hi all ive been trying a kubuntu live disk at a mates and when i try to install i get a few problems
i cant use my pci-e graphics card i have to use on-board dvi and set my display options in the bios to peg as the icp/peg or icp/peg only the peg option works to boot or install Kubuntu all i get is a black screen when i use the dvi port or the vga or the hdmi slot on the graphics card using the live usb i have created using linux live usb creator or my friends live dvd
i downloaded the kubuntu-14.04.2-desktop-amd64.iso
here is my Everest System Summery report
My DXdiag Output
My Nvidia Control Panel Output
--------[ EVEREST Ultimate Edition ]------------------------------------------------------------------------------------
Version EVEREST v5.50.2253 Beta
Benchmark Module 2.5.292.0
Homepage http://www.lavalys.com/
Report Type Report Wizard
Computer ***
Generator ***
Operating System Microsoft Windows 7 Professional 6.1.7601
Date 2015-05-14
Time 03:52
--------[ Summary ]-----------------------------------------------------------------------------------------------------
Computer:
Computer Type ACPI x86-based PC (Mobile)
OS Service Pack Service Pack 1
Internet Explorer 9.11.9600.17691
DirectX DirectX 11.0
Computer Name ***
User Name ***
Logon Domain ***
Date / Time 2015-05-14 / 03:52
Motherboard:
CPU Type DualCore Intel Core i3 530, 2933 MHz (22 x 133)
Motherboard Name Dell Vostro 430
Motherboard Chipset Intel Ibex Peak H57, Intel Ironlake
System Memory 2999 MB (DDR3-1333 DDR3 SDRAM)
DIMM1: Hynix HMT325U6BFR8C-H9 2 GB DDR3-1333 DDR3 SDRAM (8-8-8-22 @ 609 MHz) (7-7-7-20 @ 533 MHz) (6-6-6-17 @ 457 MHz)
DIMM3: Kingston KTW149-ELD 1 GB DDR3-1333 DDR3 SDRAM (8-8-8-22 @ 609 MHz) (7-7-7-20 @ 533 MHz) (6-6-6-17 @ 457 MHz)
BIOS Type AMI (07/06/10)
Communication Port Communications Port (COM1)
Display:
Video Adapter NVIDIA GeForce GT 240 (512 MB)
3D Accelerator nVIDIA GeForce GT 240
Monitor Generic PnP Monitor [NoDB] (16001001)
Monitor Hannspree LM02 [19" LCD] (3093)
Multimedia:
Audio Adapter Creative Audigy SE (SB0570) Sound Card
Audio Adapter nVIDIA HDMI @ nVIDIA GT215 - High Definition Audio Controller
Audio Adapter Realtek ALC662 @ Intel Ibex Peak PCH - High Definition Audio Controller
Storage:
IDE Controller Intel(R) 5 Series/3400 Series Chipset Family 6 Port SATA AHCI Controller - 3B22
Disk Drive MB2000EAMZF ATA Device (1863 GB, IDE)
Disk Drive ST3500312CS ATA Device (500 GB, 5900 RPM, SATA-II)
Disk Drive WDC WD3200AAJS-22B4A0 ATA Device (298 GB, IDE)
Optical Drive DTSOFT Virtual CdRom Device
Optical Drive TSSTcorp DVD+-RW TS-H653H ATA Device
SMART Hard Disks Status OK
Partitions:
C: (NTFS) 298.0 GB (22.4 GB free)
E: (NTFS) 984.1 GB (283.1 GB free)
F: (NTFS) 878.9 GB (124.8 GB free)
G: (NTFS) 465.8 GB (25.2 GB free)
Total Size 2626.8 GB (455.5 GB free)
Input:
Keyboard Standard PS/2 Keyboard
Mouse HID-compliant mouse
Network:
Primary IP Address 192.168.0.2
Primary MAC Address F0-4D-A2-DA-6D-2C
Network Adapter Broadcom NetLink (TM) Gigabit Ethernet (192.168.0.2)
Peripherals:
Printer Enviar Para o OneNote 2013
Printer Fax
Printer Microsoft XPS Document Writer
USB2 Controller Intel Ibex Peak PCH - USB 2.0 EHCI Controller 1
USB2 Controller Intel Ibex Peak PCH - USB 2.0 EHCI Controller 2
USB Device Generic USB Hub
USB Device USB Input Device
DMI:
DMI BIOS Vendor Dell Inc.
DMI BIOS Version 2.2.0
DMI System Manufacturer Dell Inc.
DMI System Product Vostro 430
DMI System Version 00
DMI System Serial Number GSXRX4J
DMI System UUID 44454C4C-53001058-8052C7C0-4F58344A
DMI Motherboard Manufacturer Dell Inc.
DMI Motherboard Product 054KM3
DMI Motherboard Version A01
DMI Motherboard Serial Number ..CN6970209K0590.
DMI Chassis Manufacturer Dell Inc.
DMI Chassis Version
DMI Chassis Serial Number GSXRX4J
DMI Chassis Asset Tag
DMI Chassis Type Desktop Case
--------[ Debug - PCI ]-------------------------------------------------------------------------------------------------
B00 D00 F00: Intel Havendale/Clarkdale Processor - Host Bridge/DRAM Controller
Offset 000: 86 80 40 00 06 00 90 20 18 00 00 06 00 00 00 00
Offset 010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 28 10 26 04
Offset 030: 00 00 00 00 E0 00 00 00 00 00 00 00 00 00 00 00
Offset 040: 01 90 D1 FE 00 00 00 00 01 40 D1 FE 00 00 00 00
Offset 050: 00 00 02 00 03 00 00 00 00 00 00 00 00 00 00 00
Offset 060: 00 00 00 00 00 00 00 00 01 80 D1 FE 00 00 00 00
Offset 070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 090: 00 00 00 00 00 00 00 00 FF 03 00 00 00 00 00 00
Offset 0A0: 30 00 C0 0B 00 00 00 00 00 00 00 00 00 00 80 BB
Offset 0B0: 00 BC 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 0D0: 00 00 00 00 03 03 00 00 00 00 00 00 00 00 00 82
Offset 0E0: 09 00 0C 01 2D A0 81 88 88 00 46 01 00 00 00 00
Offset 0F0: 00 00 00 00 0D 00 00 00 AB 0F 18 00 00 00 00 00
B00 D01 F00: Intel Havendale/Clarkdale Processor - PCI Express Graphics Root Port
Offset 000: 86 80 41 00 07 01 10 00 18 00 04 06 08 00 01 00
Offset 010: 00 00 00 00 00 00 00 00 00 01 01 00 D0 D0 00 20
Offset 020: 00 FA E0 FB 01 CE F1 DF 00 00 00 00 00 00 00 00
Offset 030: 00 00 00 00 88 00 00 00 00 00 00 00 10 01 1A 00
Offset 040: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 050: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02
Offset 080: 01 90 03 C8 08 00 00 00 0D 80 00 00 28 10 26 04
Offset 090: 05 A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 0A0: 10 00 42 01 00 80 00 00 00 00 00 00 02 2D 21 02
Offset 0B0: 40 00 02 51 00 00 04 00 00 00 48 00 00 00 00 00
Offset 0D0: 42 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 07 00 00 00
Offset 0F0: 00 00 01 00 03 01 3E 80 AB 0F 18 00 04 F0 10 F0
B00 D16 F00: Intel Ibex Peak PCH - Host Embedded Controller Interface 1 (HECI1)
Offset 000: 86 80 64 3B 06 00 10 00 06 00 80 07 00 00 80 00
Offset 010: 04 FC FF F9 00 00 00 00 00 00 00 00 00 00 00 00
Offset 030: 00 00 00 00 50 00 00 00 00 00 00 00 10 01 00 00
Offset 040: 45 02 00 00 20 00 01 80 00 00 00 60 00 00 00 00
Offset 050: 01 8C 03 C8 08 00 00 00 00 00 00 00 00 00 00 00
Offset 080: 00 00 00 00 00 00 00 00 00 00 00 00 05 00 80 00
Offset 090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 0A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 02 00 00 C0
Offset 0C0: B4 F4 73 91 0B 1E AA A4 FE 1F 6D 41 AD C0 35 BD
Offset 0D0: E5 D5 F1 32 B0 11 49 78 CD 9C 76 E5 8D 85 BD B2
Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B00 D1A F00: Intel Ibex Peak PCH - USB 2.0 EHCI Controller 2
Offset 000: 86 80 3C 3B 06 00 90 02 06 20 03 0C 00 00 00 00
Offset 010: 00 00 C0 F9 00 00 00 00 00 00 00 00 00 00 00 00
Offset 050: 01 58 C2 C9 00 80 00 00 0A 98 A0 20 00 00 00 00
Offset 060: 20 20 FF 07 00 00 00 00 01 00 00 00 00 20 00 C0
Offset 070: 01 00 DE 3F 00 00 00 00 00 00 00 00 00 00 00 00
Offset 080: 00 00 80 00 11 89 0C 13 A0 00 00 00 00 00 00 00
Offset 090: 00 00 00 00 00 00 00 00 13 00 06 03 00 00 00 00
Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 0D0: 00 00 00 00 00 AA FF 00 00 00 00 00 00 00 00 00
Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 84 60 4C B9
Offset 0F0: 00 00 00 00 88 85 8C 00 87 0F 06 08 28 17 5B 30
B00 D1B F00: Intel Ibex Peak PCH - High Definition Audio Controller
Offset 000: 86 80 56 3B 06 00 10 00 06 00 03 04 08 00 00 00
Offset 010: 04 80 FF F9 00 00 00 00 00 00 00 00 00 00 00 00
Offset 030: 00 00 00 00 50 00 00 00 00 00 00 00 16 01 00 00
Offset 040: 01 00 00 07 01 00 00 00 00 00 00 00 00 00 00 00
Offset 050: 01 60 42 C8 00 00 00 00 00 00 00 00 00 00 00 00
Offset 060: 05 70 80 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 070: 10 00 91 00 00 00 00 10 00 08 10 00 00 00 00 00
Offset 0C0: 00 04 00 01 00 00 00 00 05 00 09 02 10 70 30 16
Offset 0D0: 0B 00 91 06 10 00 31 16 00 00 00 00 00 00 00 00
Offset 0F0: 00 00 00 00 00 00 00 00 87 0F 06 08 00 00 00 00
B00 D1C F00: Intel Ibex Peak PCH - PCI Express Root Port 1
Offset 000: 86 80 42 3B 06 01 10 00 06 00 04 06 08 00 81 00
Offset 010: 00 00 00 00 00 00 00 00 00 02 02 00 F0 00 00 00
Offset 020: F0 FB F0 FB F1 FF 01 00 00 00 00 00 00 00 00 00
Offset 030: 00 00 00 00 40 00 00 00 00 00 00 00 11 01 02 00
Offset 040: 10 80 42 01 00 80 00 00 00 00 10 00 11 4C 11 01
Offset 050: 00 00 11 30 60 05 04 04 00 00 48 01 00 00 00 00
Offset 060: 00 00 00 00 16 00 00 00 00 00 00 00 00 00 00 00
Offset 070: 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 080: 05 90 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 090: 0D A0 00 00 28 10 26 04 00 00 00 00 00 00 00 00
Offset 0A0: 01 00 02 C8 00 01 00 00 00 00 00 00 00 00 00 00
Offset 0D0: 00 10 00 00 00 00 00 00 00 00 11 00 00 00 00 00
Offset 0E0: 00 0F 00 00 06 07 08 00 31 00 00 00 00 00 00 00
B00 D1D F00: Intel Ibex Peak PCH - USB 2.0 EHCI Controller 1
Offset 000: 86 80 34 3B 06 00 90 02 06 20 03 0C 00 00 00 00
Offset 010: 00 00 A0 F9 00 00 00 00 00 00 00 00 00 00 00 00
Offset 030: 00 00 00 00 50 00 00 00 00 00 00 00 17 01 00 00
Offset 050: 01 58 C2 C9 00 00 00 00 0A 98 A0 20 00 00 00 00
Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 84 90 5B B9
B00 D1E F00: Intel H57 Platform Controller Hub
Offset 000: 86 80 4E 24 07 01 10 00 A6 01 04 06 00 00 01 00
Offset 010: 00 00 00 00 00 00 00 00 00 03 03 20 E0 E0 80 22
Offset 020: F0 FF 00 00 F1 FF 01 00 00 00 00 00 00 00 00 00
Offset 030: 00 00 00 00 50 00 00 00 00 00 00 00 FF 00 02 00
Offset 040: 00 00 00 00 00 00 00 00 00 00 00 00 00 12 00 10
Offset 050: 0D 00 00 00 28 10 26 04 00 00 00 00 00 00 00 00
Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B00 D1F F00: Intel H57 - LPC Bridge
Offset 000: 86 80 08 3B 07 00 10 02 06 00 01 06 00 00 80 00
Offset 040: 01 08 00 00 80 00 00 00 01 05 00 00 10 00 00 00
Offset 050: F8 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 060: 8A 85 83 8B D0 00 00 00 80 80 8F 8E F8 00 00 00
Offset 070: F8 00 F8 00 F8 00 F8 00 F8 00 F8 00 F8 00 F8 00
Offset 080: 00 00 09 24 01 0A FC 00 00 00 00 00 00 00 00 00
Offset 090: 00 00 00 00 00 0F 00 00 00 00 00 00 00 00 00 00
Offset 0A0: 08 06 00 00 48 00 06 00 00 45 00 00 00 03 00 00
Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 08 00 00 00 00
Offset 0D0: 33 22 11 00 67 45 00 00 C0 F0 00 00 08 00 00 00
Offset 0E0: 09 00 10 11 91 00 E4 04 00 A4 00 58 06 04 F8 02
Offset 0F0: 01 C0 D1 FE 00 00 00 00 87 0F 06 08 00 00 00 00
B00 D1F F02: Intel Ibex Peak PCH - 6-port SATA AHCI Controller
Offset 000: 86 80 22 3B 07 00 B0 02 06 01 06 01 00 00 00 00
Offset 010: 01 CC 00 00 81 C8 00 00 01 C8 00 00 81 C4 00 00
Offset 020: 01 C4 00 00 00 00 80 F9 00 00 00 00 28 10 26 04
Offset 030: 00 00 00 00 80 00 00 00 00 00 00 00 13 02 00 00
Offset 040: 00 80 00 80 00 00 00 00 00 00 00 00 00 00 00 00
Offset 070: 01 A8 03 40 08 00 00 00 00 00 00 00 00 00 00 00
Offset 080: 05 70 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 090: 60 00 3F 8F 83 01 00 00 20 02 59 00 00 00 00 00
Offset 0A0: 00 00 00 00 00 00 00 00 12 B0 10 00 48 00 00 00
Offset 0B0: 13 00 06 03 00 00 00 00 00 00 00 00 00 00 00 00
B00 D1F F03: Intel Ibex Peak PCH - SMBus Controller
Offset 000: 86 80 30 3B 03 00 80 02 06 00 05 0C 00 00 00 00
Offset 010: 04 F8 FF F9 00 00 00 00 00 00 00 00 00 00 00 00
Offset 020: 01 04 00 00 00 00 00 00 00 00 00 00 28 10 26 04
Offset 030: 00 00 00 00 00 00 00 00 00 00 00 00 03 03 00 00
Offset 040: 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 060: 03 04 04 00 00 00 08 08 00 00 00 00 00 00 00 00
Offset 080: 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B00 D1F F06: Intel Ibex Peak PCH - Thermal Sensor
Offset 000: 86 80 32 3B 00 00 10 00 06 00 80 11 00 00 00 00
Offset 010: 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 030: 00 00 00 00 50 00 00 00 00 00 00 00 00 03 00 00
Offset 040: 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 050: 01 80 23 00 08 00 00 00 00 00 00 00 00 00 00 00
Offset 080: 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B01 D00 F00: XFX GeForce GT 240 Video Adapter
Offset 000: DE 10 A3 0C 07 00 10 00 A2 00 00 03 08 00 80 00
Offset 010: 00 00 00 FA 0C 00 00 D0 00 00 00 00 0C 00 00 CE
Offset 020: 00 00 00 00 01 DC 00 00 00 00 00 00 82 16 01 30
Offset 030: 00 00 00 00 60 00 00 00 00 00 00 00 10 01 00 00
Offset 040: 82 16 01 30 00 00 00 00 00 00 00 00 00 00 00 00
Offset 050: 01 00 00 00 01 00 00 00 CE D6 23 00 00 00 00 00
Offset 060: 01 68 03 00 08 00 00 00 05 78 80 00 00 00 00 00
Offset 070: 00 00 00 00 00 00 00 00 10 B4 02 00 E0 8D 00 00
Offset 080: 10 29 00 00 02 3D 05 00 48 01 02 11 00 00 00 00
Offset 090: 00 00 00 00 00 00 00 00 00 00 00 00 10 00 00 00
Offset 0A0: 00 00 00 00 00 00 00 00 01 00 01 00 00 00 00 00
Offset 0B0: 00 00 00 00 09 00 14 01 00 00 00 00 00 00 00 00
B01 D00 F01: nVIDIA GT215 - High Definition Audio Controller
Offset 000: DE 10 E4 0B 06 00 10 00 A1 00 03 04 08 00 80 00
Offset 010: 00 00 C0 FB 00 00 00 00 00 00 00 00 00 00 00 00
Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 82 16 01 30
Offset 030: 00 00 00 00 60 00 00 00 00 00 00 00 11 02 00 00
Offset 050: 00 00 00 00 00 00 00 00 CE D6 23 00 00 00 00 00
Offset 070: 00 00 00 00 00 00 00 00 10 00 02 00 A0 8D 00 00
Offset 080: 10 29 00 00 02 3D 04 00 0B 01 02 11 00 00 00 00
Offset 0A0: 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00
B02 D00 F00: Broadcom NetLink BCM57780 PCI-E Gigabit Ethernet Controller
Offset 000: E4 14 92 16 06 04 10 00 01 00 00 02 08 00 00 00
Offset 010: 04 00 FF FB 00 00 00 00 00 00 00 00 00 00 00 00
Offset 030: 00 00 00 00 48 00 00 00 00 00 00 00 00 01 00 00
Offset 040: 00 00 00 00 00 00 00 00 01 60 03 C0 08 21 00 16
Offset 050: 05 CC 81 00 0C F0 E0 FE 00 00 00 00 B0 49 00 00
Offset 060: 09 50 6C 00 D3 C9 D4 31 98 02 01 F0 00 00 1B 76
Offset 070: 92 10 00 00 00 00 00 00 14 70 00 00 F0 0D 00 00
Offset 080: 00 82 00 02 00 00 00 00 34 00 13 04 82 40 08 00
Offset 090: 19 49 00 01 00 00 00 F1 00 00 00 00 B8 00 00 00
Offset 0A0: 00 00 00 00 F4 01 00 00 00 00 00 00 66 01 00 00
Offset 0B0: 00 00 00 00 00 00 00 1B 00 00 00 00 01 00 78 57
Offset 0C0: 00 00 00 00 E4 14 92 16 0E 00 00 00 10 00 02 00
Offset 0D0: A0 8F 28 00 00 50 10 00 11 CC 06 00 00 00 11 10
Offset 0F0: 1F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B03 D01 F00: Creative Audigy SE (SB0570) Sound Card
Offset 000: 02 11 07 00 05 00 90 02 00 00 01 04 00 40 00 00
Offset 010: 01 EC 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 02 11 0A 10
Offset 030: 00 00 00 00 DC 00 00 00 00 00 00 00 11 01 02 14
Offset 040: 00 00 00 00 00 00 00 00 00 00 00 00 00 82 00 00
Offset 050: 03 80 00 00 FF FF 00 00 00 00 00 00 00 00 00 00
Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 01 00 22 06
BFF D00 F00: Intel QuickPath Architecture - Generic Non-Core Registers
Offset 000: 86 80 61 2C 06 00 00 00 05 00 00 06 00 00 80 00
Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 86 80 86 80
Offset 030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 060: 20 02 02 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 080: 00 00 00 00 00 00 00 00 01 04 00 00 00 00 00 00
Offset 0C0: 10 0C 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 0D0: 80 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00
BFF D00 F01: Intel QuickPath Architecture - System Address Decoder (SAD)
Offset 000: 86 80 01 2D 06 00 00 00 05 00 00 06 00 00 80 00
Offset 040: 10 11 11 00 00 31 13 00 00 00 00 00 00 12 00 00
Offset 050: 01 00 00 E0 00 00 00 00 00 00 00 00 00 00 00 00
Offset 060: 00 00 E0 BB 00 00 00 00 00 0C E0 FF FF 00 00 00
Offset 080: 83 0B 00 00 C2 0F 00 00 C2 0F 00 00 C2 0F 00 00
Offset 090: C2 0F 00 00 C2 0F 00 00 C2 0F 00 00 C2 0F 00 00
BFF D02 F00: Intel QuickPath Interconnect - QPI Link 0 Control
Offset 000: 86 80 10 2D 06 00 00 00 05 00 00 06 00 00 80 00
Offset 040: 00 01 8F 08 00 00 00 00 00 00 14 00 00 00 00 00
Offset 050: 00 00 00 86 00 00 00 00 55 45 06 00 00 00 00 00
Offset 0C0: 00 00 5F 00 85 06 00 00 00 00 00 F3 00 00 00 00
Offset 0D0: 01 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00
BFF D02 F01: Intel QuickPath Interconnect - QPI Physical 0 Control
Offset 000: 86 80 11 2D 06 00 00 00 05 00 00 06 00 00 80 00
Offset 040: 09 00 FF F0 01 00 80 0B 00 00 10 00 73 02 00 00
Offset 050: 16 01 0C 16 16 00 00 00 01 00 00 00 01 00 00 00
Offset 060: 00 00 00 00 00 00 00 00 00 51 C3 10 A0 A0 40 00
Offset 070: 00 00 00 00 FF FF 0F 80 00 00 00 00 FF FF 0F 00
Offset 080: 03 0C 0C 07 00 00 00 00 01 00 00 00 01 00 0F 0F
Offset 090: 82 00 00 00 02 02 02 00 08 08 88 08 02 05 00 00
Offset 0A0: 00 56 00 00 03 2C 1D 00 84 00 00 06 02 00 00 00
Offset 0B0: 77 15 AE 4D 00 00 00 00 00 00 00 00 01 00 00 00
Offset 0D0: 0A 0C 0A 0C 00 00 00 00 00 00 00 00 03 00 08 00
Offset 0E0: 00 00 02 00 00 00 40 00 00 00 82 24 00 00 00 00
Offset 0F0: 00 00 00 00 42 01 00 00 00 00 00 00 00 00 00 00
BFF D02 F02: Intel QuickPath Interconnect - Flexible Display Interface
Offset 000: 86 80 12 2D 06 00 00 00 05 00 00 06 00 00 80 00
BFF D02 F03: Intel QuickPath Interconnect - Flexible Display Interface
Offset 000: 86 80 13 2D 06 00 00 00 05 00 00 06 00 00 80 00
PCI-8086-0040: Intel Ironlake MCHBAR
Offset 100: 00 04 00 04 00 08 00 00 00 00 00 00 00 00 00 00
Offset 110: 00 60 00 00 40 44 02 02 01 00 00 00 00 00 00 00
Offset 120: 9F 7F 8E 38 73 60 13 40 05 0D 9A 02 9F 56 31 00
Offset 130: 02 13 11 F1 00 60 85 00 78 08 08 02 0F 0F 1F 11
Offset 140: 78 10 10 02 11 11 1F 10 08 07 25 2E 0E 0F 13 0F
Offset 150: 1C 00 17 EE 08 07 27 3F 0E 0F 12 0F 12 00 15 B4
Offset 160: FF FF FF 05 26 00 00 00 00 00 00 00 14 24 24 48
Offset 170: 08 08 08 08 33 43 00 00 00 00 00 00 00 FF FF FF
Offset 180: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 190: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 1A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 1B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 1C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 1D0: 3D 03 00 40 02 00 00 00 00 00 00 00 00 00 00 00
Offset 1E0: 00 00 00 00 00 00 00 00 04 00 00 00 00 00 00 00
Offset 1F0: 88 59 00 1D 00 00 02 00 00 00 00 00 00 00 00 00
Offset 200: 20 00 20 00 20 00 20 00 88 00 00 00 00 00 00 00
Offset 210: 20 00 0D 00 00 3E 00 00 00 00 00 00 00 00 00 00
Offset 220: 07 00 00 58 00 02 45 10 01 00 00 00 00 00 00 00
Offset 230: 00 00 0A 00 04 00 04 01 02 20 00 00 00 00 03 00
Offset 240: 46 20 00 01 10 97 1A 00 00 00 84 08 00 32 03 00
Offset 250: 55 05 6C 32 89 05 7A 94 47 05 13 6C 12 18 A5 1D
Offset 260: FF 01 1A 0C FF 00 0E 04 00 50 D4 CF 35 3F 24 03
Offset 270: 00 0E 55 01 06 00 05 00 42 20 36 0C 62 00 00 8B
Offset 280: 00 00 00 00 00 00 00 00 40 50 60 70 80 C0 FE FF
Offset 290: 1C 09 82 02 00 00 01 00 01 00 00 00 7A 07 00 00
Offset 2A0: 17 17 FF FA 48 48 30 00 04 0D 0D 06 1A 22 0B 2D
Offset 2B0: 6E 95 00 00 20 40 00 00 00 28 0A 00 70 70 70 01
Offset 2C0: 00 CC 09 60 8C 00 00 00 00 00 00 00 00 00 00 00
Offset 2D0: 00 01 20 00 00 44 50 04 00 00 00 00 00 00 00 00
Offset 2E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 2F0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Offset 500: 33 01 00 80 00 04 00 00 D0 04 08 1A 00 00 00 00
Offset 510: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 520: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 530: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 540: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 550: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 560: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 570: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 580: 1E C0 01 82 FF FF 0F 00 00 00 04 00 06 00 86 00
Offset 590: 82 12 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 5A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 5B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 5C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 5D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 5E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 5F0: 00 00 00 00 01 00 00 00 08 00 00 00 00 00 00 80
Offset 600: 10 00 10 00 10 00 10 00 86 00 00 00 00 00 00 00
Offset 610: BC 84 00 01 FF 0F 85 02 00 00 00 00 00 00 00 00
Offset 620: 07 00 00 58 00 02 45 10 01 00 00 00 00 09 00 00
Offset 630: 00 00 00 00 00 00 00 01 02 20 00 00 00 00 00 00
Offset 640: 46 20 00 01 10 97 3A 00 00 00 84 08 00 32 03 00
Offset 650: 55 05 6C 32 89 05 7A 94 47 05 13 6C 12 18 A5 1D
Offset 660: FF 01 1A 0C FF 00 0E 04 00 50 D4 CF 35 3F 24 03
Offset 670: 00 0E 55 01 06 00 05 00 42 20 36 0C 62 00 00 8B
Offset 680: 00 00 00 00 00 00 00 00 40 50 60 70 80 C0 FE FF
Offset 690: 1C 09 82 02 00 00 01 00 01 00 00 00 7A 07 00 00
Offset 6A0: 17 17 FF FA 48 48 30 00 04 0D 0D 06 1A 22 0B 2D
Offset 6B0: 6E 95 00 00 20 40 00 00 00 28 0A 00 70 70 70 01
Offset 6C0: A0 14 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 6D0: 00 80 00 00 F9 00 01 00 F9 FD 11 00 F6 FC 33 00
Offset 6E0: FD 00 01 00 F7 00 01 00 00 FA 34 00 00 00 00 00
Offset 6F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 900: 33 01 00 80 00 04 00 00 E6 04 08 1A 00 00 00 00
Offset 910: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 920: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 930: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 940: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 950: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 960: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 970: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 980: 1E C0 49 81 FF FF 0F 00 00 00 04 00 06 00 86 00
Offset 990: 82 12 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 9A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 9B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 9C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 9D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 9E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 9F0: 00 00 00 00 00 00 00 00 08 00 00 00 00 00 00 00
Offset 1100: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 1110: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 1120: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 1130: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 1140: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 1150: 15 22 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 1160: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 1170: 80 90 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 2C00: C0 08 04 00 00 00 00 00 00 00 00 00 00 36 05 00
Offset 2C10: 16 04 3A 31 00 00 40 00 00 00 00 00 00 00 00 00
Offset 2C20: 14 00 3A 30 00 00 00 00 00 02 00 00 00 00 00 00
--------[ Debug - Video BIOS ]------------------------------------------------------------------------------------------
C000:0000 U.l.K7400.L.w.VIDEO ..........IBM VGA Compatible......}K11/02/09
C000:0040 ................. *....0...............7....B..BPMIDl.o.......
C000:0080 .....3GT215 P672 SKU 0001 VGA BIOS..............................
C000:00C0 .......................Version 70.15.27.00.50 ...Copyright (C) 1
C000:0100 996-2009 NVIDIA Corp........fA....GT215 Board - 06720001........
C000:0140 .....Chip Rev ................................................
C000:0180 ........PCIR............l.......HYB$..BIT......D2...2.B. .>.C...
C000:01C0 ^.D...l.A...p.I...s.L.....M.....N.....P.(...S.....T.....U.....V.
C000:0200 ....c.....x.....d.....p.....i.A.....).EF.Z._...................'
C000:0240 .pP8................\\"...6...........aG8....I.@...UHaHgHHoI.Ia
C000:0280 H...ICN.JG.G.c...d..._...`..,b..kc...c.......c...~......^c....P.
C000:02C0 ....(EF.YF#".#E..kJ.F./G.F...........B...'.p.....J.4...10/22/09.
C000:0300 ........................450.06720001.......v.......D.=...w.q.q..
C000:0340 .../....Z .v.......D.=...w.q.q.,...x..Z1.d.d...5.d.....y...X....
C000:0380 .G.....L.X.'...Q.P.D.........c...d.d...d.d.d...a.d.w.B.f........
C000:03C0 .......n.v...q...u.t.P...X.x.=.z...................q.q...F.)...d
--------[ Debug - Unknown ]---------------------------------------------------------------------------------------------
HDD MB2000EAMZF ATA Device
Monitor ID MST0B01: Generic PnP Monitor [NoDB]
Monitor Model Mstar Demo
The names of actual companies and products mentioned herein may be the trademarks of their respective owners.
------------------System Information
Time of this report: 5/14/2015, 03:55:09
Machine name:***
Operating System: Windows 7 Professional 32-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_ldr.150202-1521)
Language: English (Regional Setting: English)
System Manufacturer: Dell Inc.
System Model: Vostro 430
BIOS: Default System BIOS
Processor: Intel(R) Core(TM) i3 CPU 530 @ 2.93GHz (4 CPUs), ~2.9GHz
Memory: 3072MB RAM
Available OS Memory: 3000MB RAM
Page File: 3719MB used, 2276MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7601.17514 32bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Display Tab 2: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce GT 240
Manufacturer: NVIDIA
Chip type: GeForce GT 240
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_0CA3&SUBSYS_30011682&REV_A2
Display Memory: 1710 MB
Dedicated Memory: 466 MB
Shared Memory: 1243 MB
Current Mode: 1280 x 720 (32 bit) (60Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: Mstar Demo
Monitor Id: MST0B01
Native Mode: 1280 x 720(p) (60.000Hz)
Output Type: HDMI
Driver Name: nvd3dum.dll,nvwgf2um.dll,nvwgf2um.dll
Driver File Version: 9.18.0013.4144 (English)
Driver Version: 9.18.13.4144
DDI Version: 10.1
Driver Model: WDDM 1.1
Driver Attributes: Final Retail
Driver Date/Size: 2/4/2015 04:35:16, 14497760 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B71E3E-4FE3-11CF-0265-0C101FC2C435}
Vendor ID: 0x10DE
Device ID: 0x0CA3
SubSys ID: 0x30011682
Revision ID: 0x00A2
Driver Strong Name: oem2.inf:NVIDIA_SetA_Devices.NTx86.6.1:Section002:9.18.13.4144:pci\ven_10de&dev_0ca3
Rank Of Driver: 00E02001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeVC1_C ModeWMV9_C
Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
D3D9 Overlay: Supported
DXVA-HD: Supported
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
Current Mode: 1440 x 900 (32 bit) (60Hz)
Monitor Model: LM02
Monitor Id: HSP0013
Native Mode: 1440 x 900(p) (59.887Hz)
Output Type: DVI
DDI Version: 10.1
WHQL Logo'd: Yes
WHQL Date Stamp:
Vendor ID: 0x10DE
Device ID: 0x0CA3
Revision ID: 0x00A2
DXVA-HD: Supported
D3D Status: Enabled
AGP Status: Enabled
Sound Devices
Description: Mstar Demo-1 (NVIDIA High Definition Audio)
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: HDAUDIO\FUNC_01&VEN_10DE&DEV_000D&SUBSYS_10DE0101&REV_1001
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: nvhda32v.sys
Driver Version: 1.03.0030.0001 (English)
WHQL Logo'd: Yes
Date and Size: 2/11/2015 11:38:39, 162592 bytes
Other Files:
Driver Provider: NVIDIA Corporation
HW Accel Level: Basic
Cap Flags: 0xF1F
Min/Max Sample Rate: 100, 200000
Static/Strm HW Mix Bufs: 1, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Description: Digital Audio (S/PDIF) (2- High Definition Audio Device)
Default Sound Playback: No
Default Voice Playback: No
Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0662&SUBSYS_10280426&REV_1001
Manufacturer ID: 1
Product ID: 65535
Type: WDM
Driver Name: HdAudio.sys
Driver Version: 6.01.7601.17514 (English)
WHQL Logo'd: Yes
Date and Size: 11/20/2010 22:29:03, 304128 bytes
Other Files:
Driver Provider: Microsoft
Cap Flags: 0xF1F
HW Memory: 0
Sound Capture Devices
Description: Microphone (SB Audigy)
Default Sound Capture: Yes
Default Voice Capture: Yes
Driver Name: P17.sys
Driver Version: 5.12.0001.2020 (English)
Date and Size: 10/16/2009 11:11:56, 1168896 bytes
Cap Flags: 0x1
Format Flags: 0xFFFFF
Description: Line-In (SB Audigy)
Default Sound Capture: No
Default Voice Capture: No
Cap Flags: 0x1
Description: S/PDIF-In (SB Audigy)
Cap Flags: 0x1
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x8086, 0x3B34
| Matching Device ID: usb\root_hub20
| Service: usbhub
| Driver: usbhub.sys, 11/27/2013 02:14:25, 258560 bytes
| Driver: usbd.sys, 11/27/2013 02:13:33, 6016 bytes
+-+ Generic USB Hub
| | Vendor/Product ID: 0x8087, 0x0020
| | Matching Device ID: usb\class_09
| | Service: usbhub
| +-+ USB Input Device
| | | Vendor/Product ID: 0x093A, 0x2516
| | | Matching Device ID: generic_hid_device
| | | Service: HidUsb
| | | Driver: hidusb.sys, 11/20/2010 22:29:03, 24064 bytes
| | | Driver: hidclass.sys, 7/2/2013 04:45:48, 55808 bytes
| | | Driver: hidparse.sys, 7/2/2013 04:45:45, 25728 bytes
| | +-+ HID-compliant mouse
| | | | Matching Device ID: hid_device_system_mouse
| | | | Service: mouhid
| | | | Driver: mouhid.sys, 7/14/2009 00:45:08, 26112 bytes
| | | | Driver: mouclass.sys, 7/14/2009 02:20:44, 41552 bytes
Gameport Devices
PS/2 Devices
+ Standard PS/2 Keyboard
| Matching Device ID: *pnp0303
| Service: i8042prt
| Driver: i8042prt.sys, 7/14/2009 00:11:24, 80896 bytes
| Driver: kbdclass.sys, 7/14/2009 02:20:36, 42576 bytes
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
| Driver: termdd.sys, 11/20/2010 22:29:03, 53120 bytes
| Driver: sermouse.sys, 7/14/2009 00:45:08, 19968 bytes
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 22.9 GB
Total Space: 305.1 GB
File System: NTFS
Model: WDC WD3200AAJS-22B4A0 ATA Device
Drive: E:
Free Space: 289.9 GB
Total Space: 1007.7 GB
File System: NTFS
Model: MB2000EAMZF ATA Device
Drive: F:
Free Space: 127.8 GB
Total Space: 900.0 GB
File System: NTFS
Drive: G:
Free Space: 25.8 GB
Total Space: 476.9 GB
File System: NTFS
Model: ST3500312CS ATA Device
Drive: D:
Model: TSSTcorp DVD+-RW TS-H653H ATA Device
Driver: c:\windows\system32\drivers\cdrom.sys, 6.01.7601.17514 (English), 11/20/2010 22:29:03, 108544 bytes
Drive: J:
Model: DTSOFT Virtual CdRom Device
Drive: K:
Drive: H:
Drive: I:
System Devices
Device ID: PCI\VEN_1102&DEV_0007&SUBSYS_100A1102&REV_00\4&BFE443D&0&08F0
Driver: C:\Windows\system32\drivers\P17.sys, 5.12.0001.2020 (English), 10/16/2009 11:11:56, 1168896 bytes
Driver: C:\Windows\system32\P17res.dll, 5.12.0001.2001 (English), 2/26/2009 10:36:34, 140800 bytes
Driver: C:\Windows\system32\P17APO32.dll, 1.00.0006.0000 (English), 4/21/2009 11:38:30, 506368 bytes
Driver: C:\Windows\system32\P17pld32.dll, 1.00.0006.0000 (English), 4/21/2009 11:38:50, 47104 bytes
Driver: C:\Windows\system32\OemSpiE.dll, 1.00.0012.0004 (English), 8/13/2009 16:19:42, 144384 bytes
Driver: C:\Windows\system32\P17RunE.dll, 1.00.0001.0002 (English), 3/28/2008 16:57:30, 14848 bytes
Driver: C:\Windows\P17EP.ini, 11/13/2008 15:07:24, 2177 bytes
Driver: C:\Windows\P17EPLS.ini, 6/7/2007 14:25:42, 1578 bytes
Driver: C:\Windows\P17EP51.ini, 12/4/2007 14:20:30, 1489 bytes
Driver: C:\Windows\ResDefE.exe, 2.00.0005.0000 (English), 8/26/2008 17:30:32, 8704 bytes
Driver: C:\Windows\system32\AddCat.exe, 1.00.0000.0001 (English), 12/4/2006 22:56:48, 42496 bytes
Driver: C:\Windows\system32\P17APO32.p17, 4/21/2009 11:38:06, 8035 bytes
Driver: C:\Windows\system32\APOIM32.exe, 2.53.0000.0000 (English), 8/25/2009 11:31:18, 613503 bytes
Driver: C:\Windows\system32\AppSetup.exe, 1.00.0024.0003 (English), 4/21/2009 19:37:06, 32177128 bytes
Driver: C:\Windows\system32\ctzapxx.ini, 3/8/2005 15:17:00, 54 bytes
Driver: C:\Windows\system32\ludap17.ini, 10/16/2009 15:50:54, 3930 bytes
Driver: C:\Windows\system32\ctcoins1.dll, 3.00.0002.0051 (English), 7/28/2009 22:09:06, 86016 bytes
Driver: C:\Windows\system32\ctdvins1.dll, 0.05.0000.0051 (English), 7/28/2009 22:09:08, 181760 bytes
Driver: C:\Windows\system32\drivers\drmk.sys, 6.01.7601.18276 (English), 10/4/2013 02:49:41, 81408 bytes
Driver: C:\Windows\system32\drivers\portcls.sys, 6.01.7601.18276 (English), 10/4/2013 02:17:08, 177152 bytes
Name: Intel(R) H57 Express Chipset LPC Interface Controller - 3B08
Device ID: PCI\VEN_8086&DEV_3B08&SUBSYS_04261028&REV_06\3&11583659&0&F8
Driver: C:\Windows\system32\DRIVERS\msisadrv.sys, 6.01.7600.16385 (English), 7/14/2009 02:20:43, 13888 bytes
Name: NVIDIA GeForce GT 240
Device ID: PCI\VEN_10DE&DEV_0CA3&SUBSYS_30011682&REV_A2\4&103E700&0&0008
Driver: C:\Program Files\NVIDIA Corporation\Drs\dbInstaller.exe, 9.18.0013.4144 (English), 2/4/2015 04:35:16, 382280 bytes
Driver: C:\Program Files\NVIDIA Corporation\Drs\nvdrsdb.bin, 2/4/2015 04:35:16, 1236888 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_x86_neutral_4e20ce473c1dec8e\NvCplSetupInt.exe, 1.00.0004.0000 (English), 2/4/2015 04:35:16, 80363560 bytes
Driver: C:\Program Files\NVIDIA Corporation\license.txt, 2/4/2015 04:35:16, 21904 bytes
Driver: C:\Program Files\NVIDIA Corporation\OpenCL\OpenCL.dll, 1.00.0000.0000 (English), 2/4/2015 04:35:16, 60744 bytes
Driver: C:\Windows\system32\DRIVERS\nvlddmkm.sys, 9.18.0013.4144 (English), 2/4/2015 04:35:16, 10702664 bytes
Driver: C:\Windows\system32\NvFBC.dll, 6.14.0013.4144 (English), 2/4/2015 04:35:16, 870032 bytes
Driver: C:\Windows\system32\NvIFR.dll, 6.14.0013.4144 (English), 2/4/2015 04:35:16, 908432 bytes
Driver: C:\Windows\system32\nvapi.dll, 9.18.0013.4144 (English), 2/4/2015 04:35:16, 2824176 bytes
Driver: C:\Windows\system32\nvcompiler.dll, 8.17.0013.4144 (English), 2/4/2015 04:35:16, 15294096 bytes
Driver: C:\Windows\system32\nvcuda.dll, 8.17.0013.4144 (English), 2/4/2015 04:35:16, 11209376 bytes
Driver: C:\Windows\system32\nvcuvid.dll, 7.17.0013.4144 (English), 2/4/2015 04:35:16, 3987784 bytes
Driver: C:\Windows\system32\nvd3dum.dll, 9.18.0013.4144 (English), 2/4/2015 04:35:16, 14497760 bytes
Driver: C:\Windows\system32\nvinfo.pb, 2/4/2015 04:35:16, 21015 bytes
Driver: C:\Windows\system32\nvoglv32.dll, 9.18.0013.4144 (English), 2/4/2015 04:35:16, 24199824 bytes
Driver: C:\Windows\system32\nvopencl.dll, 8.17.0013.4144 (English), 2/4/2015 04:35:16, 11272048 bytes
Driver: C:\Windows\system32\nvwgf2um.dll, 9.18.0013.4144 (English), 2/4/2015 04:35:16, 16128576 bytes
Driver: C:\Windows\system32\nvdispco3234144.dll, 2.00.0041.0004 (English), 2/4/2015 04:35:16, 1060680 bytes
Driver: C:\Windows\system32\nvdispgenco3234144.dll, 2.00.0019.0002 (English), 2/4/2015 04:35:16, 911504 bytes
Name: Intel(R) Management Engine Interface
Device ID: PCI\VEN_8086&DEV_3B64&SUBSYS_04261028&REV_06\3&11583659&0&B0
Driver: C:\Windows\system32\DRIVERS\HECI.sys, 6.00.0000.1179 (English), 9/18/2009 04:54:14, 41088 bytes
Name: Intel(R) 82801 PCI Bridge - 244E
Device ID: PCI\VEN_8086&DEV_244E&SUBSYS_04261028&REV_A6\3&11583659&0&F0
Driver: C:\Windows\system32\DRIVERS\pci.sys, 6.01.7601.17514 (English), 11/20/2010 22:29:03, 153984 bytes
Name: High Definition Audio Controller
Device ID: PCI\VEN_10DE&DEV_0BE4&SUBSYS_30011682&REV_A1\4&103E700&0&0108
Driver: C:\Windows\system32\DRIVERS\hdaudbus.sys, 6.01.7601.17514 (English), 11/20/2010 22:29:03, 108544 bytes
Device ID: PCI\VEN_8086&DEV_3B56&SUBSYS_04261028&REV_06\3&11583659&0&D8
Name: Intel(R) 5 Series/3400 Series Chipset Family PCI Express Root Port 1 - 3B42
Device ID: PCI\VEN_8086&DEV_3B42&SUBSYS_04261028&REV_06\3&11583659&0&E0
Name: Intel(R) processor PCI Express Root Port - 0041
Device ID: PCI\VEN_8086&DEV_0041&SUBSYS_04261028&REV_18\3&11583659&0&08
Name: Intel(R) 5 Series/3400 Series Chipset Family USB Enhanced Host Controller - 3B3C
Device ID: PCI\VEN_8086&DEV_3B3C&SUBSYS_04261028&REV_06\3&11583659&0&D0
Driver: C:\Windows\system32\drivers\usbehci.sys, 6.01.7601.18328 (English), 11/27/2013 02:13:41, 43520 bytes
Driver: C:\Windows\system32\drivers\usbport.sys, 6.01.7601.18328 (English), 11/27/2013 02:13:46, 284672 bytes
Driver: C:\Windows\system32\drivers\usbhub.sys, 6.01.7601.18328 (English), 11/27/2013 02:14:25, 258560 bytes
Name: Intel(R) processor DRAM Controller - 0040
Device ID: PCI\VEN_8086&DEV_0040&SUBSYS_04261028&REV_18\3&11583659&0&00
Driver: n/a
Name: Intel(R) 5 Series/3400 Series Chipset Family USB Enhanced Host Controller - 3B34
Device ID: PCI\VEN_8086&DEV_3B34&SUBSYS_04261028&REV_06\3&11583659&0&E8
Name: Broadcom NetLink (TM) Gigabit Ethernet
Device ID: PCI\VEN_14E4&DEV_1692&SUBSYS_04261028&REV_01\4&131C64EA&0&00E0
Driver: n/a
Name: Intel(R) 5 Series/3400 Series Chipset Family SMBus Controller - 3B30
Device ID: PCI\VEN_8086&DEV_3B30&SUBSYS_04261028&REV_06\3&11583659&0&FB
Driver: n/a
Name: Intel(R) 5 Series/3400 Series Chipset Family 6 Port SATA AHCI Controller - 3B22
Device ID: PCI\VEN_8086&DEV_3B22&SUBSYS_04261028&REV_06\3&11583659&0&FA
Driver: C:\Windows\system32\DRIVERS\msahci.sys, 6.01.7601.17514 (English), 11/20/2010 22:29:03, 28032 bytes
Driver: C:\Windows\system32\DRIVERS\pciidex.sys, 6.01.7600.16385 (English), 7/14/2009 02:19:03, 42560 bytes
Driver: C:\Windows\system32\DRIVERS\atapi.sys, 6.01.7600.16385 (English), 7/14/2009 02:26:15, 21584 bytes
Driver: C:\Windows\system32\DRIVERS\ataport.sys, 6.01.7601.18231 (English), 8/5/2013 02:56:47, 133056 bytes
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,6.01.7601.17514
WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,6.01.7601.17514
WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,6.01.7601.17514
MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,6.01.7600.16385
Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,6.01.7600.16385
WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,6.01.7601.17514
WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,6.01.7601.18221
Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,6.01.7600.16385
MS ATC Screen Decoder 1,0x00600800,1,1,scdec.dll,15.00.4545.1000
Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,6.01.7600.16385
DV Muxer,0x00400000,0,0,qdv.dll,6.06.7601.17514
Color Space Converter,0x00400001,1,1,quartz.dll,6.06.7601.18741
LAV Splitter,0x00800004,1,1,LAVSplitter.ax,0.62.0000.0000
WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.7601.17514
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,12.00.7601.17514
AVI Splitter,0x00600000,1,1,quartz.dll,6.06.7601.18741
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.06.7601.18741
SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,6.06.7601.17528
Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,12.00.9200.17037
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.06.7601.17528
StreamBufferSink,0x00200000,0,0,sbe.dll,6.06.7601.17528
Microsoft TV Captions Decoder,0x00200001,1,0,MSTVCapn.dll,6.01.7601.17715
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.06.7601.18741
CBVA DMO wrapper filter,0x00200000,1,1,cbva.dll,6.01.7601.17514
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.06.7601.18741
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.06.7601.18741
VBI Codec,0x00600000,1,4,VBICodec.ax,6.06.7601.17514
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.06.7601.17528
Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,6.06.7601.17514
SBE2FileScan,0x00200000,0,0,sbe.dll,6.06.7601.17528
Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7601.17514
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.06.7601.18741
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.06.7601.18741
DV Splitter,0x00600000,1,2,qdv.dll,6.06.7601.17514
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.06.7601.18741
Haali Media Splitter,0x00800001,0,1,Splitter.ax,1.13.0138.0014
Haali Media Splitter (AR),0x00400000,1,1,Splitter.ax,1.13.0138.0014
Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,6.01.7601.17514
ACM Wrapper,0x00600000,1,1,quartz.dll,6.06.7601.18741
Video Renderer,0x00800001,1,0,quartz.dll,6.06.7601.18741
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.06.7601.17528
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.06.7601.18741
Video Port Manager,0x00600000,2,1,quartz.dll,6.06.7601.18741
Video Renderer,0x00400000,1,0,quartz.dll,6.06.7601.18741
Haali Video Renderer,0x00200000,1,0,dxr.dll,
VPS Decoder,0x00200000,0,0,WSTPager.ax,6.06.7601.17514
WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.7601.17514
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,6.01.7601.17514
File writer,0x00200000,1,0,qcap.dll,6.06.7601.17514
iTV Data Sink,0x00600000,1,0,itvdata.dll,6.06.7601.17514
iTV Data Capture filter,0x00600000,1,1,itvdata.dll,6.06.7601.17514
Haali Simple Media Splitter,0x00200000,0,1,Splitter.ax,1.13.0138.0014
DirectVobSub,0x00200000,2,1,vsfilter.dll,3.00.0000.0305
DirectVobSub (auto-loading version),0x00800002,2,1,vsfilter.dll,3.00.0000.0305
DVD Navigator,0x00200000,0,3,qdvd.dll,6.06.7601.18741
Microsoft TV Subtitles Decoder,0x00200001,1,0,MSTVCapn.dll,6.01.7601.17715
Overlay Mixer2,0x00200000,1,1,qdvd.dll,6.06.7601.18741
Haali Matroska Muxer,0x00200000,1,0,Splitter.ax,1.13.0138.0014
AVI Draw,0x00600064,9,1,quartz.dll,6.06.7601.18741
RDP DShow Redirection Filter,0xffffffff,1,0,DShowRdpFilter.dll,
Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7601.17514
WST Pager,0x00200000,1,1,WSTPager.ax,6.06.7601.17514
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.06.7601.17528
DV Video Decoder,0x00800000,1,1,qdv.dll,6.06.7601.17514
LAV Splitter Source,0x00800004,0,1,LAVSplitter.ax,0.62.0000.0000
SampleGrabber,0x00200000,1,1,qedit.dll,6.06.7601.18501
Null Renderer,0x00200000,1,0,qedit.dll,6.06.7601.18501
MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,6.06.7601.17514
Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,6.01.7601.17514
StreamBufferSource,0x00200000,0,0,sbe.dll,6.06.7601.17528
Smart Tee,0x00200000,1,2,qcap.dll,6.06.7601.17514
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.06.7601.18741
AVI Decompressor,0x00600000,1,1,quartz.dll,6.06.7601.18741
NetBridge,0x00200000,2,0,netbridge.dll,6.01.7601.17514
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.06.7601.18741
Wave Parser,0x00400000,1,1,quartz.dll,6.06.7601.18741
MIDI Parser,0x00400000,1,1,quartz.dll,6.06.7601.18741
Multi-file Parser,0x00400000,1,1,quartz.dll,6.06.7601.18741
File stream renderer,0x00400000,1,1,quartz.dll,6.06.7601.18741
Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,6.01.7140.0000
StreamBufferSink2,0x00200000,0,0,sbe.dll,6.06.7601.17528
AVI Mux,0x00200000,1,0,qcap.dll,6.06.7601.17514
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.06.7601.18741
File Source (Async.),0x00400000,0,1,quartz.dll,6.06.7601.18741
File Source (URL),0x00400000,0,1,quartz.dll,6.06.7601.18741
Media Center Extender Encryption Filter,0x00200000,2,2,Mcx2Filter.dll,6.01.7601.17514
AudioRecorder WAV Dest,0x00200000,0,0,WavDest.dll,
AudioRecorder Wave Form,0x00200000,0,0,WavDest.dll,
SoundRecorder Null Renderer,0x00200000,0,0,WavDest.dll,
LAV Audio Decoder,0x00800003,1,1,LAVAudio.ax,0.62.0000.0000
LAV Video Decoder,0x00800003,1,1,LAVVideo.ax,0.62.0000.0000
Haali Video Sink,0x00200000,1,0,Splitter.ax,1.13.0138.0014
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.06.7601.17514
Enhanced Video Renderer,0x00200000,1,0,evr.dll,6.01.7601.18741
BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,6.06.7601.17669
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.06.7601.18741
WDM Streaming Tee/Splitter Devices:
Tee/Sink-to-Sink Converter,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,6.01.7600.16385
WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,6.01.7600.16385
MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,6.01.7600.16385
DV Video Encoder,0x00200000,0,0,qdv.dll,6.06.7601.17514
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.06.7601.18741
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.06.7601.17514
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.06.7601.17514
Intel Indeo® Video 4.5,0x00200000,1,1,qcap.dll,6.06.7601.17514
Microsoft RLE,0x00200000,1,1,qcap.dll,6.06.7601.17514
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.06.7601.17514
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,6.01.7600.16385
WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,6.01.7600.16385
IMA ADPCM,0x00200000,1,1,quartz.dll,6.06.7601.18741
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.06.7601.18741
GSM 6.10,0x00200000,1,1,quartz.dll,6.06.7601.18741
CCITT A-Law,0x00200000,1,1,quartz.dll,6.06.7601.18741
CCITT u-Law,0x00200000,1,1,quartz.dll,6.06.7601.18741
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.06.7601.18741
Audio Capture Sources:
Microphone (SB Audigy),0x00200000,0,0,qcap.dll,6.06.7601.17514
Line-In (SB Audigy),0x00200000,0,0,qcap.dll,6.06.7601.17514
S/PDIF-In (SB Audigy),0x00200000,0,0,qcap.dll,6.06.7601.17514
PBDA CP Filters:
PBDA DTFilter,0x00600000,1,1,CPFilters.dll,6.06.7601.17528
PBDA ETFilter,0x00200000,0,0,CPFilters.dll,6.06.7601.17528
PBDA PTFilter,0x00200000,0,0,CPFilters.dll,6.06.7601.17528
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.06.7601.18741
Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,6.06.7601.18741
WDM Streaming Capture Devices:
,0x00000000,0,0,,
SB Audigy,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
SB Audigy,0x00200000,2,2,ksproxy.ax,6.01.7601.17514
WDM Streaming Rendering Devices:
NVIDIA High Definition Audio,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
HD Audio Headphone/Speakers,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
HD Audio SPDIF out,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft Network Provider,0x00200000,0,1,MSNP.ax,6.06.7601.17514
Multi-Instance Capable VBI Codecs:
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,6.06.7601.17669
MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,6.06.7601.17514
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,1,EncDec.dll,6.06.7601.17708
Encrypt/Tag,0x00200000,0,0,EncDec.dll,6.06.7601.17708
PTFilter,0x00200000,0,0,EncDec.dll,6.06.7601.17708
XDS Codec,0x00200000,0,0,EncDec.dll,6.06.7601.17708
WDM Streaming Communication Transforms:
Audio Renderers:
Mstar Demo-1 (NVIDIA High Defin,0x00200000,1,0,quartz.dll,6.06.7601.18741
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.06.7601.18741
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.06.7601.18741
Digital Audio (S/PDIF) (2- High,0x00200000,1,0,quartz.dll,6.06.7601.18741
DirectSound: Digital Audio (S/PDIF) (2- High Definition Audio Device),0x00200000,1,0,quartz.dll,6.06.7601.18741
DirectSound: Mstar Demo-1 (NVIDIA High Definition Audio),0x00200000,1,0,quartz.dll,6.06.7601.18741
EVR Power Information
Current Setting: {651288E5-A7ED-4076-A96B-6CC62D848FE1} (Balanced)
Quality Flags: 2576
Enabled:
Force throttling
Allow half deinterlace
Allow scaling
Decode Power Usage: 100
Balanced Flags: 1424
Enabled:
Force throttling
Allow batching
Force half deinterlace
Force scaling
Decode Power Usage: 50
PowerFlags: 1424
Enabled:
Force throttling
Allow batching
Force scaling
Decode Power Usage: 0
NVIDIA System Information report created on: 05/14/2015 04:00:45System name: *** [Display] Operating System: Windows 7 Professional, 32-bit (Service Pack 1) DirectX version: 11.0 GPU processor: GeForce GT 240 Driver version: 341.44 Direct3D API version: 10.1 CUDA Cores: 96 Core clock: 550 MHz Shader clock: 1340 MHz Memory data rate: 3400 MHz Memory interface: 128-bit Total available graphics memory: 1755 MB Dedicated video memory: 512 MB GDDR5 System video memory: 0 MB Shared system memory: 1243 MB Video BIOS version: 70.15.27.00.50 IRQ: 16 Bus: PCI Express x16 Gen2 Device ID: 10DE 0CA3 30011682 Part Number: 0672 0001 [Components] nvui.dll 8.17.13.4144 NVIDIA User Experience Driver Component nvxdsync.exe 8.17.13.4144 NVIDIA User Experience Driver Component nvxdplcy.dll 8.17.13.4144 NVIDIA User Experience Driver Component nvxdbat.dll 8.17.13.4144 NVIDIA User Experience Driver Component nvxdapix.dll 8.17.13.4144 NVIDIA User Experience Driver Component NVCPL.DLL 8.17.13.4144 NVIDIA User Experience Driver Component nvCplUIR.dll 7.8.840.0 NVIDIA Control Panel nvCplUI.exe 7.8.840.0 NVIDIA Control Panel nvWSSR.dll 6.14.13.4144 NVIDIA Workstation Server nvWSS.dll 6.14.13.4144 NVIDIA Workstation Server nvViTvSR.dll 6.14.13.4144 NVIDIA Video Server nvViTvS.dll 6.14.13.4144 NVIDIA Video Server NVSTVIEW.EXE 7.17.13.4144 NVIDIA 3D Vision Photo Viewer NVSTTEST.EXE 7.17.13.4144 NVIDIA 3D Vision Test Application NVSTRES.DLL 7.17.13.4144 NVIDIA 3D Vision Module nvDispSR.dll 6.14.13.4144 NVIDIA Display Server NVMCTRAY.DLL 8.17.13.4144 NVIDIA Media Center Library nvDispS.dll 6.14.13.4144 NVIDIA Display Server PhysX 09.13.1220 NVIDIA PhysX NVCUDA.DLL 8.17.13.4144 NVIDIA CUDA 6.5.45 driver nvGameSR.dll 6.14.13.4144 NVIDIA 3D Settings Server nvGameS.dll 6.14.13.4144 NVIDIA 3D Settings Server
