crashkernel=2G-4G:320M,4G-32G:512M,32G-64G:1024M,64G-128G:2048M,128G-:4096M echo 'Loading initial ramdisk ...' initrd /boot/initrd.img-6.8.0-1062-nvidia-lowlatency } menuentry "Ubuntu, with Linux 6.8.0-1062-nvidia-lowlatency (recovery mode)" --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-6.8.0-1062-nvidia-lowlatency-recovery-1ee56e03-e339-4319-b518-8402e7279820' { recordfail load_video insmod gzio if [ x$grub_platform = xxen ]; then insmod xzio; insmod lzopio; fi insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root 1ee56e03-e339-4319-b518-8402e7279820 echo 'Loading Linux 6.8.0-1062-nvidia-lowlatency ...' linux /boot/vmlinuz-6.8.0-1062-nvidia-lowlatency root=UUID=1ee56e03-e339-4319-b518-8402e7279820 ro recovery nomodeset dis_ucode_ldr echo 'Loading initial ramdisk ...' initrd /boot/initrd.img-6.8.0-1062-nvidia-lowlatency } menuentry "Ubuntu, with Linux 6.8.0-139-generic" --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-6.8.0-139-generic-advanced-1ee56e03-e339-4319-b518-8402e7279820' { recordfail load_video set gfxpayload=$linux_gfx_mode insmod gzio if [ x$grub_platform = xxen ]; then insmod xzio; insmod lzopio; fi insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root 1ee56e03-e339-4319-b518-8402e7279820 echo 'Loading Linux 6.8.0-139-generic ...' linux /boot/vmlinuz-6.8.0-139-generic root=UUID=1ee56e03-e339-4319-b518-8402e7279820 ro quiet splash preempt=full rcu_nocbs=all crashkernel=2G-4G:320M,4G-32G:512M,32G-64G:1024M,64G-128G:2048M,128G-:4096M echo 'Loading initial ramdisk ...' initrd /boot/initrd.img-6.8.0-139-generic } menuentry "Ubuntu, with Linux 6.8.0-139-generic (recovery mode)" --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-6.8.0-139-generic-recovery-1ee56e03-e339-4319-b518-8402e7279820' { recordfail load_video insmod gzio if [ x$grub_platform = xxen ]; then insmod xzio; insmod lzopio; fi insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root 1ee56e03-e339-4319-b518-8402e7279820 echo 'Loading Linux 6.8.0-139-generic ...' linux /boot/vmlinuz-6.8.0-139-generic root=UUID=1ee56e03-e339-4319-b518-8402e7279820 ro recovery nomodeset dis_ucode_ldr echo 'Loading initial ramdisk ...' initrd /boot/initrd.img-6.8.0-139-generic } menuentry "Ubuntu, with Linux 6.8.0-138-lowlatency" --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-6.8.0-138-lowlatency-advanced-1ee56e03-e339-4319-b518-8402e7279820' { recordfail load_video set gfxpayload=$linux_gfx_mode insmod gzio if [ x$grub_platform = xxen ]; then insmod xzio; insmod lzopio; fi insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root 1ee56e03-e339-4319-b518-8402e7279820 echo 'Loading Linux 6.8.0-138-lowlatency ...' linux /boot/vmlinuz-6.8.0-138-lowlatency root=UUID=1ee56e03-e339-4319-b518-8402e7279820 ro quiet splash preempt=full rcu_nocbs=all crashkernel=2G-4G:320M,4G-32G:512M,32G-64G:1024M,64G-128G:2048M,128G-:4096M echo 'Loading initial ramdisk ...' initrd /boot/initrd.img-6.8.0-138-lowlatency } menuentry "Ubuntu, with Linux 6.8.0-138-lowlatency (recovery mode)" --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-6.8.0-138-lowlatency-recovery-1ee56e03-e339-4319-b518-8402e7279820' { recordfail load_video insmod gzio if [ x$grub_platform = xxen ]; then insmod xzio; insmod lzopio; fi insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root 1ee56e03-e339-4319-b518-8402e7279820 echo 'Loading Linux 6.8.0-138-lowlatency ...' linux /boot/vmlinuz-6.8.0-138-lowlatency root=UUID=1ee56e03-e339-4319-b518-8402e7279820 ro recovery nomodeset dis_ucode_ldr echo 'Loading initial ramdisk ...' initrd /boot/initrd.img-6.8.0-138-lowlatency } } menuentry "Ubuntu" --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-simple-1ee56e03-e339-4319-b518-8402e7279820' { recordfail load_video set gfxpayload=$linux_gfx_mode insmod gzio if [ x$grub_platform = xxen ]; then insmod xzio; insmod lzopio; fi insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root 1ee56e03-e339-4319-b518-8402e7279820 linux /boot/vmlinuz-7.0.0-1016-nvidia root=UUID=1ee56e03-e339-4319-b518-8402e7279820 ro quiet splash preempt=full rcu_nocbs=all crashkernel=2G-4G:320M,4G-32G:512M,32G-64G:1024M,64G-128G:2048M,128G-:4096M initrd /boot/initrd.img-7.0.0-1016-nvidia } END /etc/grub.d/42_linux_proxy
<< *** END text of /boot/grub/grub.cfg.new *** >>>
