Problem installing insight debugger
    I`m trying to install the insight debugger into Kubuntu 20.04 LTS (fully updated) using the Synaptic package manager. However, when I enter "insight" (without quotes) into the Synaptic Quick filter box, Synaptic shows four search results none of which is the insight debugger. I also tried (in Konsole) sudo apt-get install insight which resulted in "E: Package 'insight' has no installation candidate".
    Has Kubuntu removed the insight debugger from the repo or is there some other method for installing this package ?
    Best regards,
    Stuart
    Debian, and eventually Ubuntu apparently removed this quite ancient software quite some time ago, as far as I can tell. I see report of it happening in 2010.
    I am having a hard time finding references to it past 2015
