disable touchpad when mouse plugged in
    [SOLVED] disable touchpad when mouse plugged in
    In previous versions of Kubuntu, I had a choice to disable the touchpad if my mouse was plugged in. I kept in my CherryTree notes how to do it:
    Alt+F2
    Type "Touchpad"
    Choose "Touchpad Settings"
    The Alt+F2 and then typing "Touchpad" brings up the same thing as this:
    System Settings ⇒ Input Devices ⇒ Touchpad
    Either way, there used to be a checkbox where I chose "disable touchpad when mouse is plugged in." I did notice that page shows my touchpad as:
    SynPS/2 Synaptics Touchpad
    My laptop is a Lenovo Ideapad Z570. I think on that Touchpad page it used to list a Lenovo touchpad, but I'm not certain. I'm wondering if during this install of 20.04 maybe my Z570 somehow didn't get its proper driver. The touchpad does run with that PS/2 Synaptics one. I would just like to be able to automatically disable it when I plug a mouse in. If I'm using a mouse, I never use the touchpad. I prefer that, as I can't accidentally touch the touchpad causing the cursor to move off to somewhere that I did not intend.
    So I'm wondering if I have the wrong touchpad driver and need to hunt down the right one. Or, alternatively, maybe there's some kind of utility out there that can monitor if a mouse gets plugged in and then will disable the touchpad.
    Kubuntu 20.04 (desktop & laptop), Windows 7 (via VirtualBox on desktop PC)
    My guess is that the newer kubuntu is using the newer libinput xorg-input driver by default. The older synaptics driver is on it's way out (but still installable and working) that currently offers more configuration options (and a different config dialog for system settings).
    I'd first check which driver is in use, by running:
    xinput list
    Note the id number for your touchpad in the output.
    Then run:
    xinput list-props <id>
    replace "<id>" with the id number you got from the previous command:
    Do you see references to "libinput" or "synaptics" on the configuration output.
    If it's "libinput", install "xserver-xorg-input-synaptics" package and reboot.
    Then check the xinput commands that the config has changed to Synaptics.
    Now access the System Settings Input devices configuration and you should see a different dialog, in which you can set "disable when mouse plugged" (you can exclude certain mice devices as well, like a trackpoint).
    EDIT: The libinput driver should have automatic "palm detection" and "disable while typing" features, AFAICT, but there is always a chance it's not working for you (or doesn't fit what you need to prevent accidental cursor movements), in which case trying out the synaptics driver and it's options is probably a good idea (at least for the time being).
      you need to install the package xserver-xorg-input-synaptics
      (top of thread: thread tools)
        ^This. I just want to add that after installing it, you may need to open and close System Settings more than once before it finally shows up in its touchpad settings; this is what it should look like, with five tabs:
          I can see how that might get lost in the details. Glad you both agree, though
            I'm sorry, @kubicle! I even scanned your post [with my old, tired, blurry, awful eyes], looking for that, and didn't see it! Kind of sums up how things have been going for me lately.
              Thanks, everyone! That worked perfectly. I've saved this info in my settings notes (in CherryTree) so that I have it if I ever need to install Kubuntu from scratch again.
              Thank you all so much for your help.
              Btw, one of these days I'll make a post about how I document in detail all my OS installs in CherryTree. That way I have a record of exactly everything I did, making any new OS install go quickly and smoothly.
              Here's what it changed. What a difference!
                No need to be sorry, no harm done...and I'm quite adept in missing what other people have previously said myself.
                I just don't wish people to absurdly think that there is a question I don't know the answer to
                  Aw, shucks, @kubicle, you're too kind.
                  Seriously, I like to give credit where credit is due, so it bothers me when someone supplied the correct answer but I didn't even notice it.
                  At any rate, I for one will NEVER absurdly think there's a question you don't know the answer to!
                    You're welcome. I'm really glad you were able to get the results you wanted.
                    I keep notes, too, just in a running text file that's been going for...a looooooong time. The newest info always goes at the top, and I date and label each entry. If I need to find out how I...hmmmm...disabled the touchpad on 20.04 since it no longer offered that option, I look it up! Just search for 'touchpad' and it hits. I'd be very interested in seeing how you do yours.
                      Reading is hard sometimes
