Default browser problem
    [RESOLVED] Default browser problem
    Outside of `xdg-settings`, `mimeapps.list` and `update-alternatives` where can a system be getting a value for default application?
    My system is opening links in Brave browser even though it is not my default browser.
    In Sublime Text if I right click on a link and choose the option to open that URL in a browser, Brave browser will open.
    image of url link dialog box in Sublime Text
    In the Java application DBeaver if I am prompted with a software update screen and click to view the details , the system redirects to Brave browser.
    In Thunderbird if I click on a web link in an e-mail, it opens in Brave. Refining this functionality in Thunderbird yields an interesting clue. If I navigate to the Preferences section (Menu Edit > Settings scroll down to ‘Files & Attachments’ ) for opening applications `http` and `https` offer choices.
    image of file & Attachments section in Thunderbird preferences
    Where is Thunderbird getting the idea Brave is the default browser? Everything else in my system is pointing towards Thorium.
    In Brave settings, setting Brave as the default is unchecked. Any *.desktop shortcuts for Brave on the system have the `--no-default-browser-check` flag on the command line syntax.
    In `~/.config/mimeapps.list` any values with `thorium-browser.desktop` are closer to the top than `com.brave.Browser.desktop` or `brave-browser.desktop`.
    In `update-alternatives` these are the outputs for `gnome-www-browser`, `www-browser` or `x-www-browser​`:
    ```bash
    > sudo update-alternatives --get-selections | grep brow
    ```text
    gnome-www-browser auto /usr/bin/thorium-browser
    infobrowser auto /usr/bin/info
    x-www-browser auto /usr/bin/thorium-browser
    ```bash
    xdg-settings check default-web-browser thorium-browser.desktop
    yes
    ```bash
    > sudo update-alternatives --config gnome-www-browser
    ```text
    There are 4 choices for the alternative gnome-www-browser (providing /usr/bin/gnome-www-browser).
    Selection Path Priority Status
    * 0 /usr/bin/thorium-browser 200 auto mode
    1 /usr/bin/brave-browser-stable 10 manual mode
    2 /usr/bin/thorium-browser 200 manual mode
    3 /usr/bin/waterfox 40 manual mode
    ```bash
    > sudo update-alternatives --config x-www-browser
    ```text
    There are 3 choices for the alternative x-www-browser (providing /usr/bin/x-www-browser).
    1 /usr/bin/brave-browser-stable 100 manual mode
    Press <enter> to keep the current choice[*], or type selection number:
    ```bash
    sudo update-alternatives --config www-browser
    ```text
    There are 2 choices for the alternative www-browser (providing /usr/bin/www-browser).
    Have you looked at K > System Settings > [Personalization] > Applications > Default Applications > Web Browser ?
    That's where I've managed to fix this issue with Firefox versus Chrome.
    I do recall that after making a choice, I had to do something ...
    like close everything, restart the PC, and then it would take full effect.
    (On this subject, I can see you are a more advanced user! more so than I am :-) )
    Last edited by Qqmike; Apr 16, 2026, 06:41 AM. Reason: Added "Default Applications" to the path
      What does the Default Applications section in System Settings show, not the file associations part?
      Check each app's settings, often this is a cuplprit, if they have options for this.
      Tbird (and Firefox) usually honors the system settings, or rather imports those, or something similar, but is well known to get broken sometimes.
      Use XDG tools to see what is listed; the www-browser and update-alternatives things are not used everywhere, and are not as relevant these days, especially for Flaptaks and Snaps; in general xdg is what is being used overall.
      The command x-www-browserfor me opens Chrome, but otherwise my default is FF in System Settings and via XDG, which is honored everywhere for me. Including Dbeaver installed as a flatpak to test.
      This is on Plasma 6, I don't have a Plasma 5 install any longer; I just upgraded my secondary PC to 26.04, and my main runs neon, which is 24.04, but does have upgraded XDG parts. So if there is a bug in 24.04, I am not able to see it at the moment.
      $ xdg-settings get default-web-browser
      firefox.desktop
      $ update-alternatives --display x-www-browser
      x-www-browser - auto mode
      link best version is /usr/bin/google-chrome-stable
      link currently points to /usr/bin/google-chrome-stable
      link x-www-browser is /usr/bin/x-www-browser
      slave x-www-browser.1.gz is /usr/share/man/man1/x-www-browser.1.gz
      /usr/bin/firefox - priority 100
      slave x-www-browser.1.gz: /usr/share/man/man1/firefox.1.gz
      /usr/bin/google-chrome-stable - priority 200
      /usr/bin/konqueror - priority 30
      slave x-www-browser.1.gz: /usr/share/man/man1/konqueror.1.gz
      Basically, tl;dr look at xdg settings and system settings, not the more legacy update-alternatives things.
        please post output of
        echo $BROWSER
        gio mime x-scheme-handler/http
        gio mime x-scheme-handler/https​
        ʟɨռʊӼ ʄօʀ ʟɨʄɛ
          Under System Settings > Applications > Default Applications the Thorium Browser is set as the default Web Browser.
          I do no use Flatpaks or Snaps. So the existence of one of those overriding other default preferences is a non-factor.
          ​Rebooting the system had no effect.
          The commands and output of xdg-settings and update-alternatives:
          link best version is /usr/bin/thorium-browser
          link currently points to /usr/bin/thorium-browser
          /usr/bin/brave-browser-stable - priority 100
          /usr/bin/thorium-browser - priority 200
          /usr/bin/waterfox - priority 40
          ​> xdg-settings check default-web-browser thorium-browser.desktop
          yes
            echo $BROWSER
            We have a winner for discovering what is pointing to brave-browser.desktop!
            > echo $BROWSER
            Default application for “x-scheme-handler/http”: brave-browser.desktop
            Registered applications:
                  waterfox.desktop
                  kfmclient_html.desktop
                  thorium-shell.desktop
                  vivaldi-stable.desktop
                  firefox_firefox.desktop
            Recommended applications:
                  waterfox.desktop
            No default applications for “x-scheme-handler/https”
            Attempting to correct this handler I did 'man gio'. From the man page:
            mime MIMETYPE [HANDLER]
                       If no handler is given, the mime command lists the registered and recommended
                       applications for the mimetype. If a handler is given, it is set as the default handler
                       for the mimetype.
                       Handlers must be specified by their desktop file name, including the extension.
                       Example: org.gnome.gedit.desktop.
            Absent from the list of Registered applications above is an entry for thorium-browser.desktop.
            If I try 'gio mime x-scheme-handler/http thorium-browser.desktop', this is the response:
            gio: Failed to load info for handler “thorium-browser.desktop”
            I have tried putting 'thorium-browser.desktop' in '/usr/share/applications/' or '~/.local/share/applications/' singularly one location or both locations simultaneously and re-run 'gio mime x-scheme-handler/http thorium-browser.desktop'. Each time the result has been:
            I can not find anything in web searches using "register desktop file gio" other than links to the gio manpage.
            How do I fix 'gio mime x-scheme-handler/http' to point to "thorium-browser.desktop"?
            As a side question, desktop files can be in '/usr/share/applications/' or '~/.local/share/applications/'. Does the system look in both those locations or just '/usr/share/applications/' for 'gio' or files referenced in '~/.config/mimeapps.list'​?
              when i click on web links within parts of the kde desktop like help functions, etc it opens the link in falkon instead of my default browser (firefox) which i find handy so that it does not disturb my tabs in firefox.
              when i go to file associations in settings, i see that if i search for .html in the search box, i find that:
              under the known types listed as "applications", the setting is to open in a separate viewer
              and under the known types listed as "xhtml+xml" the top application is falkon
              then under the known types listed as "html" the top application is the zen browser which was the last one i installed
              so, i would look in settings > file associations drill down into the mimetype you are seeking to control
                run these
                gio mime x-scheme-handler/http thorium-shell.desktop
                gio mime x-scheme-handler/https thorium-shell.desktop​
                update XDG
                xdg-mime default thorium-shell.desktop x-scheme-handler/http
                xdg-mime default thorium-shell.desktop x-scheme-handler/https​
                rebuilt cache
                update-desktop-database ~/.local/share/applications
                Thunderbird, DBeaver, Sublime should all switch immediately (no reboot needed).​
                ps:Thorium installed as thorium-shell.desktop, not thorium-browser.desktop​
                ʟɨռʊӼ ʄօʀ ʟɨʄɛ
                  On this,
                  politely, this is wrong, at least as far as my system. Thorium shell is a separate application. It does not launch the Thorium browser.
                  Opening /usr/share/applications/thorium-shell.desktop and examining the Exec line it is:
                  Exec=/usr/bin/thorium-shell %U
                  Opening /usr/share/applications/thorium-browser.desktop and examining the Exec line it is:
                  Exec=/usr/bin/thorium-browser %U
                  When I installed Thorium on my system it created two desktop files:
                  thorium-browser.desktop is what appears in entries of ~/.config/mimeapps.list
                  thorium-browser.desktop is what appears in update-alternatives
                  Under /usr/bin/ path there are:
                  /usr/bin/thorium-browser-stable -> /opt/chromium.org/thorium/thorium-browser
                  /usr/bin/thorium-browser -> /opt/chromium.org/thorium/thorium-browser
                  If I follow your guidelines, this is the result of using thorium-shell.desktop as the 'x-scheme-handler/https'
                  thorium-shell rendering
                  The same url opened in a new window of thorium I manually open
                  thorium browser rendering
                  Is it possible you downloaded and installed Thorium to help provide an answer?
                  Based on the answer you provided, it raised the questions in my mind, 'How could this be? Has there been a change in the Thorium package?' I downloaded and installed a newer version than the version on my system. On a fresh install, the set-up of thorium-shell and thorium-browser are exactly as you presented and shared.
                  But that fresh install is broken for it does not open thorium browser in an interface similar to Chromium or Google Chrome. From this fresh install I would rewrite the exec lines in the .desktop files or open a ticket on the Thorium support board.
                  Reinstalling the older version of Thorium on the system fixed the original problem.
                  Default application for “x-scheme-handler/https”: thorium-browser.desktop
                          waterfox.desktop
                          waterfox.desktop
                  What does gio mime look for in a desktop file in order for it to be considered a possible alternative?
                    gio mime considers a .desktop file valid if:
                    Type=Application
                    Exec= exists
                    MimeType= includes the scheme requested
                    Everything else is ignored.
                    try this instead
                    sudo nano /usr/share/applications/thorium-shell.desktop
                    remove this part MimeType=x-scheme-handler/http;x-scheme-handler/https;
                    rebuild cache
                    update-desktop-database /usr/share/applications
                    ʟɨռʊӼ ʄօʀ ʟɨʄɛ
                      I spy Thorium Browser having three different .desktop files, if that matters.
                      org.chromium.Thorium.desktop as well as the other two.
                      A small snippet:
                      [Desktop Entry]
                      # This is the same as thorium-browser.desktop except NoDisplay=true prevents
                      # duplicate menu entries. This is required to match the application ID
                      # used by XDG desktop portal, which has stricter naming requirements.
                      # The old desktop file is kept to preserve default browser settings.
                      NoDisplay=true
                      Version=1.0
                      Name=Thorium Browser​
                      Is gio even relevant on KDE, or on the desktop proper? Just a random thought, and getting confused as to where it is used.
                        A small snippet:
                        [Desktop Entry]
                        NoDisplay=true
                        Version=1.0
                        org.chromium.Thorium.desktop is in Thorium version 138 and not relevant to the version 130 I am using. Once I get a handle on resolving this gio issue I plan to tackle upgrading to 138.
                        gio is relevant in so far as it is the reason Brave was misinterpreted as the default browser when everything else on my system was pointing to Thorium as the default browser. Otherwise I'm with you on thinking Why is a utility for Gnome interfering with KDE?
                          Type=Application
                          Exec= exists
                          try this instead
                          rebuild cache
                          Before doing what you suggest I executed
                          gio mime x-scheme-handler/https brave-browser.desktop
                          for testing purposes.
                          Carrying what you suggest has no impact on
                          gio mime x-scheme-handler/https thorium-browser.desktop
                          'gio' will still adopt 'thorium-browser.desktop' as the https handler even though 'x-scheme-handler/https;' has been removed from the 'MimeType'.
                          There must be something in the 'deb' package that executes at time it is applied to set the 'gio mime x-scheme-handler/https thorium-browser.desktop'. When I reinstalled 'thorium-browser_130.0.6723.174_SSE3.deb' it solved this 'gio' problem.
