Huawei E5372 mobile wifi not being recognised
    I've been a Kubuntu user for a few years, but still class myself as a Linux noob. I'm trying to get my Huawei E5372 mobile wifi device (branded Kanguru externally) to work on 22.04 but with no success. It works well on my Windows partition (I'm dual-booting) but is not recognised in Kubuntu. Every time I boot up it is recognised as a Kanguru optical device and not a networking device. So my first question is, is there any way I can stop the system mounting my device as storage?
    After skimming some other forums I issued the following commands. Note that this is not a direct screen shot as I have to save the output on my Windows partition in order to be able to upload to the Internet.
    g@g-zen:~$ip link
    1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT group default qlen 1000
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    2: enp3s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP mode DEFAULT group default qlen 1000
    link/ether f4:b5:20:2d:d3:8c brd ff:ff:ff:ff:ff:ff
    3: wwx0c5b8f279a64: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN mode DEFAULT group default qlen 1000
    link/ether 0c:5b:8f:27:9a:64 brd ff:ff:ff:ff:ff:ff
    g@g-zen:~$ lsusb
    Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
    Bus 003 Device 002: ID 12d1:1506 Huawei Technologies Co., Ltd. Modem/Networkcard
    Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
    Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
    Bus 001 Device 005: ID 058f:6362 Alcor Micro Corp. Flash Card Reader/Writer
    Bus 001 Device 004: ID 046d:c077 Logitech, Inc. M105 Optical Mouse
    Bus 001 Device 003: ID 04b3:3025 IBM Corp. NetVista Full Width Keyboard
    Bus 001 Device 002: ID 04f9:0027 Brother Industries, Ltd HL-2030 Laser Printer
    Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
    g@g-zen:~$ ls /dev/ttyUSB*
    /dev/ttyUSB0
    g@g-zen:~$
    Any help would be very gratefully received.
    Graham
    Welcome!
    Perhaps usb-modeswitch will help?
    If you apt info usb-modeswitch it sounds like this could be the right tool for this device.
    https://askubuntu.com/questions/4634...ongle-on-12-04
      Thanks for the welcome, the suggestion and the link - much appreciated!
      I issued the commands you suggested and usb-modeswitch is installed but does not appear to be initiating the switch. ifconfig is not installed on my system and when I tried to install net-tools, the package could not be found. So I'm in a bit of a catch-22 ; I need the Internet to download packages to make my Internet work... More in hope than expectation I tried to activate wwan0 but the device does not exist (unsurprisingly). Here is a print of my shell session:
      g@g-zen:~$ sudo apt info usb-modeswitch
      [sudo] password for g:
      Package: usb-modeswitch
      Version: 2.6.1-3ubuntu2
      Status: install ok installed
      Priority: optional
      Section: comm
      Maintainer: Ubuntu Developers <ubuntu-devel-discuss@lists.ubuntu.com>
      Original-Maintainer: Thorsten Alteholz <debian@alteholz.de>
      Installed-Size: 142 kB
      Depends: tcl, usb-modeswitch-data, libc6 (>= 2.34), libusb-1.0-0 (>= 2:1.0.9)
      Suggests: comgt, wvdial
      Homepage: https://www.draisberghof.de/usb_modeswitch/
      Download-Size: unknown
      APT-Manual-Installed: no
      APT-Sources: /var/lib/dpkg/status
      Description: mode switching tool for controlling "flip flop" USB devices
      Several new USB devices have their proprietary Windows drivers onboard,
      especially WAN dongles. When plugged in for the first time, they act
      like a flash storage and start installing the driver from there. If
      the driver is already installed, the storage device vanishes and
      a new device, such as an USB modem, shows up. This is called the
      "ZeroCD" feature.
      On Debian, this is not needed, since the driver is included as a
      Linux kernel module, such as "usbserial". However, the device still
      shows up as "usb-storage" by default. usb-modeswitch solves that
      issue by sending the command which actually performs the switching
      of the device from "usb-storage" to "usbserial".
      This package contains the binaries and the brother scripts.
      g@g-zen:~$ ifconfig
      Command 'ifconfig' not found, but can be installed with:
      sudo apt install net-tools
      g@g-zen:~$ sudo apt install net-tools
      Reading package lists... Done
      Building dependency tree... Done
      E: Unable to locate package net-tools
      g@g-zen:~$ sudo ip link set wwan0 up
      Cannot find device "wwan0"​
      Is there any way to stop the Huawei being mounted as an optical device/storage?
        Bit of an update. The Huawei mobile wifi is in use as my internet access when at our home in France. We are only there 2-3 months of the year maximum, so it makes no sense to me to sign up for a full-time contract when it will be unused for 9 months of the year. Earlier this week I drove back to the UK and brought the desktop PC and the Huawei device I use there back to the UK, so I can continue my troubleshooting. At least in the UK if I need to download any packages I can just plug the PC into my router and use 'normal' broadband.
        But I really do need to get the Huawei figured out and working for when I next go back to France.​
          I've been trying to get to the bottom of this problem and it seems to me that the root problem is that the Huawei device is initially recognised by Linux as being a flash storage device, and not a mobile wifi device. Every time I login the device is present as flash storage. I can eject it, but of course the next time I boot into Kubuntu it pops back as flash storage. This is the output I see from 'usb-devices'...
          T: Bus=01 Lev=01 Prnt=01 Port=04 Cnt=01 Dev#= 2 Spd=480 MxCh= 0
          D: Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1
          P: Vendor=12d1 ProdID=1506 Rev=01.02
          S: Manufacturer=HUAWEI Technology
          S: Product=HUAWEI Mobile
          C: #Ifs= 4 Cfg#= 1 Atr=80 MxPwr=500mA
          I: If#= 0 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=02 Prot=12 Driver=option
          E: Ad=01(O) Atr=02(Bulk) MxPS= 512 Ivl=4ms
          E: Ad=81(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
          I: If#= 1 Alt= 1 #EPs= 3 Cls=ff(vend.) Sub=02 Prot=16 Driver=huawei_cdc_ncm
          E: Ad=02(O) Atr=02(Bulk) MxPS= 512 Ivl=4ms
          E: Ad=82(I) Atr=03(Int.) MxPS= 64 Ivl=2ms
          E: Ad=83(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
          I: If#= 2 Alt= 0 #EPs= 2 Cls=08(stor.) Sub=06 Prot=50 Driver=usb-storage
          E: Ad=03(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
          E: Ad=84(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
          I: If#= 3 Alt= 0 #EPs= 2 Cls=08(stor.) Sub=06 Prot=50 Driver=usb-storage
          E: Ad=04(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
          E: Ad=85(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms​
          So I really need to find a way to permanently disable/detach/remove interfaces 2 and 3. I think that once they are unable to be recognised at boot time, then I stand a chance of Linux recognising the network device and installing it.
          So - how do I go about disabling the usb-storage interfaces permanently?
