Hello! I have been using Kubuntu for some time and it is excellent.
However, I have occasionally run into a strange issue. This also occurred on Linux Mint, as I previously used that OS as well. Sometimes, I will try to open the plasma System Monitor, and it will load infinitely. The application is unresponsive and must be terminated to close the window. Mission Center also fails with the message "Failed to connect to Gatherer socket". I also attempted to run the command "systemctl status" but the command times out.
Besides these, the system behaves normally and there are no other issues. I can restart the computer to make the issue go away, but I would like to stop it from happening to begin with. Does anyone know why this might happen? Here is a video of the issue: https://zip.macver.org/u/97C2Oo.mp4
Thank you!
Thank you!
