Alright, so I just upgraded my Kubuntu 11.10 install to KDE 4.8 in the hopes of fixing a few bugs (Darned Muon Software Center kept crashing before). Thankfully, the process went very smoothly; or so I thought.
Now whenever my screen locks (which, since I'm using a laptop is pretty often) when I enter back to my desktop I cannot connect to any wireless networks.
I go to my Network panel and it tells me that the Wireless Network is "Unavailable" right above where it tells me that the Wired Connection is Unplugged. When I try to go to the screen where my available networks are it doesn't show anything, even though there should be a good 20 networks visible. I haven't found any way to reconnect to my network short of restarting my computer - which is kind of a pain - and then sometimes even that fails after 10 minutes or so.
Help me Kubuntu Forum guys, you're my only hope. I will be glad to try anything in my power to give more info for troubleshooting.
wns=io+mem
ci0000:00 complete after 523.744 msecs
