Re: Lucid permissions problems for usb
Thank you, GreyGeek,
That's very helpful. Looks like I have a lot to do so I'll get cracking and come back to let you know what happened. Yes, I often get a message saying my disk can't be unmounted because a file is open in an application and I have assumed that's because the classroom computers here (all windows) are notoriously infected. I've never been able to find out which file is supposedly open, so I have just pulled out the usb - I'm now realising that's obviously a stupid thing to do!
Will get to work on all this now.
BUT!!!!!
Now I'm paralysed by fear, confusion and uncertainty!
1. Everything I mount on this system is FAT not NTFS or whatever. That's because about 3 years ago I had an external drive that had NTFS and it was impossible to mount it, so I just got it converted to FAT. BUT I think the basic problem stems from those efforts to mount that drive 3 years ago, though I don't understand why it has just become an issue since the Lucid upgrade.
2. Tried some of the things you said but really not expert enough to do so with confidence. Then thought I should check what's there already in fstab. Went in through Krusader and this is what I saw (see attached pic). Using the 'view' feature, this is what is in each of those 6 fstab files (I just copied and pasted the contents to a document. (T) means it's a text file. The other two (files 3 and 5) have the little green logo beside them.
top fstab file (T)
# -- This file has been automaticly generated by ntfs-config --
2nd fstab file
proc /proc proc defaults 0 0
# Entry for /dev/sda1 :
UUID=948fb0d0-7875-4137-8365-aff054b7c890 / ext3 nouser,defaults,errors=remount-ro,atime,auto,rw,dev,exec,suid 0 1
# Entry for /dev/sda5 :
UUID=21d2d5ee-52c7-4166-960c-6b4ef6b12aac none swap sw 0 0
/dev/hda /media/cdrom0 auto user,atime,noauto,rw,dev,exec,suid 0 0
3rd fstab file (backup)(T)
same as first
4th fstab file (T)
# /dev/sda5
5th fstab file
# /dev/sda1
# /dev/sda5
6th fstab file (T)
# UNCONFIGURED FSTAB FOR BASE SYSTEM
BUT!!!!!
top fstab file (T)
2nd fstab file
same as first
4th fstab file (T)
# /dev/sda5
5th fstab file
# /dev/sda1
# /dev/sda5
6th fstab file (T)
That's a new piece of information I wasn't aware of. Windows boxes are notorious for being easily infected and having multiple infections. The worst is the keyboard logger Trojan residing in the MBR. Even if you reinstall Windows but don't wipe the HD (including the MBR) the box will get re-infected on the next boot. But, if you DO wipe the HD then the 5GB hidden, unlabeled partition (another favorite place malware hides in) is erased, along with your ability to "recover" the installation, since most recent recovery discs do not include reinstall on the bare metal.
If that pic is an early one of you it looks remarkably similar to one of my younger sister, taken when she was around four. So many pseudonyms and avatars are gender neutral, or are outright reversals, that I generally don't ascribe any significance to them, or notice them, unless they are outstandingly unusual.
