Hey All,
I recently installed Kubuntu 23.10 (fresh install from 23.04) and I'm missing the Hybrid-Sleep and Hibernate functions in the Power Management in the system settings menu. I had this previously in 23.04 and have had it on every other distro I've ran with Plasma.
installed using LVM and the first thing I did was reboot directly into the live .iso and increase my swap size. My laptop has 12 gb of ram, so I increased my swap to 17.5 gb, then did my first boot into the fresh install. I've checked and modified /etc/systemd/sleep.conf to allow for hybrid-sleep and hibernate, but they still do not show up in the menu. Do I have to rebuild grub first? Am I missing some step with systemctl?
Any help is appreciated, I've also listed out my lsblk below so you can see how the volumes are structured.
nvme0n1 259:0 0 238.5G 0 disk
├─nvme0n1p1 259:1 0 512M 0 part /boot/efi
└─nvme0n1p2 259:2 0 238G 0 part
├─vgkubuntu-root 252:0 0 220.4G 0 lvm /
└─vgkubuntu-swap_1 252:1 0 17.5G 0 lvm [SWAP]
