Hi, just noticed that my wifi isn't working and not sure if it is my hardware (network card) or something else. Here's what I noticed:
out of the blue the wifi wouldn't connect, I restarted the router and my laptop and it seemed to fix itself, whatever the issue was and then the next day the same thing happened but restart of both laptop and router didn't fix the issue this time and every attempt to connect to my wifi or any other wifi network results in the same thing - there's an attempt and then it is unable to and I get a pop up in the right hand corner telling me this.
I am able to connect with a wired (ethernet) connection
OS kubuntu 24.04 LTS
KDE Plasma 5.27.12
kernel: 6.8.0-71 64 bit
the laptop is an ASUS F555LA-AB31 and network card is RTL8111/8168/8411 (output from nmcli)
I've made sure that wifi is toggled on and there isn't a function key on the keyboard that inadvertantly turns off wifi as with other laptops so pretty sure the obvious stuff is not the issue
before I go ahead and swap out the network card, I'd like to be sure that this is in fact a hardware issue and not a software issue, what are the steps to make that determination?
thank you
KDE Plasma 5.27.12
thank you
