Hello everybody!
I hope you all are doing well.
I have recently changed the OS from Ubuntu 20.04 (GNOME GUI) to Kubuntu 20.04 (KDE Plasma) and Windows 10 with dualboot.
I had been using Kubuntu with no updates (even with no NVIDIA proprietary driver installed) for 2 weeks or so and never noticed any bugs. So I decided to update the system. Right after the update (used sudo apt update && sudo apt upgrade) I faced the following problem: machine turns off and then reboots in a second, thus leading me to the SDDM Login Screen.
I installed package named "laptop-mode-tools" and it solved the problem... for a while (1 week of adequate shutdown).
I am facing this problem of rebooting instead of shutdown again and nothing seems to work properly.
I tried using sudo shutdown now, but it didn't work.
I have to mention, I have Windows 10 installed as 2nd OS (dualboot), and it shutdowns the machine properly. More than that, I never faced this problem while using Ubuntu 20.04.
I suppose, you are probably interested in the result of inxi -Fxzd command to get started (hope that helps):
Hope we can find a solution and thank you in advance.
[FONT=monospace][COLOR=#5454ff][B]System: Kernel:[/B][/COLOR][COLOR=#000000] 5.4.0-64-generic x86_64 [/COLOR][COLOR=#5454ff][B]bits:[/B][/COLOR][COLOR=#000000] 64 [/COLOR][COLOR=#5454ff][B]compiler:[/B][/COLOR][COLOR=#000000] gcc [/COLOR][COLOR=#5454ff][B]v:[/B][/COLOR][COLOR=#000000] 9.3.0 [/COLOR][COLOR=#5454ff][B]Desktop:[/B][/COLOR][COLOR=#000000] KDE Plasma 5.18.5 [/COLOR]
[COLOR=#5454ff][B]Distro:[/B][/COLOR][COLOR=#000000] Ubuntu 20.04.1 LTS (Focal Fossa) [/COLOR]
[COLOR=#5454ff][B]Machine: Type:[/B][/COLOR][COLOR=#000000] Laptop [/COLOR][COLOR=#5454ff][B]System:[/B][/COLOR][COLOR=#000000] Hewlett-Packard [/COLOR][COLOR=#5454ff][B]product:[/B][/COLOR][COLOR=#000000] HP ZBook 15 G2 [/COLOR][COLOR=#5454ff][B]v:[/B][/COLOR][COLOR=#000000] A3009DD10303 [/COLOR][COLOR=#5454ff][B]serial:[/B][/COLOR][COLOR=#000000] <filter> [/COLOR]
[COLOR=#5454ff][B]Mobo:[/B][/COLOR][COLOR=#000000] Hewlett-Packard [/COLOR][COLOR=#5454ff][B]model:[/B][/COLOR][COLOR=#000000] 2253 [/COLOR][COLOR=#5454ff][B]v:[/B][/COLOR][COLOR=#000000] KBC Version 03.12 [/COLOR][COLOR=#5454ff][B]serial:[/B][/COLOR][COLOR=#000000] <filter> [/COLOR][COLOR=#5454ff][B]UEFI:[/B][/COLOR][COLOR=#000000] Hewlett-Packard [/COLOR]
[COLOR=#5454ff][B]v:[/B][/COLOR][COLOR=#000000] M70 Ver. 01.24 [/COLOR][COLOR=#5454ff][B]date:[/B][/COLOR][COLOR=#000000] 04/17/2019 [/COLOR]
[COLOR=#5454ff][B]Battery: ID-1:[/B][/COLOR][COLOR=#000000] BAT0 [/COLOR][COLOR=#5454ff][B]charge:[/B][/COLOR][COLOR=#000000] 33.8 Wh [/COLOR][COLOR=#5454ff][B]condition:[/B][/COLOR][COLOR=#000000] 49.1/49.1 Wh (100%) [/COLOR][COLOR=#5454ff][B]model:[/B][/COLOR][COLOR=#000000] Hewlett-Packard Primary [/COLOR]
[COLOR=#5454ff][B]status:[/B][/COLOR][COLOR=#000000] Discharging [/COLOR]
[COLOR=#5454ff][B]CPU: Topology:[/B][/COLOR][COLOR=#000000] Quad Core [/COLOR][COLOR=#5454ff][B]model:[/B][/COLOR][COLOR=#000000] Intel Core i7-4810MQ [/COLOR][COLOR=#5454ff][B]bits:[/B][/COLOR][COLOR=#000000] 64 [/COLOR][COLOR=#5454ff][B]type:[/B][/COLOR][COLOR=#000000] MT MCP [/COLOR][COLOR=#5454ff][B]arch:[/B][/COLOR][COLOR=#000000] Haswell [/COLOR][COLOR=#5454ff][B]rev:[/B][/COLOR][COLOR=#000000] 3 [/COLOR]
[COLOR=#5454ff][B]L2 cache:[/B][/COLOR][COLOR=#000000] 6144 KiB [/COLOR]
[COLOR=#5454ff][B]flags:[/B][/COLOR][COLOR=#000000] avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx [/COLOR][COLOR=#5454ff][B]bogomips:[/B][/COLOR][COLOR=#000000] 44694 [/COLOR]
[COLOR=#5454ff][B]Speed:[/B][/COLOR][COLOR=#000000] 1468 MHz [/COLOR][COLOR=#5454ff][B]min/max:[/B][/COLOR][COLOR=#000000] 800/3800 MHz [/COLOR][COLOR=#5454ff][B]Core speeds (MHz):[/B][/COLOR][COLOR=#5454ff][B]1:[/B][/COLOR][COLOR=#000000] 1421 [/COLOR][COLOR=#5454ff][B]2:[/B][/COLOR][COLOR=#000000] 1403 [/COLOR][COLOR=#5454ff][B]3:[/B][/COLOR][COLOR=#000000] 1401 [/COLOR][COLOR=#5454ff][B]4:[/B][/COLOR][COLOR=#000000] 1400 [/COLOR][COLOR=#5454ff][B]5:[/B][/COLOR][COLOR=#000000] 1398 [/COLOR]
[COLOR=#5454ff][B]6:[/B][/COLOR][COLOR=#000000] 1574 [/COLOR][COLOR=#5454ff][B]7:[/B][/COLOR][COLOR=#000000] 1443 [/COLOR][COLOR=#5454ff][B]8:[/B][/COLOR][COLOR=#000000] 1465 [/COLOR]
[COLOR=#5454ff][B]Graphics: Device-1:[/B][/COLOR][COLOR=#000000] Intel 4th Gen Core Processor Integrated Graphics [/COLOR][COLOR=#5454ff][B]vendor:[/B][/COLOR][COLOR=#000000] Hewlett-Packard [/COLOR][COLOR=#5454ff][B]driver:[/B][/COLOR][COLOR=#000000] i915 [/COLOR]
[COLOR=#5454ff][B]v:[/B][/COLOR][COLOR=#000000] kernel [/COLOR][COLOR=#5454ff][B]bus ID:[/B][/COLOR][COLOR=#000000] 00:02.0 [/COLOR]
[COLOR=#5454ff][B]Device-2:[/B][/COLOR][COLOR=#000000] NVIDIA GK107GLM [Quadro K1100M] [/COLOR][COLOR=#5454ff][B]vendor:[/B][/COLOR][COLOR=#000000] Hewlett-Packard [/COLOR][COLOR=#5454ff][B]driver:[/B][/COLOR][COLOR=#000000] nvidia [/COLOR][COLOR=#5454ff][B]v:[/B][/COLOR][COLOR=#000000] 390.141 [/COLOR]
[COLOR=#5454ff][B]bus ID:[/B][/COLOR][COLOR=#000000] 01:00.0 [/COLOR]
[COLOR=#5454ff][B]Display:[/B][/COLOR][COLOR=#000000] x11 [/COLOR][COLOR=#5454ff][B]server:[/B][/COLOR][COLOR=#000000] X.Org 1.20.9 [/COLOR][COLOR=#5454ff][B]driver:[/B][/COLOR][COLOR=#000000] modesetting,nvidia [/COLOR][COLOR=#5454ff][B]unloaded:[/B][/COLOR][COLOR=#000000] fbdev,nouveau,vesa [/COLOR]
[COLOR=#5454ff][B]resolution:[/B][/COLOR][COLOR=#000000] 1920x1080~60Hz [/COLOR]
[COLOR=#5454ff][B]OpenGL:[/B][/COLOR][COLOR=#5454ff][B]renderer:[/B][/COLOR][COLOR=#000000] Quadro K1100M/PCIe/SSE2 [/COLOR][COLOR=#5454ff][B]v:[/B][/COLOR][COLOR=#000000] 4.6.0 NVIDIA 390.141 [/COLOR][COLOR=#5454ff][B]direct render:[/B][/COLOR][COLOR=#000000] Yes [/COLOR]
[COLOR=#5454ff][B]Audio: Device-1:[/B][/COLOR][COLOR=#000000] Intel 8 Series/C220 Series High Definition Audio [/COLOR][COLOR=#5454ff][B]vendor:[/B][/COLOR][COLOR=#000000] Hewlett-Packard [/COLOR]
[COLOR=#5454ff][B]driver:[/B][/COLOR][COLOR=#000000] snd_hda_intel [/COLOR][COLOR=#5454ff][B]v:[/B][/COLOR][COLOR=#000000] kernel [/COLOR][COLOR=#5454ff][B]bus ID:[/B][/COLOR][COLOR=#000000] 00:1b.0 [/COLOR]
[COLOR=#5454ff][B]Device-2:[/B][/COLOR][COLOR=#000000] NVIDIA GK107 HDMI Audio [/COLOR][COLOR=#5454ff][B]vendor:[/B][/COLOR][COLOR=#000000] Hewlett-Packard [/COLOR][COLOR=#5454ff][B]driver:[/B][/COLOR][COLOR=#000000] snd_hda_intel [/COLOR][COLOR=#5454ff][B]v:[/B][/COLOR][COLOR=#000000] kernel [/COLOR]
[COLOR=#5454ff][B]bus ID:[/B][/COLOR][COLOR=#000000] 01:00.1 [/COLOR]
[COLOR=#5454ff][B]Sound Server:[/B][/COLOR][COLOR=#000000] ALSA [/COLOR][COLOR=#5454ff][B]v:[/B][/COLOR][COLOR=#000000] k5.4.0-64-generic [/COLOR]
[COLOR=#5454ff][B]Network: Device-1:[/B][/COLOR][COLOR=#000000] Intel Ethernet I217-LM [/COLOR][COLOR=#5454ff][B]vendor:[/B][/COLOR][COLOR=#000000] Hewlett-Packard [/COLOR][COLOR=#5454ff][B]driver:[/B][/COLOR][COLOR=#000000] e1000e [/COLOR][COLOR=#5454ff][B]v:[/B][/COLOR][COLOR=#000000] 3.2.6-k [/COLOR][COLOR=#5454ff][B]port:[/B][/COLOR][COLOR=#000000] 6080 [/COLOR]
[COLOR=#5454ff][B]bus ID:[/B][/COLOR][COLOR=#000000] 00:19.0 [/COLOR]
[COLOR=#5454ff][B]IF:[/B][/COLOR][COLOR=#000000] enp0s25 [/COLOR][COLOR=#5454ff][B]state:[/B][/COLOR][COLOR=#000000] down [/COLOR][COLOR=#5454ff][B]mac:[/B][/COLOR][COLOR=#000000] <filter> [/COLOR]
[COLOR=#5454ff][B]Device-2:[/B][/COLOR][COLOR=#000000] Intel Wireless 7260 [/COLOR][COLOR=#5454ff][B]driver:[/B][/COLOR][COLOR=#000000] iwlwifi [/COLOR][COLOR=#5454ff][B]v:[/B][/COLOR][COLOR=#000000] kernel [/COLOR][COLOR=#5454ff][B]port:[/B][/COLOR][COLOR=#000000] 5000 [/COLOR][COLOR=#5454ff][B]bus ID:[/B][/COLOR][COLOR=#000000] 3d:00.0 [/COLOR]
[COLOR=#5454ff][B]IF:[/B][/COLOR][COLOR=#000000] wlp61s0 [/COLOR][COLOR=#5454ff][B]state:[/B][/COLOR][COLOR=#000000] up [/COLOR][COLOR=#5454ff][B]mac:[/B][/COLOR][COLOR=#000000] <filter> [/COLOR]
[COLOR=#5454ff][B]Drives: Local Storage:[/B][/COLOR][COLOR=#5454ff][B]total:[/B][/COLOR][COLOR=#000000] 447.13 GiB [/COLOR][COLOR=#5454ff][B]used:[/B][/COLOR][COLOR=#000000] 29.20 GiB (6.5%) [/COLOR]
[COLOR=#5454ff][B]ID-1:[/B][/COLOR][COLOR=#000000] /dev/sda [/COLOR][COLOR=#5454ff][B]vendor:[/B][/COLOR][COLOR=#000000] Kingston [/COLOR][COLOR=#5454ff][B]model:[/B][/COLOR][COLOR=#000000] SA400S37480G [/COLOR][COLOR=#5454ff][B]size:[/B][/COLOR][COLOR=#000000] 447.13 GiB [/COLOR]
[COLOR=#5454ff][B]Optical-1:[/B][/COLOR][COLOR=#000000] /dev/sr0 [/COLOR][COLOR=#5454ff][B]vendor:[/B][/COLOR][COLOR=#000000] hp [/COLOR][COLOR=#5454ff][B]model:[/B][/COLOR][COLOR=#000000] DVDRW DU8A6SH [/COLOR][COLOR=#5454ff][B]rev:[/B][/COLOR][COLOR=#000000] DH61 [/COLOR][COLOR=#5454ff][B]dev-links:[/B][/COLOR][COLOR=#000000] cdrom,cdrw,dvd,dvdrw [/COLOR]
[COLOR=#5454ff][B]Features:[/B][/COLOR][COLOR=#5454ff][B]speed:[/B][/COLOR][COLOR=#000000] 24 [/COLOR][COLOR=#5454ff][B]multisession:[/B][/COLOR][COLOR=#000000] yes [/COLOR][COLOR=#5454ff][B]audio:[/B][/COLOR][COLOR=#000000] yes [/COLOR][COLOR=#5454ff][B]dvd:[/B][/COLOR][COLOR=#000000] yes [/COLOR][COLOR=#5454ff][B]rw:[/B][/COLOR][COLOR=#000000] cd-r,cd-rw,dvd-r,dvd-ram [/COLOR][COLOR=#5454ff][B]state:[/B][/COLOR][COLOR=#000000] running [/COLOR]
[COLOR=#5454ff][B]Partition: ID-1:[/B][/COLOR][COLOR=#000000] / [/COLOR][COLOR=#5454ff][B]size:[/B][/COLOR][COLOR=#000000] 124.07 GiB [/COLOR][COLOR=#5454ff][B]used:[/B][/COLOR][COLOR=#000000] 10.77 GiB (8.7%) [/COLOR][COLOR=#5454ff][B]fs:[/B][/COLOR][COLOR=#000000] ext4 [/COLOR][COLOR=#5454ff][B]dev:[/B][/COLOR][COLOR=#000000] /dev/sda3 [/COLOR]
[COLOR=#5454ff][B]ID-2:[/B][/COLOR][COLOR=#000000] /home [/COLOR][COLOR=#5454ff][B]size:[/B][/COLOR][COLOR=#000000] 191.23 GiB [/COLOR][COLOR=#5454ff][B]used:[/B][/COLOR][COLOR=#000000] 18.40 GiB (9.6%) [/COLOR][COLOR=#5454ff][B]fs:[/B][/COLOR][COLOR=#000000] ext4 [/COLOR][COLOR=#5454ff][B]dev:[/B][/COLOR][COLOR=#000000] /dev/sda4 [/COLOR]
[COLOR=#5454ff][B]ID-3:[/B][/COLOR][COLOR=#000000] swap-1 [/COLOR][COLOR=#5454ff][B]size:[/B][/COLOR][COLOR=#000000] 24.79 GiB [/COLOR][COLOR=#5454ff][B]used:[/B][/COLOR][COLOR=#000000] 0 KiB (0.0%) [/COLOR][COLOR=#5454ff][B]fs:[/B][/COLOR][COLOR=#000000] swap [/COLOR][COLOR=#5454ff][B]dev:[/B][/COLOR][COLOR=#000000] /dev/sda2 [/COLOR]
[COLOR=#5454ff][B]Sensors: System Temperatures:[/B][/COLOR][COLOR=#5454ff][B]cpu:[/B][/COLOR][COLOR=#000000] 63.0 C [/COLOR][COLOR=#5454ff][B]mobo:[/B][/COLOR][COLOR=#000000] 48.0 C [/COLOR][COLOR=#5454ff][B]gpu:[/B][/COLOR][COLOR=#000000] nvidia [/COLOR][COLOR=#5454ff][B]temp:[/B][/COLOR][COLOR=#000000] 49 C [/COLOR]
[COLOR=#5454ff][B]Fan Speeds (RPM):[/B][/COLOR][COLOR=#000000] N/A [/COLOR]
[COLOR=#5454ff][B]Info: Processes:[/B][/COLOR][COLOR=#000000] 241 [/COLOR][COLOR=#5454ff][B]Uptime:[/B][/COLOR][COLOR=#000000] 16m [/COLOR][COLOR=#5454ff][B]Memory:[/B][/COLOR][COLOR=#000000] 23.16 GiB [/COLOR][COLOR=#5454ff][B]used:[/B][/COLOR][COLOR=#000000] 1.87 GiB (8.1%) [/COLOR][COLOR=#5454ff][B]Init:[/B][/COLOR][COLOR=#000000] systemd [/COLOR][COLOR=#5454ff][B]runlevel:[/B][/COLOR][COLOR=#000000] 5 [/COLOR]
[COLOR=#5454ff][B]Compilers:[/B][/COLOR][COLOR=#5454ff][B]gcc:[/B][/COLOR][COLOR=#000000] 9.3.0 [/COLOR][COLOR=#5454ff][B]clang:[/B][/COLOR][COLOR=#000000] 10.0.0-4ubuntu1 [/COLOR][COLOR=#5454ff][B]Shell:[/B][/COLOR][COLOR=#000000] bash [/COLOR][COLOR=#5454ff][B]v:[/B][/COLOR][COLOR=#000000] 5.0.17 [/COLOR][COLOR=#5454ff][B]inxi:[/B][/COLOR][COLOR=#000000] 3.0.38 [/COLOR]
[/FONT]
