Transparent icon not transparent in System Tray
    Just installed iplist. It has a single transparent background icon at /usr/share/pixmaps/ipblock.png.
    The transparency is respected by KDE where the icon is show for the K Menu entry (Applications > Internet > IPblock), but, when launched, the System Tray does not. To the best of my knowledge, this aberrant behavior of a transparent application icon has never happened before. Anyone know why this is happening, and more importantly, if/how to fix it?
    Slava Ukraini! πŸ‡ΊπŸ‡¦
    Re: Transparent icon not transparent in System Tray
    Maybe
    The KDE is using an iconcache to speed KDE/application startup times. Sometimes the KDE icon cache could get corrupted. Then there are wrong icons, corrupted icons or totally mission icons. If this is the problem - you could try to move/rename/remove the kde-icon-cache files
    Reset icon-cache
    Stop the application (iplist)
    Reset the kde icon cache by removing:
    rm /var/tmp/kdecache-$USER/kpc/kde-icon-cache.*
    This will remove the kde-icon-cache files. Sometimes you will need log out and log in.
    At here:
    rog@K910:~$ rm /var/tmp/kdecache-$USER/kpc/kde-icon-cache.*
    rm: cannot remove `/var/tmp/kdecache-rog/kpc/kde-icon-cache.*': No such file or directory
    The icon cache is empty and the cache is building from the scratch.
    Earlier:
    > Topic: Corrupt Desktop Icons
    > Topic: the exit icons have disappeared
    Before you edit, BACKUP !
    Why there are dead links ?
    2. Thread: Lost Information
      Thanks Rog. Tried your suggestion of deleting the /var/tmp/kdecache-$USER/kpc/kde-icon-cache.* files (three of them), then logged out and logged back in. The three files were recreated as you point out, but when I launched IPblock, it's System Tray icon is still not respecting the transparency.
      I am using the Tragedy 2.0.1 Plasma Theme. I'll switch to Oxygen and see if there is any difference in the handling of this icon.
        Okay, tried the Oxygen and Air Plasma Themes. In both, the transparency of the IPblock icon is not being respected when it's placed in the System Tray.
        The icon does have a transparent background. Why isn't its transparency being respected?
          Experimenting a bit - and then searching
          Editing with the Gimp the /usr/share/pixmaps/ipblock.png. Using the Eraser tool to remove the pixels from the icon. The Icon is changing in the K-menu but not in the System Tray.
          So it seems that the System Tray is not using the /usr/share/pixmaps/ipblock.png.
          Searching - this old Mandriva user board topic > KDE Tray Icons Have White Background [solved] is telling that the non KDE (or non Qt) applications could have hickups with the KDE color/transparency system.
            Hmm. "non KDE (or non QT) applications"
            I don't think that iplist is a GKT application - how can I tell? But that everywhere on my system, the icons background is transparent except for the System Tray just doesn't make any sense. I know it isn't my Tragedy Theme, as I tested it on the other two 'default' Themes and the behavior is the same.
            That would tell me that it's a plasma issue, but what?
              No - it is a C++ with the java GUI
              /iplist-0.28/src$ file main.cc
              main.cc: ASCII C program text
              apt-cache show iplist
              Package: iplist
              Status: install ok installed
              Priority: extra
              Section: net
              Depends: libc6 (>= 2.4), libgcc1 (>= 1:4.1.1), libnetfilter-queue1 (>= 0.0.15), libnfnetlink0 (>= 0.0.40), libpcre3 (>= 7.7), libstdc++6 (>= 4.4.0), zlib1g (>= 1:1.1.4), iptables, java6-runtime
              [img width=400 height=326]http://img710.imageshack.us/img710/6513/themes.png[/img]
              The Gui with the logo.png can be found /usr/share/java/ipblockUI.jar.
              Opening with the Ark: ark /usr/share/java/ipblockUI.jar
              logo.png is in /ipblockui/resources/logo.png.
              Sources etc. > PPA for uljanow
                I believe this bug is in Sun's code and still open. Seeing that Sun's JDK uses GTK libs, I expect this would apply to us KDE users also
                https://bugs.launchpad.net/ublogger/+bug/424326
                  Took a look at logo.png in Gwenview and in Gimp. It has a transparent background as well. Transparency is transparency, and .png is .png. The icon is being placed in the System Tray, so why isn't the transparency being respected?
                    I guess this also explains why my pidgin (only non-qt app with sys-tray icon, that i am using) icon doesn't have transparent background.
                      The original icon inside the .jar has the transparency. You guess is as good as mine - is this an java problem ( as the "skunk's" bug link suggest) or is this a KDE problem.
                      It would be nice if the KDE/GTK/Java/Python/whatever applications would play together - but meanwhile: a workaround.
                      1) Unpacking: /usr/share/java/ipblockUI.jar
                      2) Removing the transparency (adding a black background - as i have a black panel).
                      3) Repacking the ipblockUI.jar.
                      4) Testing - seems to work.
                        Here is a link to the bug in Sun's database
                        http://bugs.sun.com/bugdatabase/view...bug_id=6453521
                        Perhaps if it gets some more votes the priority might be bumped up
                          So it seems that the Sun AWT TrayIcon API was written specifically for animated icons in the system tray. How short sighted of the programmer! All they would have had to do, and even now, would need to do, is include a conditional check for animated icons. If an animated icon, process gr.fillRect(0, 0, curW, curH); else don't. Seems to me this would fix the problem once and for all.
