I have discovered that I no longer get any sound output if I select any HDMI option for the output device on my Framework 13 laptop, after upgrading from Kubuntu 22.04 LTS to 24.04.01 LTS (it was working fine before the upgrade). Built-in speaker output is working fine. Not sure where to start troubleshooting, so can someone help? I did notice that all the duplicate HDMI output options vanished (e.g., HDMI 2 Stereo, HDMI 2 5.1, HDMI 3 Stereo, etc.), but I never needed those options before, either, no matter which HDMI port I used.
No sound output through HDMI after upgrading to 24.04.01
System Settings -> Hardware -> Audio gives me the following options:- Off
- Analog Stereo Duplex
- Analog Stereo Output
- Digital Stereo (HDMI) Output + Analog Stereo Input
- Digital Surround 5.1 (HDMI) Output + Analog Stereo Input
- Digital Surround 7.1 (HDMI) Output + Analog Stereo Input
- Analog Stereo Input
- Pro Audio
- Built-in Audio Pro
- Built-in Audio Pro 3
- Built-in Audio Pro 7
- Built-in Audio Pro 8
- Built-in Audio Pro 9
I'm guessing it's either a problem with PipeWire configuration or a conflict between PipeWire and PulseAudio, but I have no idea how to continue troubleshooting at this point.
Edit: I'm connecting to an Onkyo TX-RZ50 AV receiver, which is connected to a Samsung 4K TV,Last edited by jrwatts; Sep 07, 2024, 02:21 AM.
Do #2 or #3 work by any chance?
There (probably) is no conflict with Pulse and Pipewire , as the main pulseaaudio service should not be running.
lets check some things:
Code:$ pactl info | grep "^Server" Server String: /run/user/1000/pulse/native Server Protocol Version: 35 Server Name: PulseAudio (on PipeWire 1.0.5) <----------- Server Version: 15.0.0
Code:$ systemctl status --user pipewire-* ● pipewire-pulse.service - PipeWire PulseAudio Loaded: loaded (/usr/lib/systemd/user/pipewire-pulse.service; enabled; preset: enabled) Active: active (running) since Sat 2024-09-07 19:15:28 AEST; 9min ago <-------------------- TriggeredBy: ● pipewire-pulse.socket Main PID: 1368 (pipewire-pulse) Tasks: 3 (limit: 9259) Memory: 4.8M (peak: 5.1M) CPU: 40ms CGroup: /user.slice/user-1000.slice/user@1000.service/session.slice/pipewire-pulse.service └─1368 /usr/bin/pipewire-pulse Sep 07 19:15:28 kromey-elemi systemd[1352]: Started pipewire-pulse.service - PipeWire PulseAudio. ● pipewire-pulse.socket - PipeWire PulseAudio Loaded: loaded (/usr/lib/systemd/user/pipewire-pulse.socket; enabled; preset: enabled) Active: active (running) since Sat 2024-09-07 19:15:28 AEST; 9min ago <-------------------------- Triggers: ● pipewire-pulse.service Listen: /run/user/1000/pulse/native (Stream) CGroup: /user.slice/user-1000.slice/user@1000.service/app.slice/pipewire-pulse.socket
What audio hardware do you have?Code:$ systemctl status --user pulseaudio ○ pulseaudio.service - Sound Service Loaded: loaded (/usr/lib/systemd/user/pulseaudio.service; enabled; preset: enabled) Active: inactive (dead) <---------------------- TriggeredBy: ○ pulseaudio.socket
$HOME/.local/state/wireplumber/
use alsamixer to both see which chip is being used, as well as checking that something hasn't been disabled, though this probably won't be obvious at all.
You can also try to reset pipewire/wireplumber by deleting
$HOME/.local/state/wireplumber/ and $HOME/.local/state/pipewire/media-session.d/ (if present) and
$HOME/.config/pulse/ (if present), and reboot.
Yes, #2 & #3 work through the built-in speakers.
Here's my output from those commands:
Code:$ pactl info | grep "^Server" Server String: /run/user/1000/pulse/native Server Protocol Version: 35 Server Name: PulseAudio (on PipeWire 1.0.5) Server Version: 15.0.0
Code:$ systemctl status --user pipewire-* ● pipewire-pulse.socket - PipeWire PulseAudio Loaded: loaded (/usr/lib/systemd/user/pipewire-pulse.socket; enabled; preset: enabled) Active: active (running) since Sat 2024-09-07 04:09:16 MDT; 6min ago Triggers: ● pipewire-pulse.service Listen: /run/user/1000/pulse/native (Stream) CGroup: /user.slice/user-1000.slice/user@1000.service/app.slice/pipewire-pulse.socket Sep 07 04:09:16 Amy systemd[1652]: Listening on pipewire-pulse.socket - PipeWire PulseAudio. ● pipewire-pulse.service - PipeWire PulseAudio Loaded: loaded (/usr/lib/systemd/user/pipewire-pulse.service; enabled; preset: enabled) Active: active (running) since Sat 2024-09-07 04:09:16 MDT; 6min ago TriggeredBy: ● pipewire-pulse.socket Main PID: 1666 (pipewire-pulse) Tasks: 3 (limit: 38079) Memory: 22.7M (peak: 23.6M) CPU: 692ms CGroup: /user.slice/user-1000.slice/user@1000.service/session.slice/pipewire-pulse.service └─1666 /usr/bin/pipewire-pulse Sep 07 04:09:16 Amy systemd[1652]: Started pipewire-pulse.service - PipeWire PulseAudio. alsamixer shows "Card: HDA Intel PCM" and "Chip: IDT 92HD95" (This is a 2nd generation Framework 13 laptop, with Intel i7-1260P.)Code:$ systemctl status --user pulseaudio ○ pulseaudio.service - Sound Service Loaded: loaded (/usr/lib/systemd/user/pulseaudio.service; enabled; preset: enabled) Active: inactive (dead) TriggeredBy: ○ pulseaudio.socket
However, I get this:
$HOME/.local/state/pipewire/media-session.d/ also doesn't exist.Code:$ ls $HOME/.local/state/wireplumber/ ls: cannot access '/home/jonathan/.local/state/wireplumber/': No such file or directory
I tried deleting $HOME/.config/pulse/ and rebooting, and it was re-created, holding a single "cookie" subdirectory (and still, only the built-in speaker output works),
edit: if I manually type the command instead of copy-pasting, the wireplumber state directory does exist:
Code:$ ls .local/state/wireplumber/ default-nodes default-profile default-routes restore-stream
