Hello,
Up to 18.04 (including), I was using Jupiter to keep the laptop cold. With 20.04 some libraries Jupiter is depending on (at least python-gtk2) were killed. The only option to keep laptop cold is now the indicator-cpufreq. I avoided it in the past because amnesic. Now, like it or not, I have to use it. But to really like it, I have to get rid of its amnesia. Thus, two options:
1) To change its amnesic behavior, to remember the last settings before reboot.
2) To change it's default setting from Performance or Power on Demand, to Power Saving. In this case, I won't care about the amnesia issue anymore, as it will always start on Power Saving, which is what I want.
With this, I'll be happy with 20.04 (upgraded to the latest Plasma, as there are some issues there too, but improvements are fast).
Thanks,
Thanks,
