I upgraded from 22.04 to 24.04 several months ago. The PC was very sluggish. I decided to re-install 22.04. I used the same GPT partitions (Home, Swap, and Root). I reformatted each one, giving each one the same mount points. The system was supposed to put the boot command on Sda, (I'm not exactly sure whether that is at the beginning of the hard drive or on the root partition. Home is Sda2. Root is Sda4.)
The installation completed. When I restarted, I was stopped by the following message on the screen:
Gnu Grub Version 2.12
Minimal Bash-like editing is supported. For the first word, TAB lists possible command completions. . . .
There was a type-in command line field preceded by Grub>
It seems impossible to exit from this prompt. I can't do anything to get beyond it and complete the startup.
I can't figure out how Grub 2.1 became involved in this installation process. It seems that something is stored at the beginning of the hard drive--- perhaps something left over from 22.04-- and it is causing problems.
Any suggestions? I really don't want to have to blank the whole drive, re-create the GPT partition, and start over again.
