Results 1 to 6 of 6
Thread: nvidia problems - no sli, boots to blank screen
  1. Back To Top    #1
    Kubuntu as Second Language doctordruidphd's Avatar
    Join Date
    Jan 2009
    Location
    Pacific Northwest, USA
    Posts
    1,692
    Threads
    200
    Local Date
    Jan 12th 2018
    Local Time
    07:23 AM
    Two problems have appeared:
    1. On bootup, the system goes to a blank/black screen (not actually black, very dark grey). If i hit CTRL-ALT-F1, then CTRL-ALT-F7, I get the kdm greeter (yes I am using kdm) which then works as expected. This problem just appeared within the last 2 days (today is Sunday Oct 14th) after doing daily dist-upgrades, up until then has been working as expected.
    2. I have 2 identical (9800 GT) cards in SLI configuration, with appropriate entries in xorg.conf to make it work. I just noticed, upon starting nvidia-settings, that card GPU1 is not being detected; I get only the entry for GPU0. I found an old copy of Lucid and booted it, and it works correctly -- both cards there -- so it's not hardware failure. lspci shows both cards present. glxgears rate is abysmal. I tried booting precise, but unfortunately I had run a dist-upgrade on it yesterday, so it's the same video driver, and the same problem. I tried uninstalling and installing an older version of the NVIDIA driver from the website, but it complains about ABI and won't start, so I can't test that idea. I do not know how long this problem has been present.
    I suspect these may be related video driver problems. Anyone else having similar issues?
    $ apt-cache policy nvidia-current
    nvidia-current:
    Installed: 304.51.really.304.43-0ubuntu1
    Edit: Installing the most recent version of the NVIDIA driver from their website (304.51) has the same problem - no sli. The downloaded driver DOES fix the bootup screen problem. Anyone else with a similar setup to verify that there's a problem? Thanks.
  2. Back To Top    #2
    Newbie
    Join Date
    Oct 2012
    Posts
    1
    Threads
    0
    Local Date
    Jan 12th 2018
    Local Time
    10:23 AM
    I just did a fresh (re)-install of Kubuntu 12.10 and I'm experiencing the same thing.
    1) system boots to a black screen, but you can tell that things are running
    2) if I type my password in anyway, I see the actual Kubuntu boot sequence, and then get a login
    3) I haven't tried the Ctrl-Alt-F1, Ctrl-alt-F7 sequence, but I'll do that.
    System:
    Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz
    32Gb RAM
    2 graphics cards: GT218 [GeForce 210], Nvidia
    driving 4 monitors
    sudo apt-cache policy nvidia-current
    nvidia-current:
    Installed: 295.40-0ubuntu1.1
    Candidate: 295.40-0ubuntu1.1
    Version table:
    *** 295.40-0ubuntu1.1 0
    500 http://us.archive.ubuntu.com/ubuntu/ precise-updates/restricted amd64 Packages
    500 http://security.ubuntu.com/ubuntu/ precise-security/restricted amd64 Packages
    100 /var/lib/dpkg/status
    295.40-0ubuntu1 0
    500 http://us.archive.ubuntu.com/ubuntu/ precise/restricted amd64 Packages
    NOTE: Previously this didn't happen, but I had originally installed ubuntu and then added the KDE later. This time I installed Kubuntu fresh.
  3. Back To Top    #3
    Join Date
    Jan 2009
    Location
    Posts
    1,692
    Threads
    200
    Local Date
    Jan 12th 2018
    Local Time
    07:23 AM
    That's interesting. I tried it, and it didn't work.
    Do you have your graphics cards set up for SLI, and are they both being detected? ( take a look at nvidia-settings) You are using an older version of the driver, but still it might be worth checking.
  4. Back To Top    #4
    Join Date
    Jan 2009
    Location
    Posts
    1,692
    Threads
    200
    Local Date
    Jan 12th 2018
    Local Time
    07:23 AM
    Update on 15 Oct : Today's dist-upgrade, which included, among other things, updates to grub, ureadahead and upstart, seems to have fixed the problem of booting into a blank screen. The problem of no SLI seems to be more related to the video driver itself.
  5. Back To Top    #5
    Senior Member
    Join Date
    Mar 2012
    Posts
    223
    Threads
    28
    Local Date
    Jan 12th 2018
    Local Time
    09:23 AM
    I've been having problems too, every since about a week ago when an update updated my driver to Nvidia 304.51.
  6. Back To Top    #6
    Join Date
    Jan 2009
    Location
    Posts
    1,692
    Threads
    200
    Local Date
    Jan 12th 2018
    Local Time
    07:23 AM
    Beginning to look like the SLI problem is hardware related. Will know for sure when the replacement cards get here. The boot-to-bsod problem seems to have been fixed here by recent updates.
Similar Threads
  1. Kubuntu boots to permanent black/blank screen
    By shiftylookingcow in forum Post-installation
    Last Post: May 26th 2013, 11:33 PM
  2. Karmic Boots into a (somewhat) functional blank screen)
    By trevor4706 in forum Install and Boot
    Last Post: Jan 1st 2010, 04:30 PM
  3. install fine, then boots to blank screen
    By gutty96 in forum Installation and Boot
    Last Post: Nov 4th 2007, 05:48 PM
  4. nvidia 64bit driver, x-server, blank screen
    By Ajn in forum Hardware Support
    Last Post: Sep 22nd 2007, 07:30 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
