Hello. After upgrading from 14.04.1 to Kubuntu 14.10, I can't shutdown anymore. It just takes forever and nothing. Any help?
Kubuntu 14.10 does not shutdown
Don't shutdown from the GUI.
Switch to terminal mode and try: sudo shutdown now
Then see what process is holding you up.
Thanks for your answer. Unfortunately, it didn't work. It just takes forever and this time I get a blank screen, whith no plymouth theme.Originally posted by oshunluvr View PostDon't shutdown from the GUI.
did you just do this in a terminal ,,,, or switch to a TTY (ctrl+alt+F6) in a terminal you will not see the shutdown process ,,,,in a TTY you will .Originally posted by geoaraujo View PostThanks for your answer. Unfortunately, it didn't work. It just takes forever and this time I get a blank screen, whith no plymouth theme.
Changing to a TTY, it only showed briefly something about the firewall (ufw), I think, and then, I've got a blank screen.
Edit: It says briefly "skip stopping firewall: ufw (not enable)".
And the message I get when using the gui is "wait-for-state stop/waiting".Last edited by geoaraujo; Oct 30, 2014, 07:19 PM.
I installed 14.10 Plasma 5 last night. For me: rebooting/shutting down only works from the SDDM menu. In other words, if I log out first, then click reboot or shutdown it works. Must be an error in the desktop commands somewhere.
Well, I'm running KDE 4.14.2. I've already tried that but it didn't work either...Originally posted by oshunluvr View PostI installed 14.10 Plasma 5 last night. For me: rebooting/shutting down only works from the SDDM menu. In other words, if I log out first, then click reboot or shutdown it works. Must be an error in the desktop commands somewhere.
I've searched around Kubuntu and Ubuntu forums, Launchpad bugs and so on. I've tried so many solutions right now, from 11.04 to 14.10 and none of them worked. System halts but does not power off. So, to be less agressive, I do RSEIUB to reboot the computer, and after the Kubuntu logo, I get a blank screen instead of login screen. Then I have to press the poweroff button. This is very frustrating.
Edit: I've also tried changing to kdm instead of lightdm, but then I get a lot of kde errors and a blank screen after login and shutdown doesn't work anyway.Last edited by geoaraujo; Nov 11, 2014, 11:36 AM.
Same here, but it's intermittent. Most of the time shutdown works, sometimes it does not.
Once it's at the "stop/wait" screen I can press ctrl-alt-del and it will often seem to get through that block only to block again on another stop/wait. Eventually ctrl-alt-delete does nothing anymore, and then i press the power button on my computer (desktop) and it will shut down (even if I had told it in the GUI to reboot).
I only haveThe blog also has a nice set of trouble shooting scripts in the article after the one you posted the link for.Code:lee@lee-asrock:~$ cat /etc/rc0.d/S90halt
