I recently built a computer from the following parts:
board: XFX MG-63Mi-7109 GeForce 7100 Socket 775
processor: Intel Pentium Dual Core E2200 2.2Ghz 1MB
memory: 2048MB PC5400 DDR2 667Mhz
video card: XFX GeForce 8500 GT 512MB
I got it up and running and installed Kubuntu on it (not sure how to check version). Since the desired use of the computer is to play films on a tv, I was very particular about the video output. I noticed that once or twice a minute the screen would flicker, which would really ruin any film watching experience, and was all-around annoying.
I found a Linux driver for the card on the XFX site and after some coaching from a seasoned Linux-user friend got it installed. Then I ran Adept and installed all the OS updates.
Upon reboot the GUI wouldn't load however I could log in and access files in a terminal screen. I googled the problem and found a solution in reconfiguring the x server. At that terminal screen I typed:
udo dpkg-reconfigure -phigh xserver-xorg
then:
startx
Now the GUI desktop loads perfectly every time except the flicker is back. In doing this, did I undo all the good of the proprietary driver? Since I'm not a native Linux user I am having trouble getting back to the panel that controls drivers to even see if the driver is still running. I thought possibly the refresh rate was off but after trying two different monitors the exact problem occurs.
Any ideas/help would be greatly appreciated.
then:
startx
