With every upgrade I seem to have problems with getting Akonadi running.
I recently upgraded from Kubuntu 16.04 to 16.10.
Akonadi refuses again to start.
I solved it last time but don't remember what I did.
I removed (purged) and reinstalled all Akonadi and mysql related packages but the problem is still there.
"(sudo) akonadictl start" results in the following "akonadiserver.error" file:
Database process exited unexpectedly during initial connection!
executable: "/usr/sbin/mysqld-akonadi"
arguments: ("--defaults-file=/home/jo/kubuntu_16_04/.local/share/akonadi/mysql.conf", "--datadir=/home/jo/kubuntu_16_04/.local/share/akonadi/db_data/", "--socket=/tmp/akonadi-root.dicPFm/mysql.socket")
stdout: ""
stderr: "mysqld: [ERROR] Could not open required defaults file: /home/jo/kubuntu_16_04/.local/share/akonadi/mysql.conf\nmysqld: [ERROR] Fatal error in defaults handling. Program aborted!\n"
exit code: 1
process error: "Unknown error"
Failed to remove Unix socket
Failed to remove runtime connection config file
stdout: ""
exit code: 1
. Kontact is now working for me and I am currently setting it up from the packages that I have on my KDE Neon system. I am pleased to see that on Yakkety, the Calendar now allows AM times to be specified and stored rather than changing to PM when I save entries on the KDE Neon system.
