linux-image-5.4.0-42-generic post-removal error
    [SOLVED] linux-image-5.4.0-42-generic post-removal error
    During the apt-get upgrade, I get the following error message: installed linux-image-5.4.0-42-generic package post-removal script
    subprocess returned error exit status 1
    I have taken the usual steps for such cases. What to do?
    Have you manually removed any kernels?
    Intel i7 11th Gen 16GB 1TB
      I tried to remove the kernel in question manually, but without success.
        O.K. Without knowing what you did as "the usual steps", have you tried
        sudo apt autoremove
        sudo apt autoclean
        sudo apt clean
        in that sequence?
        Have you tried to remove that object in Synaptic or Muon?
        And what is your dual boot configuration?
          sudo apt autoremove
          sudo apt autoclean
          sudo apt clean
          in that sequence?
          Yes, I ran the above commands in that order without any results. Anyway, the problem has been solved ever since. It turned out that I misconfigured something in grub.cfg with my grub menu timeout. After I fixed this, now everything is working normally. By the way, I don't use dual-boot, but multi-boot, because I have multiple systems installed on separate partitions in parallel.
            Glad you got it solved.
            You had the "Dual Boot" label on your original title, thus my question about dual boot. Multiboot is cool, too!
              Originally posted by zoli62 View Post
              ... I have multiple systems installed on separate partitions in parallel.
              I used to juggle multiple systems in "multiple separate partitions"... then I moved to btrfs, with multiple systems in separate subvolumes, a huge time saver. Sometimes the installers won't do it directly, in which case I install to scratch partitions then move the system into the btrfs.
                How much more stable is btrfs filesystem than ext4?
