Re: KDS Monitor / "RV530LE [Radeon X1600]" graphics card - high resolution problems
what does
xrandr -q
show now with edid turned off?
what does
xrandr -q
Screen 0: minimum 320 x 200, current 1024 x 768, maximum 8192 x 8192 VGA-0 connected 1024x768+0+0 (normal left inverted right x axis y axis) 360mm x 260mm 1280x1024 75.0 1024x768 85.0* 85.0 75.1 800x600 85.1 75.0 640x480 85.0 720x400 70.1 S-video disconnected (normal left inverted right x axis y axis) DVI-0 disconnected (normal left inverted right x axis y axis)
(II) RADEON(0): Printing DDC gathered Modelines: (II) RADEON(0): Modeline "1280x1024"x0.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz) (II) RADEON(0): Modeline "1024x768"x0.0 94.50 1024 1072 1168 1376 768 769 772 808 +hsync +vsync (68.7 kHz) (II) RADEON(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz) (II) RADEON(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz) (II) RADEON(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz) (II) RADEON(0): Modeline "1024x768"x0.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz) (II) RADEON(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz) (II) RADEON(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz) (II) RADEON(0): Modeline "640x480"x0.0 36.00 640 696 752 832 480 481 484 509 -hsync -vsync (43.3 kHz) (II) RADEON(0): Modeline "800x600"x0.0 56.25 800 832 896 1048 600 601 604 631 +hsync +vsync (53.7 kHz) (II) RADEON(0): Modeline "800x600"x100.0 68.18 800 848 936 1072 600 601 604 636 -hsync +vsync (63.6 kHz) (II) RADEON(0): Modeline "1600x1200"x0.0 162.00 1600 1664 1856 2160 1200 1201 1204 1250 +hsync +vsync (75.0 kHz)
# Drm device configuration
# This driver provides support for the
# Direct Rendering Infrastructure (DRI) in XFree86 4.1.0 and higher.
config DRM_RADEON
tristate "ATI Radeon"
depends on DRM && PCI
select FB_CFB_FILLRECT
select FB_CFB_COPYAREA
select FB_CFB_IMAGEBLIT
select FW_LOADER
select DRM_KMS_HELPER
select DRM_TTM
select POWER_SUPPLY
help
Choose this option if you have an ATI Radeon graphics card. There
are both PCI and AGP versions. You don't need to choose this to
run the Radeon in plain VGA mode.
If M is selected, the module will be called radeon.
source "drivers/gpu/drm/radeon/Kconfig"
xrandr --newmode "1600x1200"x0.0 162.00 1600 1664 1856 2160 1200 1201 1204 1250 +hsync +vsync xrandr --newmode "1280x1024"x0.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync
xrandr --newmode "1600x1200"x0.0 162.00 1600 1664 1856 2160 1200 1201 1204 1250 +hsync +vsync xrandr --addmode VGA-0 1600x1200x0.0 xrandr --output VGA-0 --mode 1600x1200x0.0
xrandr --newmode "1280x1024"x0.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync xrandr --addmode VGA-0 1280x1024x0.0 xrandr --output VGA-0 --mode 1280x1024x0.0
gtf 1280 1024 65
xrandr --newmode "1280x1024_65.00" 119.40 1280 1368 1504 1728 1024 1025 1028 1063 -HSync +Vsync xrandr --addmode VGA-0 1280x1024_65.00 xrandr --output VGA-0 --mode 1280x1024_65.00
gtf 1600 1200 61 # 1600x1200 @ 61.00 Hz (GTF) hsync: 75.82 kHz; pclk: 163.78 MHz Modeline "1600x1200_61.00" 163.78 1600 1704 1880 2160 1200 1201 1204 1243 -HSync +Vsync xrandr --newmode "1600x1200_61.00" 163.78 1600 1704 1880 2160 1200 1201 1204 1243 -HSync +Vsync xrandr --addmode VGA-0 1600x1200_61.00 xrandr --output VGA-0 --mode 1600x1200_61.00
/etc/kde4/kdm/Xsetup
