partitionmanager asks for a password
    Dear all,
    I copied kubuntu25.iso on a USB flash drive. I started the computer on it (with ventoy). As I wanted to use the partitionsmanager to look at the partitions of my computer, it asked me for a password. I couldn't believe it. Thereafter I read that kubuntu25 has a lot of problems, which I agreed.
    A few weeks later, I copied kubuntu24.iso on a USB flash drive. I started the computer on it (still with ventoy). As I wanted to use the partitionmanager to look at the partitions of my computer, it also asked me for a password. I couldn't believe it once more.
    Please how can you explain this ? In both cases, I never set any password.
    In the past I started 100 times from a USB flash drive and I never had to enter any password.
    KDE Partition Manager has always prompted for your password.
    Slava Ukraini! 🇺🇦
      Not from the live USB session.
      I can't reproduce this, and I use Ventoy as well
      So, trying 25.04 it in a VM, it did ask for a password. It definitely did not do this when I installed 25.04 on my laptop last week. Or rather I do not recall it, and it is something I would have noted immediately.
      . I wanted to use the partitionsmanager to look at the partitions of my computer,
      You don't need to use a live session to use Partition Manager, especially if you are just looking.
      But in this case, just click Ok, without entering a password
      This is strange for sure.
        just hit ok
        there is no password for a live USB.
          Thank you Snowhog, claydoh and skyfishgoo.
          I wanted to see the partition before installing Kubuntu.
          I will click on OK without giving any password.
            also if you choose the manual or "something else" method in the installer you will get a partition manager like view of all your disks ... i always use this method rather than trust the installer to know where i want to put linux.
