opening Folders problem
    [Software] opening Folders problem
    I am running 26.04 LTS in dual boot with Mint Zena. I have a back up parition on another Drive. that I plan to use and swop files with each system.
    Dolphin File manager will not open the folders on this partition(B-UP) I googled for answer on Google but unsure if the answers are correct and will work. Being abit of a Newbie and perhaps (thick) I found one of those answers, above me.
    If anyone can assist and provide a easy to understand way of achieving the result. Always as part of my learning curve a explantion of why I cannot do this. My own thought that it do to Permissions
    Appreciate any advice
    You need to add more detail like how you're trying to open the directories and what error messages you see, if any. Otherwise, people just have to guess.
    Start with;
    Describe how the offending partition is mounted.
    What you see when you try Dolphin.
    What does "B-UP" mean?
    I'm going to guess that you haven't mounted the partition correctly - or at all - and you don't have permissions set properly.
    Answer the above and maybe you can get a helpful answer.
    There is 1 user viewing this topic.
