wireless connection problem right after installation
    Hi all,
    I am just a new Kubuntu player, get it downloaded yesterday and managed to installed properly in my Dell Dimension.
    I know Linux relies on the network pretty much but the very first problem is I cannot connect to the wireless network I had, which can be seen from the right bottom of the task bar, it showed me the option (AP) I have, but I just cannot connect them! It normally takes seconds in Windows, as it does not have password, (WEP) at all.
    Is there any problem or any further setup / configuration I forgot?
    Thank you all in advance!
    Marvin
    Re: wireless connection problem right after installation
    Do you know what kind of wireless adapter you have?
      Hi, it should be Dlink something.
      it's PCI interface, worked pretty well in XP.
      i can see the available AP in the range by clicking the icon at right botton of task bar, but when i click the one it always showing 'connecting...' then 'configuring device' afterwards, it just stopped showed a red cross on the icon. failed.
        I have not had that happen before. Is it possible that the AP is configured with WEP/WPA and the password/key is incorrect? Or maybe that the AP is using mac filtering and your machines mac is not in the list?
