Dropbox icon does not show in system tray, with KB 15.04
Pan-Galactic QuordlepleenSo Long, and Thanks for All the Fish
- Jul 2011
- 9625
- Seattle, WA, USA
- Send PM
And then I bought an SSD and did a totally fresh install.
HPLIP crashes with the old message there is no system tray and I still have to do a hot reboot to get a working system.
This makes me wonder what made the icon show up in the original install...
I am not sure my fresh install had anything to do with it.Originally posted by mparillo View PostI finally got my icon. Fresh install of Alpha-2, and followed the Headless CLI Instructions.
[ATTACH=CONFIG]6229[/ATTACH].
It seems to me that as my other VMs / Partitions are being upgraded, the Drop Box Icon is starting to appear everywhere.
For all I know it is a stealthy Drop Box upgrade.
I think most of us are using the backports PPA for updated KDE stuff .
https://launchpad.net/~kubuntu-ppa/+...untu/backports
Do you get an icon from running Dropbox from the K-menu, or double clicking the binary, or is it not loading at login?
I have the standard deb file from dropbox installed, and it does run for me - but I have since upgraded to Wily. I was using 15.04 with kubuntu-backports installed, and it worked there. I am guessing that updating plasma is putting the correct libraries in the correct places for Dropbox to find.
You could try doing the 'headless' install - which simply installs dropbox locally in your home dir, and looks to have a newer dropbox version than the deb file.
https://www.dropbox.com/install?os=lnx
If that doesn't work, then maybe consider upgrading Plasma - which is a good idea in general, major plasma and frameworks upgrades in thereSelf-built: Asus PRIME B550M-K/Ryzen 5600GT/32Gb/Intel ARC B580 12Gb/KDE neon
HP systray still crashes here. I have to kill it and re-launch it after it fails on log-in. Same for Synergy.
Error is "No System Tray found"
and still no dropbox icons either.
Loaded the backports PPA, and Kubuntu locks up while downloading one of the packages. After rebooting it then hangs everytime on bootup. Wiped that install out and did a fresh install without the backports. Still no dropbox icon.
Not too concerned, as I'm still running 14.10 and I know eventually it will appear in 15.04!
OK well, Dropbox mysteriously appeared in the systray this morning after powering up (I did a full shutdown last night) along with chromium and solaar so the tray appears to be working in that regard. However, synergy and hp-systray still cannot find the system tray so I would assume the issue is now those apps.
The only thing I did significant to my system yesterday was install the grive/Google Drive ppa and add a google drive folder to my home. The grive indicator is also in the systray so maybe it pulled in something I was missing.
