It's a minor annoyance only, but every time I boot up my laptop, the System Volume is muted. I can set the volume from the System Tray, but it won't survive a reboot. Thoughts?
Volume always muted when system is booted
Slava Ukraini! πΊπ¦
"It is a capital mistake to theorize before one has data." - Sherlock HolmesβTags: None
A root owned file or directory? On my Eoan,
is where the the volume is saved, you might check around there. .tdb files, "trivial database", are some awful (IMO) samba format that pulseaudio uses.Code:$ touch ts $ # change the audio volume... $ find .config -newer ts .config/pulse/a112c35e9614496caa1b3e9cdf66b7f5-device-volumes.tdb
Not an ownership problem. All the files in .config/pulse are owned by me, and all have rw attributes.Slava Ukraini! πΊπ¦
Have you tried to use alsamixer?
Execute:
sudo alsactl store Set your volume levels and other levels, then hit ESC
This should save alsamixer configurations to /etc/asound.state which gets loaded every startup.
Another option is using "sudo alsactl store" after setting your sound volumes in the system tray.
DISCLAIMER: Some advise against using alsamixer when pulseaudio is installed. It hasn't given my setup any problems. But, if that were the case then why the following:
AND:/usr/share/pulseaudio/alsa-mixer
/usr/share/pulseaudio/alsa-mixer/paths
/usr/share/pulseaudio/alsa-mixer/profile-sets
/usr/share/pulseaudio/alsa-mixer/paths/analog-input-aux.conf
/usr/share/pulseaudio/alsa-mixer/paths/analog-input-dock-mic.conf
/usr/share/pulseaudio/alsa-mixer/paths/analog-input-fm.conf
/usr/share/pulseaudio/alsa-mixer/paths/analog-input-front-mic.conf
/usr/share/pulseaudio/alsa-mixer/paths/analog-input-headphone-mic.conf
/usr/share/pulseaudio/alsa-mixer/paths/analog-input-headset-mic.conf
/usr/share/pulseaudio/alsa-mixer/paths/analog-input-internal-mic-always.conf
/usr/share/pulseaudio/alsa-mixer/paths/analog-input-internal-mic.conf
/usr/share/pulseaudio/alsa-mixer/paths/analog-input-linein.conf
/usr/share/pulseaudio/alsa-mixer/paths/analog-input-mic-line.conf
/usr/share/pulseaudio/alsa-mixer/paths/analog-input-mic.conf
/usr/share/pulseaudio/alsa-mixer/paths/analog-input-mic.conf.common
/usr/share/pulseaudio/alsa-mixer/paths/analog-input-rear-mic.conf
/usr/share/pulseaudio/alsa-mixer/paths/analog-input-tvtuner.conf
/usr/share/pulseaudio/alsa-mixer/paths/analog-input-video.conf
/usr/share/pulseaudio/alsa-mixer/paths/analog-input.conf
/usr/share/pulseaudio/alsa-mixer/paths/analog-input.conf.common
/usr/share/pulseaudio/alsa-mixer/paths/analog-output-headphones-2.conf
/usr/share/pulseaudio/alsa-mixer/paths/analog-output-headphones.conf
/usr/share/pulseaudio/alsa-mixer/paths/analog-output-lineout.conf
/usr/share/pulseaudio/alsa-mixer/paths/analog-output-mono.conf
/usr/share/pulseaudio/alsa-mixer/paths/analog-output-speaker-always.conf
/usr/share/pulseaudio/alsa-mixer/paths/analog-output-speaker.conf
/usr/share/pulseaudio/alsa-mixer/paths/analog-output.conf
/usr/share/pulseaudio/alsa-mixer/paths/analog-output.conf.common
/usr/share/pulseaudio/alsa-mixer/paths/hdmi-output-0.conf
/usr/share/pulseaudio/alsa-mixer/paths/hdmi-output-1.conf
/usr/share/pulseaudio/alsa-mixer/paths/hdmi-output-2.conf
/usr/share/pulseaudio/alsa-mixer/paths/hdmi-output-3.conf
/usr/share/pulseaudio/alsa-mixer/paths/hdmi-output-4.conf
/usr/share/pulseaudio/alsa-mixer/paths/hdmi-output-5.conf
/usr/share/pulseaudio/alsa-mixer/paths/hdmi-output-6.conf
/usr/share/pulseaudio/alsa-mixer/paths/hdmi-output-7.conf
/usr/share/pulseaudio/alsa-mixer/paths/iec958-stereo-input.conf
/usr/share/pulseaudio/alsa-mixer/paths/iec958-stereo-output.conf
/usr/share/pulseaudio/alsa-mixer/paths/steelseries-arctis-output-chat-common.conf
/usr/share/pulseaudio/alsa-mixer/paths/steelseries-arctis-output-game-common.conf
/usr/share/pulseaudio/alsa-mixer/paths/usb-gaming-headset-input.conf
/usr/share/pulseaudio/alsa-mixer/paths/usb-gaming-headset-output-mono.conf
/usr/share/pulseaudio/alsa-mixer/paths/usb-gaming-headset-output-stereo.conf
/usr/share/pulseaudio/alsa-mixer/profile-sets/cmedia-high-speed-true-hdaudio.conf
/usr/share/pulseaudio/alsa-mixer/profile-sets/default.conf
/usr/share/pulseaudio/alsa-mixer/profile-sets/dell-dock-tb16-usb-audio.conf
/usr/share/pulseaudio/alsa-mixer/profile-sets/force-speaker-and-int-mic.conf
/usr/share/pulseaudio/alsa-mixer/profile-sets/force-speaker.conf
/usr/share/pulseaudio/alsa-mixer/profile-sets/kinect-audio.conf
/usr/share/pulseaudio/alsa-mixer/profile-sets/maudio-fasttrack-pro.conf
/usr/share/pulseaudio/alsa-mixer/profile-sets/native-instruments-audio4dj.conf
/usr/share/pulseaudio/alsa-mixer/profile-sets/native-instruments-audio8dj.conf
/usr/share/pulseaudio/alsa-mixer/profile-sets/native-instruments-korecontroller.conf
/usr/share/pulseaudio/alsa-mixer/profile-sets/native-instruments-traktor-audio10.conf
/usr/share/pulseaudio/alsa-mixer/profile-sets/native-instruments-traktor-audio2.conf
/usr/share/pulseaudio/alsa-mixer/profile-sets/native-instruments-traktor-audio6.conf
/usr/share/pulseaudio/alsa-mixer/profile-sets/native-instruments-traktorkontrol-s4.conf
/usr/share/pulseaudio/alsa-mixer/profile-sets/sb-omni-surround-5.1.conf
/usr/share/pulseaudio/alsa-mixer/profile-sets/steelseries-arctis-common-usb-audio.conf
/usr/share/pulseaudio/alsa-mixer/profile-sets/usb-gaming-headset.conf
The alsa-restore.service contains:/usr/lib/systemd/system/alsa-restore.service
/usr/lib/systemd/system/sound.target.wants/alsa-restore.service
which uses alsactl.Code:$ cat /usr/lib/systemd/system/alsa-restore.service # # Note that two different ALSA card state management schemes exist and they # can be switched using a file exist check - /etc/alsa/state-daemon.conf . # [Unit] Description=Save/Restore Sound Card State Documentation=man:alsactl(1) ConditionPathExists=!/etc/alsa/state-daemon.conf ConditionPathExistsGlob=/dev/snd/control* After=alsa-state.service [Service] Type=oneshot RemainAfterExit=true ExecStartPre=/bin/mkdir -p /run/alsa ExecStart=-/usr/sbin/alsactl -E HOME=/run/alsa -E XDG_RUNTIME_DIR=/run/alsa/runtime restore ExecStop=-/usr/sbin/alsactl -E HOME=/run/alsa -E XDG_RUNTIME_DIR=/run/alsa/runtime store
I checked my alsa-restore.service status and was shown this:
Code:$ sudo systemctl status alsa-restore.service [sudo] password for jerry: ● alsa-restore.service - Save/Restore Sound Card State Loaded: loaded (/lib/systemd/system/alsa-restore.service; static; vendor preset: enabled) Active: active (exited) since Fri 2020-03-20 11:29:00 CDT; 1h 5min ago Docs: man:alsactl(1) Process: 916 ExecStartPre=/bin/mkdir -p /run/alsa (code=exited, status=0/SUCCESS) Process: 973 ExecStart=/usr/sbin/alsactl -E HOME=/run/alsa -E XDG_RUNTIME_DIR=/run/alsa/runtime> Main PID: 973 (code=exited, status=0/SUCCESS) Mar 20 11:29:00 Aspire-V3-771 systemd[1]: Starting Save/Restore Sound Card State... Mar 20 11:29:00 Aspire-V3-771 systemd[1]: Started Save/Restore Sound Card State.Last edited by GreyGeek; Mar 20, 2020, 11:37 AM."A nation that is afraid to let its people judge the truth and falsehood in an open market is a nation that is afraid of its people.β
β John F. Kennedy, February 26, 1962.
If Greygeek's suggestions don't help, a workaround could be to set the volume in a startup script.sets the default volume to 50%, 32768 being 50% of 65536.Code:$ pactl set-sink-volume @DEFAULT_SINK@ 32768
So, attempting to run sudo alsactl store resulting in:
sudo: alsactl: command not found
Seems that alsa-utils needs to be installed. So, I installed it.
sudo alsactl store then executes; at least, it doesn't present the error; I'm returned to the prompt.
With alsa-utils or without, I still don't have even notification sounds (Configure Notifications - System Settings Module). None of the events that are 'active' play the specified .ogg file. What is interesting, is that if I right-click on the speaker icon in the System Tray and click on Configure Audio Volume... and click on Audio > Advanced and click on Front Left or Front Right, I hear "Front left" and "Front right", so obviously sound functions.
Also of note: After installing alsa-utils and rebooting (ensuring that the volume was not zero (System Tray > Audio Volume), rebooting resulted in the volume not being muted; it retained the volume setting. This was true even after I purged alsa-utils and rebooted.
This issue is now 'Solved'. Not sure if it was the installation of alsa-utils (installed it; purged it; installed it again), or following the guidance found here. What ever. alsa-utils is installed, and I followed that links guidance and added options snd-hda-intel model=generic to the end of /etc/modprobe.d/alsa-base.conf. A reboot and I have system notification sounds.Slava Ukraini! πΊπ¦
