Results 1 to 2 of 2
Thread: Running a Broadcom BCM42143 wireless adapter on Kubuntu 20.04
  1. Back To Top    #1
    Kubuntu as a Second Language TWPonKubuntu's Avatar
    Join Date
    Nov 2013
    Location
    Western US
    Posts
    1,290
    Threads
    119
    Local Date
    Jun 7th 2020
    Local Time
    01:58 AM
    I had given up being able to use this device, which is the internal wireless adapter on my 64bit system. The driver for this does NOT work.
    By chance, and not deliberately, I had turned on the eno1 adapter (that is the Ethernet port). And now the Broadcom wireless device is active and working! Wheee!
    I no longer need to use an external wireless adapter to get internet connections. I'm a happy camper.
    For anyone else who has this problem with the Broadcom BCM43142 wireless adapter, I found the eno1 enable toggle in the configuration settings for the Network Monitor widget which I had placed on my desktop.
    I found not other locations which offer the ability to toggle eno1 on/off. It might exist, but I could not find it.
    FYI
    TWP
    If You're Not Paranoid Yet, You Should Be. Kubuntu 20.04 64bit under Kernel 5.6.16, Hp Pavilion, 6MB ram.
  2. Back To Top    #2
    Kubuntu as a Second Language jglen490's Avatar
    Join Date
    Jul 2006
    Location
    Montgomery AL
    Posts
    1,613
    Threads
    53
    Local Date
    Jun 7th 2020
    Local Time
    03:58 AM
    That's weird, but it's good that you have it working! I'll have to remember that on.
    So there's a word or two for something like that: supercal ... (blah, blah)
    Anyway, it's happiness!
    I feel more like I do now than I did when I got here.
    Home Brew PC: MSI B365M PRO-VDH(MS-7C39), 120GB+500GB, 16GB RAM
    Kubuntu 18.04.4.LTS Bionic, 5.3.0-53-generic x86_64, Plasma 5.12.9
Posting Permissions
  • You may not post replies
  • You may not edit your posts
