[SIZE=5]Hello guys...
¿Is there any way to avoid the need to restart the X (KDM)?
Trying to use the dual panel view, (twin view) in the nvidia-settings.
My Xorg ----> http://pastebin.com/9Bszw3T8
cat /proc/version:
Linux version 4.5.0-customlinux (root@duilio-desktop) (gcc version 4.8.4 (Ubuntu 4.8.4-2ubuntu1~14.04.1) ) #1 SMP Thu Mar 24 18:19:45 ART 2016
Kubuntu 14.04.4
Kde 4.14.13
Nvidia proprietary drivers 361.42
The strange thing is that when I keep and save (with sudo) the settings of the x in the NVIDIA Control Panel---->Xorg, I can use the system preferences "monitors" smothly , but then I reboot the system, and I try to place monitor A alonside monitor B in a twin view conf, everything comes black again, you can only see the mouse cursor, until you restart kdm.
So everything you do to change the x to one or another monitor, required the need to restart kdm with no exceptions.
I try several configurations with Xinerama On and Off, its always the same.
Instructiones from nvidia:
https://help.ubuntu.com/community/NvidiaMultiMonitors
This is the only thing compare to gnome or mate that bothers me.
More infor about my graphics:
lspci -v -s `lspci | awk '/VGA/{print $1}'`
01:00.0 VGA compatible controller: NVIDIA Corporation GK104 [GeForce GTX 760] (rev a1) (prog-if 00 [VGA controller])
Subsystem: ZOTAC International (MCO) Ltd. Device 3265
Flags: bus master, fast devsel, latency 0, IRQ 48
Memory at fd000000 (32-bit, non-prefetchable) [size=16M]
Memory at f0000000 (64-bit, prefetchable) [size=128M]
Memory at f8000000 (64-bit, prefetchable) [size=32M]
I/O ports at e000
[virtual] Expansion ROM at fe000000 [disabled]
Capabilities: <access denied>
Kernel driver in use: nvidia
¿is this something related to plasma 4, kde? ¿or nvidia proprietary drivers?
Any help is really appreciated
cat /proc/version:
Kubuntu 14.04.4
Kde 4.14.13
I/O ports at e000
