Review of Resolute Raccoon Kubuntu 26.04 LTS
    For those that want to try Kubuntu 26.04 Resolute Racoon, it is better to take the snapshot versions instead daily build. The last one " SnapShot 3 " from 2026/01/29 install good with Calamares. After the install operation use discover to update.
    https://cdimage.ubuntu.com/kubuntu/r...te/snapshot-3/
    In time: Daily Image below from today 2026/02/03 still has a problem. Use the snapshot 3 version above.
    https://cdimage.ubuntu.com/kubuntu/daily-live/20260203/
      wompmpmpp...wompppp.. no joy... same ERROR IMPLOSION.
      10:15:09 [6]: virtual Calamares::JobResult SetPartFlagsJob::exec()
      Setting flags on "/dev/vda" partition "/dev/vda1"
      "boot"
      10:15:09 [6]: virtual void Calamares::JobThread::run()
      Starting job "Set partition information" ( 7 / 41 )
      10:15:09 [6]: QVariantList FillGlobalStorageJob::createPartitionList() const
      Building partition information map
      .. partitions on "/dev/vda"
      .. mapping for "/dev/vda1" "/dev/vda1"
      partlabel : "kubuntu_2604"
      partition-uuid (partuuid) : "PartUUID$9f8109fd"
      parttype : ""
      partattrs : "0"
      mountPoint: : "/"
      fs: : "ext4"
      fsName : "ext4"
      filesystem-uuid (uuid) : "FSUUID$16482ac"
      claimed : "true"
      10:15:09 [6]: virtual Calamares::JobResult FillGlobalStorageJob::exec()
      Saving partition information map to GlobalStorage["partitions"]
      FillGlobalStorageJob writing bootLoader path: QVariant(QVariantMap, QMap(("installPath", QVariant(QString, "/dev/vda"))))
      Starting job "Managing auto-mount settings…" ( 8 / 41 )
      10:15:09 [6]: virtual Calamares::JobResult AutoMountManagementJob::exec()
      Restore automount settings
      Starting job "mount" ( 9 / 41 )​
        Tried an install of 26.04 and also got no further than the mounting of the partition stage. Installed KDE Neon instead.
          Well I found snapshot 2 and its installing to the VM as of now..
          FYI: for some who follow
          https://mirror.cpsc.ucalgary.ca/mirr...eleases/26.04/
          Ok.. installed.. now lets purge and reconfigure to reality...
            Downloaded and installed snapshot 2 ... all ok
            Updated 1330-odd packages and after rebooting had '.. faux_driver dell-pclatform_profile probe failed' on top of display, but no GUI.
            Entered CTRL+ALT-F3 to enter text screen. Edited '/etc/default/grub' to make grub menu visible on bootup. Rebooted. Entered recovery, altered nothng, and was able to enter GUI, but seems laggy.
            Is there a driver for Dell Inspiron laptops? It's a 2-core Celeron. Or do I leave KDE neon on here as that seemed to work without a problem... for now?
            'WebGL Aquarium' gives me 4fps with 100 fish
              Is there a GPU?
              This IS still early pre-release days with much in flux, particularly kernels and drivers. If If Nvidia drivers are involved, those can break once in a while while kernels are tweaked. If not, there may be a Mesa package lagging, or missing temporarily. Things like that. I'd wait until there is an official beta if this sort of thing is bothersome.
                Is there a GPU?
                It's a laptop. I'll go back to 25.10 and wait for the release and see what happens.
                  rec9140 ,
                  I have been testing 26.04 resolute racoon daily builds. Not via KVM.
                  Anyway, there is a bug on Calamares Installer that prevents it to be installed using daily build 20260201 and daily build 20260202. At least for me and my setup. The bug happens exactly when doing partitioning setup for the disk. In my case: # erase disk and install #.
                  Daily Build 20263101 is working like a charm.On Index there is not this daily build anymore. Only 2026/02/01 and 2026/02/02.
                  Seems to be also happening for Lubuntu which uses calamares: https://bugs.launchpad.net/ubuntu/+s...s/+bug/2140539
                    OK... installed... So where are we ... so far... NOTE: If you can't handle blunt, to the point posts... move along.. move along... I am not the person who you want to read..... I'd say most have already made that step...
                    X11 RESTORED! - Don't even bother, it ain't happening. Thats the whole reason I am testing this (one last update to everything) , as this appears to be the KDE and Kubuntu swan song for me.. based on their plan to remove X11 in KDE 6.8? or so.. Sigh..
                    Again, no need to attempt to change my view, it taint happening. This is the Rubicon, and I go no further. Don't mind the grinding of axe sound... move along... move along..
                    LightDM installed - XDMCP ENABLED!
                    Synaptic installed
                    Issues:
                    Synaptic - Still the quick search/filter is missing ?? I thought this was restored? Or has not filtered down yet?? YES I installed apt-xapian-index​, still the quick search/filter didn't appear... sighhh. Why do we keep breaking the nice things!
                    X11 Session seems to have several issues, slow response, to clicks, or no response to clicks at all. To get the display size correct, go to Display, select the size, click keep.. NOPE. Couldn't click that.. Had to use xrandr on CLI.. that stuck, thankfully. Repeating this to test things after a reboot of the VM, changing resolution and apply it changes, and stays. NO keep/revert dialog.. Overall it felt "buggy." Glitches here and there, slow click, random clikcs on things when it "caught up" to a click 10 seconds ago or so
                    The above shows that this needs attention on the X11 session. Not good.
                    LightDM - Login Screen/Greeter screen size wrong, but this happens in VBOX and VMW too, sometimes it corrects itself with guest-additions, sometimes not, a quick edit of lightdm.conf, annoying more than anything really, at least for now, in a VM, I don't care but it can at least it can be corrected, well, correctly.
                    Konsole - Where is the memo about removing the menu/tool bar as a default This is a bad move, yeah I think this has been growing since 22.04? or something, and its gotten worse... I am not sure what logic is in this, but it ain't any logic I apply.... shrug...
                    Somethings I have a glitch with as KVM and bridge aka real world networking don't seem to work on anything I tried. Why would any one default to NAT'd networking? For now the virt-manager connection is fine, but long term testing will need that resolved or even use of KVM.. bridge is a simple thing that VBOX and VMW do from the get go.. how is this not included and the default in KVM? ? ? ? ? ?
                    Now to desnap etc... restore Firefox... etc...
                      Yes , it seems lubuntu too. Like claydoh said: " this IS still early pre-release days ", so lets see how it performs in the next daily build or next snapshot.
                      Anyway, i still have a 20263101 daily build and it installs flawless. The problem started from 20260102 daily build.
                        Quick notice, for anyone testing 26.04 the latest update splits the linux-firmware into separate packages, so if you graphics suddenly feel sluggish remember to install linux-firmware-amd-graphics or intel-graphics or nvidia-graphics
                          How does scaling work in 26.04? I'm trying it in a VM and it craps out at 125%. The cursor is no longer aligned. I have display that's 2560x1600 and I would reallyt like to scale it at 150%.
                            mr_raider - You would be better booting from a live flash-drive containing the latest daily image and testing it on bare hardware instead of through a vm which could be causing it's own issues.
                              It's a laptop with nvidia switchable graphics. That has it's own issues in a live environment.
                                Ok trying it on the real deal. If I set display to 2560x1600 which is native, it's clean and crisp but everything is tiny.
                                If I scale the screen to 150%, the fonts are fuzzy and every now and then Sddm just goes black and I can't login.
                                Ideas?
                                There is 1 user viewing this topic.
