I posted this morning about the password requirements. This was in a VM, I have just tried on a bare metal and because I run an esoteric HDMI setup I always use nomodeset when installing as I cannot read the tiny fonts in normal mode. This time I was able to input a simple one digit password when entering a user. Just my observations, so if you can't install due to the extremely restrictive password requirements, just install in safe graphics mode.
Review of Resolute Raccoon Kubuntu 26.04 LTS
No, it needs at least 8 digits and with very specific exclusions on a normal installOriginally posted by skyfishgoo View Postkubuntu (and i thing all of ubuntu) has required at least 2 digits for a password for years now, afaik
i think you can also just leave it blank, but do not recommend thatAsus Z270i7 16gb rm 8tb GT1660 Haupp Quad tuner Kubuntu Jammy/Win 11 Be/FE mythtv 0.34Homerun dual netwk tuner 55¨ Smsng QN95B55" Lap Smsng NP R580 i5 nvidia linux Ultimate/Win 10
Has anyone seen if the issues surrounding KDE shortcuts has been resolved? This is the only thing that stops me (and thousands of others) from using Wayland. The work-a rounds I have seen are pretty convoluted involving loading an app and changing various permissions in the Wayland ecosystem.
This is a very basic requirement, and used to be a trivial exercise under x which was baked into the KDE environment - heck - even Windows makes it simple.
I have to say this is a very polished early release, everything works smooth as silk, even clunky old Mythtv works well, now to try and setup printers.Last edited by barfly; Mar 21, 2026, 10:19 AM.Asus Z270i7 16gb rm 8tb GT1660 Haupp Quad tuner Kubuntu Jammy/Win 11 Be/FE mythtv 0.34Homerun dual netwk tuner 55¨ Smsng QN95B55" Lap Smsng NP R580 i5 nvidia linux Ultimate/Win 10
What shortcuts, specifically, and what issues/workarounds?Originally posted by barfly View Postthe issues surrounding KDE shortcuts
(this may be better asked in a general KDE/Plasma section rather than a pre-release chat topic, for more eyeballs)
Hello all,
I've tried beta and last snapshot last 2 days in VM. Live session work fine, but after installation it's completely broken. As soon as I try to type something, program and plasma crash. I tried it in KVM and VMWare Workstation, it's the same.
Fix should be on the way: https://bugs.launchpad.net/ubuntu/+s...h/+bug/2146607Originally posted by cookiemuncher View Post'fastfetch' doesn't list correctly, but 'sudo fastfetch' does.
BTW: I don't have a screen attached to the laptop as the laptop was dropped and the screen was shattered and so was surgically removed. I have a Dell monitor connected via HDMI.
PS: Don't know how to copy/paste the text output correctly so I screengrabbed.
Your excellant list of the current state of Kubuntu 26/04 shows the 1 month to go before its release
. It will be released on the 23rd April, and no doubt we will all be looking forward to its status on that day.
Install 26.04 beta and has been working fine for me, no major problems here. on my little laptop anyway. So think it should be good to go on April 23rd.
I found one small problem. HPLip-gui package installs but will not run. Work on 24.10 but not 26.04.
when you try to run hp-setup in terminal get this output.
Code:raceback (most recent call last): File "/usr/bin/hp-setup", line 48, in <module> from base import device, utils, tui, models, module, services, os_utils File "/usr/share/hplip/base/device.py", line 2689, in <module> class LocalOpener(urllib_request.URLopener): ^^^^^^^^^^^^^^^^^^^^^^^^ AttributeError: module 'urllib.request' has no attribute 'URLopener' Last edited by kc1di; Mar 29, 2026, 05:29 AM.Dave Kubuntu 20.04 Registered Linux User #462608
Looks like the same error as: https://bugs.launchpad.net/ubuntu/+s...p/+bug/2146570Originally posted by kc1di View PostI found one small problem. HPLip-gui package installs but will not run. Work on 24.10 but not 26.04.
Yep I reported there.Originally posted by acheron View Post
It also same in gnome on ubuntu 26.04 beta. I think it maybe a PY 3 thing. But it's above my pay grade
