Bluetooth Connection Issues with Headphones
    Hello!
    i have issues with bluetooth on kubuntu 24.04. i have an tp-link ub500 which seems to work fine, but i cannot connect to my headphones (xiaomi buds 6 lite) it. first i tried trough the graphical interface, but it didn't work. with bluetoothctl it finally worked, then some magic the ai told me to do where i first executed sudo rfcomm bind /dev/rfcomm 78:99:87:B0:33:78 and then pactl set-default-sink "bluez_sink.78:99:87:B0:33:78, and now it kind of works, but the audio really stutters and is not useable. still, connecting trough the graphical interface in the taskbar doesn't work, which is also a bummer, because to every time connect trough the terminal seems not ideal to me.
    next up i tried installing blueman, but also no real improvement: the audio still stutters, sometimes it works for several seconds, but definetly not useable.
    any help is greatly appreciated, since i really would like bluetooth to work.
    thank you in advance!
    Is your Kubuntu 24.04 installed on a PC that also has Windows? You may want to read through this thread; it isn't long. https://forums.linuxmint.com/viewtopic.php?t=368114
      well, i do have a dualboot, but haven't booted into windows in ages. apart from this, i think my problem is different than the one discussed in the thread, since in general my bluetooth does work.
