I installed 11.04, then my video card died, and I put in a new GeForce 210 card. Then I couldn't boot to Kubuntu. Then I wiped the disk and tried to start all over again, but the live CD (desktop AMD64) would not install. It stops right after I select the install option. I have used the F6 "nomodeset" option without any change in the results. So unless I get some assistance from somewhere, I can't even try 11.04 because the live CD will not load up properly. Any help out there? Thanks for listening!
So someone, either in the Kubuntu development team, or the Grub2 development team, has caused a whole category of users to be unable to enjoy the live CD Kubuntu experience. It does look like the developers could make this distro accessible to everyone, even if they did have to give up a fancy splash screen or two. This has been a recurring theme in Linux history, and it really makes it difficult to recruit new Linux converts from casual Windows users when they encounter such a show stopper as this. And even if there is a work-around, which I have not yet found, it almost certainly will not be very user-friendly.
