Hello
I'm running Kubuntu 24.04.2 LTS on Dell Inspiron 15 3530 i5
Everything went fine for about year of use until moment, when I was working on battery without power cord and laptop went to sleep (that's my observation, not 100% sure this is the situation or cause).
After that moment, I wasn't able to work with my bluetooth mouse or use bluetooth head phones to listen to music, I wasn't able to reconnect to devices visible in bluetooth tab running in system tray.
This is the output from command line:
(headfones put into pairing mode, but don't show up)
I also did more advanced settings:
I also did
and restarted laptop too
nothing has helped... any suggestions or experience with this serious issue? Thank you
uname -a Linux martin-inspiron153530 6.8.0-63-generic #66-Ubuntu SMP PREEMPT_DYNAMIC Fri Jun 13 20:25:30 UTC 2025 x86_64 x86_64 x86_64 GNU/Linux
sudo lsusb -v | grep -i bluetooth Bus 001 Device 009: ID 0bda:887b Realtek Semiconductor Corp. Bluetooth Radio bDeviceProtocol 1 Bluetooth idProduct 0x887b Bluetooth Radio iProduct 2 Bluetooth Radio bInterfaceProtocol 1 Bluetooth iInterface 4 Bluetooth Radio bInterfaceProtocol 1 Bluetooth iInterface 4 Bluetooth Radio bInterfaceProtocol 1 Bluetooth iInterface 4 Bluetooth Radio bInterfaceProtocol 1 Bluetooth iInterface 4 Bluetooth Radio bInterfaceProtocol 1 Bluetooth iInterface 4 Bluetooth Radio bInterfaceProtocol 1 Bluetooth iInterface 4 Bluetooth Radio bInterfaceProtocol 1 Bluetooth iInterface 4 Bluetooth Radio
systemctl status bluetooth ● bluetooth.service - Bluetooth service Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; preset: enabled) Active: active (running) since Thu 2025-07-10 09:18:02 CEST; 28min ago Docs: man:bluetoothd(8) Main PID: 1155 (bluetoothd) Status: "Running" Tasks: 1 (limit: 18713) Memory: 3.4M (peak: 4.3M) CPU: 45ms CGroup: /system.slice/bluetooth.service └─1155 /usr/libexec/bluetooth/bluetoothd júl 10 09:18:12 martin-inspiron153530 bluetoothd[1155]: Endpoint registered: sender=:1.57 path=/MediaEndpoint/A2DPSource/aptx_ll_1 júl 10 09:18:12 martin-inspiron153530 bluetoothd[1155]: Endpoint registered: sender=:1.57 path=/MediaEndpoint/A2DPSource/aptx_ll_0 júl 10 09:18:12 martin-inspiron153530 bluetoothd[1155]: Endpoint registered: sender=:1.57 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_1 júl 10 09:18:12 martin-inspiron153530 bluetoothd[1155]: Endpoint registered: sender=:1.57 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_0 júl 10 09:18:12 martin-inspiron153530 bluetoothd[1155]: Endpoint registered: sender=:1.57 path=/MediaEndpoint/A2DPSource/faststream júl 10 09:18:12 martin-inspiron153530 bluetoothd[1155]: Endpoint registered: sender=:1.57 path=/MediaEndpoint/A2DPSource/faststream_duplex júl 10 09:18:12 martin-inspiron153530 bluetoothd[1155]: Endpoint registered: sender=:1.57 path=/MediaEndpoint/A2DPSink/opus_05 júl 10 09:18:12 martin-inspiron153530 bluetoothd[1155]: Endpoint registered: sender=:1.57 path=/MediaEndpoint/A2DPSource/opus_05 júl 10 09:18:12 martin-inspiron153530 bluetoothd[1155]: Endpoint registered: sender=:1.57 path=/MediaEndpoint/A2DPSink/opus_05_duplex júl 10 09:18:12 martin-inspiron153530 bluetoothd[1155]: Endpoint registered: sender=:1.57 path=/MediaEndpoint/A2DPSource/opus_05_duplex
bluetoothctl Waiting to connect to bluetoothd...[bluetooth]# Agent registered [bluetooth]# list Controller A8:3B:76:DA:90:24 martin-inspiron153530 [default] [bluetooth]# power on [bluetooth]# Changing power on succeeded [bluetooth]# scan on [bluetooth]# SetDiscoveryFilter success [bluetooth]# Discovery started [bluetooth]#
rfkill ID TYPE DEVICE SOFT HARD 0 bluetooth hci0 unblocked unblocked 1 wlan phy0 unblocked unblocked
sudo dmesg | grep -i "bluetooth" | tail -n 20 [ 4.355873] Bluetooth: HCI socket layer initialized [ 4.355875] Bluetooth: L2CAP socket layer initialized [ 4.355879] Bluetooth: SCO socket layer initialized [ 4.548156] Bluetooth: hci0: RTL: examining hci_ver=0b hci_rev=000b lmp_ver=0b lmp_subver=8852 [ 4.549071] Bluetooth: hci0: RTL: rom_version status=0 version=1 [ 4.549090] Bluetooth: hci0: RTL: loading rtl_bt/rtl8852bu_fw.bin [ 4.550442] Bluetooth: hci0: RTL: loading rtl_bt/rtl8852bu_config.bin [ 4.551030] Bluetooth: hci0: RTL: cfg_sz 6, total sz 58003 [ 4.878158] Bluetooth: hci0: RTL: fw version 0xdbc6b20f [ 4.963029] Bluetooth: hci0: AOSP extensions version v1.00 [ 4.963033] Bluetooth: hci0: AOSP quality report is supported [ 9.103794] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [ 9.103798] Bluetooth: BNEP filters: protocol multicast [ 9.103803] Bluetooth: BNEP socket layer initialized [ 9.105508] Bluetooth: MGMT ver 1.22 [ 9.216138] Bluetooth: hci0: AOSP extensions version v1.00 [ 9.216152] Bluetooth: hci0: AOSP quality report is supported [ 11.543042] Bluetooth: RFCOMM TTY layer initialized [ 11.543048] Bluetooth: RFCOMM socket layer initialized [ 11.543053] Bluetooth: RFCOMM ver 1.11
sudo dmesg | grep -i "realtek" | tail -n 20 [ 2.996310] usb 1-10: Manufacturer: Realtek [ 8.065713] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC3254: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:speaker [ 8.065722] snd_hda_codec_realtek hdaudioC0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0) [ 8.065725] snd_hda_codec_realtek hdaudioC0D0: hp_outs=1 (0x21/0x0/0x0/0x0/0x0) [ 8.065727] snd_hda_codec_realtek hdaudioC0D0: mono: mono_out=0x0 [ 8.065729] snd_hda_codec_realtek hdaudioC0D0: inputs: [ 8.065730] snd_hda_codec_realtek hdaudioC0D0: Headset Mic=0x19 [ 8.065732] snd_hda_codec_realtek hdaudioC0D0: Headphone Mic=0x1b [ 8.065735] snd_hda_codec_realtek hdaudioC0D0: Internal Mic=0x12
rfkill list all 0: hci0: Bluetooth Soft blocked: no Hard blocked: no 1: phy0: Wireless LAN Soft blocked: no Hard blocked: no
lsusb Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 001 Device 002: ID 067b:2586 Prolific Technology, Inc. USB 2.0 Hub Bus 001 Device 003: ID 25a7:fa61 Areson Technology Corp Elecom Co., Ltd MR-K013 Multicard Reader Bus 001 Device 004: ID 067b:2586 Prolific Technology, Inc. USB 2.0 Hub Bus 001 Device 005: ID 27c6:639c Shenzhen Goodix Technology Co.,Ltd. Goodix USB2.0 MISC Bus 001 Device 006: ID 1bcf:2283 Sunplus Innovation Technology Inc. Full HD webcam Bus 001 Device 007: ID 046d:c31c Logitech, Inc. Keyboard K120 Bus 001 Device 008: ID 0bda:5556 Realtek Semiconductor Corp. Integrated_Webcam_FHD Bus 001 Device 009: ID 0bda:887b Realtek Semiconductor Corp. Bluetooth Radio Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
sudo nano /etc/default/grub GRUB_CMDLINE_LINUX_DEFAULT="usbcore.autosuspend=-1" sudo update-grub sudo reboot
echo 'ACTION=="add", SUBSYSTEM=="usb", ATTR{idVendor}=="0bda", ATTR{idProduct}=="887b", ATTR{power/autosuspend}=="-1"' | sudo tee /etc/udev/rules.d/99-realtek-bt-fix.rules
sudo udevadm control --reload-rules
sudo udevadm trigger
sudo reboot
I also did
sudo systemctl restart bluetooth
