Issue with display after installation
    Hi everyone
    I've tried installing several times but each time I get the same result. The display is showing garbled lines and I cant see anything. I wonder if its my factory overclocked Zotac 560ti AMP! card that it doesnt like.
    Kubuntu 13.04 Raring Ringtail 64-bit.
    Linux User: #193835 - Ubuntu User #35248
    If you run 12.04 from the LiveCD, do you have the same issue?
      hmm not tried the live cd, will try that later and report back.
        Where can I get the live cd from?
          From the Kubuntu.org website...
          What disk did you use so far?
            I used the kubuntu 12.04 LTS dvd.
              Next boot with garbled screen, try this:
              CRTL-ATL-F1
              log in
              type: cat /var/log/Xorg.0.log |more
              Scroll through the file and look for warnings (WW) and errors (EE). Also note which driver is being used. Report back...
                Thanks will try that.
                  Unfortunately the display is still garbled after pressing ctrl+alt+F1 so I cannot see what Im doing.
                    Sounds like your video card is not starting in a mode compatible with your monitor. Have you tried booting to recovery mode to see if you get a readable text console?
                      It works perfectly in bios and in windows 7, sounds more likely to be linux at fault.
                        OK, let me rephrase...
                        Sounds like linux is not starting your video card in a mode compatible with your monitor.
                        Common guy, you have to help out a little bit. This is a linux forum...
                        Again, have you tried booting to recovery mode to see if you get a readable text console?
                          What if he edited his kernel line in grub at boot and added VGA=791 to force 1024x768? Think that would at least get him further into the system to troubleshoot?
                            Why would I want to lower my resolution. Surely kubuntu should support my native (common) res.Its rediculous that this issue even exists when it works fine on Windows.
                              Lowering your resolution would be to enable you to boot into the system to troubleshoot what is wrong it would not be the solution to the problem.
