Apologies if this isn't the right sub-forum for my problem.
Everything was working until I installed Krita. Now I have to login to my 2nd hard drive in order to use it after boot, and my desktop launchers won't start their associated programs any more.
I've went into Sytem Settings>Removeable Devices and checked "Automount on Login" and "Automount on Attach" for my 2nd hard drive, in both the Attached Devices and Disconnected Devices sections. That didn't help.
Here's my fstab -
	Appears to be partitions on the primary hard drive (ssd used for boot only).
I haven't looked into the Launcher problem yet, other than to delete the old ones and recreate new ones (didn't work). Putting the application launchers on the toolbar works though.
Here's my fstab -
	# /etc/fstab: static file system information. # # Use 'blkid' to print the universally unique identifier for a # device; this may be used with UUID= as a more robust way to name devices # that works even if disks are added and removed. See fstab(5). # # <file system> <mount point> <type> <options> <dump> <pass> proc /proc proc nodev,noexec,nosuid 0 0 # / was on /dev/sda1 during installation UUID=26c5bfb5-79d7-4f2c-af59-5a0bcdf79436 / ext4 errors=remount-ro 0 1 # /boot was on /dev/sda5 during installation UUID=13490989-1e98-4f08-8b37-b0c3a82ac0fd /boot ext4 defaults 0 2 # /home was on /dev/sda8 during installation UUID=dc6678f0-788c-4499-926b-ac70c10bcc1e /home ext4 defaults 0 2 # /tmp was on /dev/sda6 during installation UUID=fa4485be-4ccb-4ae4-83c3-76bda969be89 /tmp ext4 defaults 0 2 # /usr was on /dev/sda7 during installation UUID=b8695f81-a4a6-4f5d-8354-c5c641de9962 /usr ext4 defaults 0 2
