USB devices not detected when running on battery
    If my laptop is running on battery, and I connect a USB device, nothing happens. If I plug the laptop into the mains, then plug the device in, I get the KDE pop up notice asking me what to do.
    Anyone got any ideas why this could be ?
    I've just noticed this, and it certainly worked a few weeks ago when I last tried, so I wonder if an update has changed something...
    Re: USB devices not detected when running on battery
    What kind of USB device? If it is a disk drive that gets power from the USB connector, then probably it's a "feature" to save the battery.
      No, it's my phone, and it used to work fine.
      It also occurs with my sat. nav., ditto, so it's not the external devices fault.
        Is there any chance the battery is not holding a good charge any more? It sounds like a power sensor is cutting off power to the USB connector when faced with a current draw, unless the system is plugged into the mains.
          Good guess, but both the KDE battery gauge and lshal indicate all is well:
          root@wopr:~# lshal|grep battery
          udi = '/org/freedesktop/Hal/devices/computer_power_supply_battery_BAT0'
           battery.charge_level.current = 64357 (0xfb65) (int)
           battery.charge_level.design = 73260 (0x11e2c) (int)
           battery.charge_level.last_full = 69086 (0x10dde) (int)
           battery.charge_level.percentage = 93 (0x5d) (int)
           battery.charge_level.rate = 16872 (0x41e8) (int)
           battery.is_rechargeable = true (bool)
           battery.model = 'DELL HP' (string)
           battery.present = true (bool)
           battery.rechargeable.is_charging = false (bool)
           battery.rechargeable.is_discharging = true (bool)
           battery.remaining_time = 13731 (0x35a3) (int)
           battery.reporting.current = 5798 (0x16a6) (int)
           battery.reporting.design = 6600 (0x19c8) (int)
           battery.reporting.last_full = 6224 (0x1850) (int)
           battery.reporting.rate = 1520 (0x5f0) (int)
           battery.reporting.technology = 'Li-ion' (string)
           battery.reporting.unit = 'mAh' (string)
           battery.serial = '1' (string)
           battery.technology = 'lithium-ion' (string)
           battery.type = 'primary' (string)
           battery.vendor = 'SMP' (string)
           battery.voltage.current = 12032 (0x2f00) (int)
           battery.voltage.design = 11100 (0x2b5c) (int)
           battery.voltage.unit = 'mV' (string)
            My guess is something in the "policykit" region of your system has changed -- don't know why it would, or exactly how to fix it. But it should be possible to change the behavior, which is clearly tied to the question of whether the system is on battery or mains.
              Is there a GUI or sensible command line for looking at it's rules ? What about something like pm-utils ? There are a few hints kicking around the internet, but the best fit for my symptoms seems to be on Arch rather than Ubuntu :
              https://bbs.archlinux.org/viewtopic.php?id=113611
              https://bbs.archlinux.org/viewtopic.php?id=120359
                Yes, those bug reports look exactly like your symptom. Arch uses plain vanilla KDE, as far as I know, so a fix that works for Arch Linux will probably work for Kubuntu as well.
                FYI, it is also true for Debian that if you hibernate or "sleep" the computer, then the USB bus has lost track of what was connected in the prior session, and you might have to reboot to get the webcam or other device to work again. I have had that experience in recent weeks. I see that also reported for Arch.
                  Any chance your BIOS has a power saving setting that disables some or all of the USB ports when on battery power? One of my Dell's turns off the ethernet port when in battery only mode.
                    No chance, it worked until recently, and I don't spend hours playing with the BIOS
                      Do you mean "power management" ? There isn't a relevant tickbox in the profiles as far as I can tell.
